Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Turns on picture distortd and curved in three color lines at top cannot get to convergence
  • RCA Master
  • 5,138 Answers
Go to menu then setup if you do not see convergence listed then you have a blowed fuse FL231 it will be on deflection board which is bottom board on left side it has FBT flyback transfomer on it and on the right side of FBT is 3 fuses in a roll they look like small brown rectrangler caps but they are fuses 0.6amps it will be the one in the middle Call Partstore.com for Part 1-866-925-7278 or look it up online .
God Bless and have a wonderfull day.
Posted on Nov 14, 2009
    Genius:
  • 1,112 Answers
The reason these fuse open is from bad connections around the flyback area, besides changing the fuses, buy the the way replace all three with new ones, Resolder the pins of the flyback area to eliminate fuses blowing again. If no fuses are blown then the convergence power supply is faulty and will need to be replaced.
Posted on Nov 15, 2009
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
Colors over lapping lll
convergence is off, convergence ICs need to be replaced
May 27, 2010 | RCA Scenium D40W20 40" Rear Projection...
The picture looks 3D
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Rca projection tv
this is a indication of convergence problem. the curved picture indicates total or a complete loss of convergence power. I first recomend you read the artilce in tips in tricks section. the fl231 problem it might be this if you do not have the convergence options in setup of customer menu. if not it might be a convergence power board issue
Oct 12, 2008 | RCA HD52W59 HDTV Projection Television
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
213 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
