Question about Car Audio & Video
Got a dw004 24v sds. just changed brushes, old ones pretty good. unit drops in speed by id say 1/3. every now and again kicks back into life. could this be the switch
  • 44 Answers
More than likely, i had a similar problem on a d/w 18v impact driver a friend gave me 'cause he thought it was dead, i replaced the switch and it has been working ever since
Posted on Nov 14, 2009
Testimonial: "cheers dude. thought it prob was as runs fine. just done my impact too. once again. many thanks"
Hitachi 24v sds hammer drill issues with speed when pulling back trigger switch sometimes works other times nothing, already changed dc speed control trigger any ideas to what the problem is? Thanks
faltering on a slide contact on electric field or switch, but in most cases dirth (dust) in carbonbrushes can be hanging somewhat in one or both brushholders.
Or a problem in the trigger switch itself dust and dirth have almost the highest priority in case of faltering by clamping carbon brushes.
Oct 04, 2016 | Hitachi Drills
Does anyone have advice on what to check next if you've changed the brushes on a BHR202 and it still doesn't work?
Is there a Deep discharge protection connector on your powertool ????
The thirth small contact in the battery connector or only 2 contacts ?
If not then its an advise it must be modificated then you have only to break off a notch on the new modificated battery holder connector so it can be placed in the older not marketing technical modificated housing, and you have to change the switch and the battery connector , the differences are 091A. 643844-1 old batteryconnector (2 contacts) change into 091B. 644808-8
New modified batteryconnector (3 contacts with deep discharge protection it has a limit until a level)
088A. 650578-9 Switch old model (2 contacts) replace for a
088B. 638882-6 New modified switch (3 contacts )
What you need is even expensive by this model if you have a modified type with the 3 contacts to know what can be wrong else is remove the brushes charge you battery and measure it first if its full and take a multimeter measure tool between both brushholder measure and pull the trigger that must between give 16and 20 volt DC if the battery was good charged . next measure is ohms resist measure both brushes in the brushholders and measure for a few ohms from brushcontact to brushcontact throught the armature inside the machine.
if not a resistance to get measure through the armature without brushes if some object or parts was comming trough the ventilation of the machine between armature and brusholder then the brush beet not the collector anymore different things to look at .
26116694-xaq5q3decq2piqybkt2ddcrv-2-0.jpg Look also how the kind of wiring technik of the armature is different left is a old kind of armature that will last for 5 years or more its having thicker wiring and an other winding pattern instead of the modern kind of armatures from the last years from 2009 and later Johnson armatures by PANASONIC MILWAUKEE, MAKITA , this new armature has a lot of more power but its faster defect because of the to tight tolerance of heat dissipation and ventilation but thats most in time of inbetween 2 or 3 years worn by the great strength and light machine makes this rapidly abuse when it is going to slowly get gives a shrill sound then i know there is also not much power on , batteries are fast empty and no power left ( AND THE PROBLEM IS PEOPLE THINK THE BATTERIES ARE GETTING OLD no thats not the problem but the armature is it and as before its eating carbon brushes in between 1 month again so fast if its worked in daily use. ALWAYS REPLACE BRUSHES AND ARMATURE (thermical shortings not to see but to hear and measure) at the same time it isnt not so expensive as that you choose new batteries and the batteries work great on a other tool . if the machine has eating the brushes with the old armature left on picture nothing was happens and it last again in good condition but the power difference is great between the old and the new armatures of the brand Milwaukee 18V to compare this old was Milwaukee 18volt and right the same kind of new sensitive armature like Panasonic or Makita have used in their tools.
Mar 03, 2016 | Makita 18V LXT 7/8in. Rotary Hammer - Tool...
How do I replace brushes on this drill?
[PDF]Hammers and Hammer Drills - eBuild
www.ebuild.com/ImgRepos%5C2010%20Hammers.pdf_06072010_110..See pages 46-49,. 184-214 for hammer drill accessories. BOSCH. H a m m e rs a n d.... 11250VSRD - 3/4" SDS-plus® Rotary Hammer .... technician can quickly replacethe brushes and cord .... 11264EVS - 1-5/8" SDS-max® Rotary Hammer.
Oct 20, 2015 | Bosch 11264EVS 1-5/8 SDS-Max Rotary Hammer
My drill start to smoke after 20-30secs of runing
Replace the brushes and clean the unit
My answers are short and sweet. Common sense mostly. If you are trying to get something for nothing...Don't waste my time! Remember if something sounds to good to be true that it usually is. I've spent many years of my life trying to cheat the system and was pretty good at it. This all changed when I discovered that people were doing the same thing to me. What comes around, goes around. Karma! Now I assist people in making win-win deals...that are legit!
Oct 18, 2014 | Drills
SDS drill variable power
Ok about changing the brushes but have you searched if the place where the brushes are located allow the brushes to move forward freely or they are in a way were narrowed so that the brushes can only move for few millimeters?
Mar 06, 2014 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
How to change brushes on bosch11227e rotary hammer
Disconnect the power cord from power supply first---ON most electric machines the brushes are under a small threaded button on either side of the motor case near the end. They are plastic and when unscrewed will have a spring around a copper wire attached to the brush. Just pull out and push in the new units ensuring that any curve of the brush will fit around the armature. Retighten the plastic cap.
Jul 09, 2012 | Bosch 11240 1-9/16" SDS Max Combination...
The rotating brush is stopping
Two things you can do. 1- Remove the brush as if you were going to change the drive belt for it. Clean the brush as best you can and spray some WD40 on the hard rubber/plastic pieces at both ends of the brush. Rotate the pieces to work the WD40 into the space between the pieces and the brush axle. 2- If you have one available, as long as the brush is off, change the belt.
This should get your unit back in operation. If you find this solution helpful, I would appreciate a Thumbs Up from you. Thank you. Paul
Oct 08, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do i change the brushes on a Bosch 11253 VSR?
Unscrew the caps, carefully remove the old brush, replace it with a new one that is exactly like the old. Replace the screw cap. Thats it.
Jun 09, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Drill and grinder only work upside down
The only time I have encountered this problem is when the field coil is loose in the motor housing, or one or more of the leads has come loose. By tipping the unit back the coil slides to the rear and makes contact. Then contact breaks when the tool in tipped forward.
Apr 28, 2009 | Metabo 600242420 BHE22 7/8" SDS-plus...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Car Audio & Video Logo
107 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
