Question about Dell OptiPlex GX270 PC Desktop
On boot up not reading the hard drive all the connections look good
    Novelist:
  • 186 Answers
How big is the drive? How old? You need a very quiet room for booting. When you boot, listen for a high pitched whine, this will be your disk spinning up. If you don't hear it, it may be stuck and a slight tap can sometimes make it spin again. Wishful thinking, but if it's older and small, break down and get a new big one. Don't throw the other away, the data can be retrieved. You can also go to bios and set boot for CD/DVD. Put in your master disk and you can get at your disk, maybe.
Posted on Nov 14, 2009
Have presario the pc turns on it says there is a device that isnt connected
If I am understanding your question as posted, it may be indicative that the hard drive may not be stable, or readable for that matter. If all the connections are correct and it still fails to boot, then see if you can get a disc to boot from and try and read the internal hard drive. If you can read information then the drive should still be good. It's just that the OS isn't properly configured. A reload of the OS should take care of it. However, if you can't read anything from the the hard drive, then the drive may be defective. Replace the drive, reload the OS and there you go.
Feb 19, 2013 | Compaq Presario 5000 PC Desktop
Laptop not working Packard bell message on screen says BOOTMGR is missing
HI
I Think the laptop is trying to read the hard drive to boot up and its got a problem reading it
it may be worth turning off the laptop unplug the power core remove the hard drive from the base of the laptop usually only one or two screws to take off the cover and normally quite easy to remove
then try to start up the laptop
then turn off again
give the hard drive a quick blow over the connections
replace the hard drive
and try to boot up again
if this dont help
press power up key as well as the F8 key
this will hopefully take you into the repair options
and try the last good known configuration
or
repair my computer
if this does not work then the hard drive may be corrupt of dead
which is not good new if you havent done any backup disks or have any recovery disks
or a operating system install disk
hope you get it sorted
Jul 07, 2011 | Computers & Internet
Acer Aspire one is reading: "Check cable connection!, PXE-M0F; Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key" What does this mean and what can I do to repair or by pass...
Generally an indication that the Hard Drive has failed. Try reseating the drive and see if it reads again. PXE is a default attempt to boot to a network boot if no hard drive is availabe
Oct 04, 2010 | Computers & Internet
STILL SAME PROBLEM
Sounds like your hard drive is either dead or the cable or interface is not making a good connection. The computer cannot read the main hard drive that contains the master boot record and the computer is searching for a boot device. The pxe-e61 is the computer searching for a network drive to boot from. It then goes to the next device in it's menu. Need to check the hard drive and all cables and / or interface connections. Go through the BIOS settings and make sure the computer default settings are reset.
Jun 18, 2010 | Acer Aspire 3680 Laptop
Disk read error
kindly chek the drive connection make sure the cable is properly connected if possible then change the power connector of the hard disk.and boot the system in safe mode and go to command prompt and type chkdsk /r /f and restart the system.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 22, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Sony vaio pcv rx680g desktop
First, ensure that the bios is reading the hard drive and that the hard drive is part of the boot sequence. If you have a known working drive and the drive is not been read by the bios, you will get the Disc Boot failure error because windows resides on the disc which the bios cannot access.
Secondly, if the bios is reading the disc then ensure that the disc is set as part of the boot sequence-preferably the item after DVD drive should be Hard Disc in the boot menu.
If both of these items are in correct order then you could have a bad boot sector on the drive. Run a C:Chkdsk. If no bad sectors are found try C:Fixmbr-ensure that the Windows installation disc is in the CD/DVD drive when running Fixmbr.
If that fails do a clean install of windows.
Good Luck
Sep 28, 2009 | Sony VAIO Digital Studio PCV-RX680G...
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
I have emachine t5010 not booting. I receive error message
This means the system can't read from your hard drive. This might be due to a loose data or power cable connection. You can open the computer and make sure all the connections are firmly seated. It might also be a power supply problem. The hard drive may have failed. Or the drive may been wiped clean (or at least had its boot sector destroyed) as the result of a virus. A problem on the system board might have developed. Troubleshooting would involve booting from a CD to run diagnostic software, substituting known good parts, or both.
Dec 19, 2008 | E-Machines T5010 PC Desktop
Ilunable to read from hard drive or cdrom from p4i65g
Try changing the IDE cable which connects your CDROM to motherboard. Also make sure that Master/slave configuration are properly set if both the hard disk and the cdrom are connected with a single cable
Nov 25, 2008 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Hardisk failure
It can be a few things that are causing your issue; try these tips and see if any work for you: http://kb.iu.edu/data/aelm.html
If they don’t at least post what exactly happens when you try to boot, and we’ll help you further.
Nov 11, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Dell OptiPlex GX270 PC Desktop Logo
94 people viewed this question
Alun Cox
