Question about Ryobi Garden
Hi I have a Ryobi RBC30SET/ RBC30SBT strimmer / brushcutter and I need to know how to fill up the strimmer spool again. Cannot seem to load it properly with line so that it keeps coming out when it breaks off.If anyone can put up a video in youtube it would be great.
scrodamoon
  • 659 Answers
SOURCE: Strimmer Line
rotate the starter pulley by hand. You should feel the spring getting tight. Once the pulley is slightly tensioned, usually 5-10 turns, release the pulley and let is pull the string onto the pulley. You may have to add some tension to get all the rope to wind on the pulley.
Posted on Oct 04, 2008
  • 22 Answers
SOURCE: Strimmer line replacement
what model do you have?
Posted on Apr 03, 2009
#1 Taper
  • 1040 Answers
SOURCE: gls 220 auto strimmer
When putting new line on, it must be wound clockwise onto the spool
Jim
Posted on Jul 03, 2009
  • 8 Answers
SOURCE: strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Posted on Sep 13, 2009
bbreton
  • 437 Answers
SOURCE: I have a Ryobi RLT 30CESA with the strimmer
I would not put a brushcutter blade on this unit. The curved shaft quik disconnect may not hold up to the shock torque created by the brushblade. It may damage the drive shaft since it is a curved shaft quik disconnect model. You may have to purchase a straight shaft trimmer to get that job done.
Posted on Oct 03, 2009
Ryobi Li-ion strimmer
check that you are using the correct line in the head
if it is too thick , the load will be causing the thermo switch for the motor to stop operation until it cools down
Jun 16, 2017 | Ryobi Drills
Purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
try Lowes or any Agway, and if that dowsn't work, try checking on line with your type of trimmer.
Apr 22, 2012 | Garden
Hi, I have a Ryobi PBC 3046YB strimmer/brushcutter, which worked perfectly well in its first season, used about 10 times. When first used the following season, the machine would start easily, but when I...
This does not sound like an air leak, normally an air leak will cause fast uncontrollable idle, if it sounds muffled i would be looking at a blocked spark arrestor, or exhaust port, or muffler.Slacken the muffler right off and just try running it to see if it picks up normally.
Jul 18, 2011 | Ryobi Garden
How can i strimmer wire on a ryobi plt 3043ye
Hi alice louise
Try this method
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 02, 2011 | Ryobi 15" Electric Factory Reconditioned...
How to fit brushcutter to ryobi petrol strimmer. I have the tools but have lost the nuts etc, can I replace them? But will still not know how to fit the Tri-Ark
the nuts on weed eaters are usually left handed threads, they do sell them at a hardware store and I am sure the other parts you need you may have to go to a small engines sales/service. Hope this helped Tim
May 28, 2011 | Ryobi Garden
Strimmer will not start got spark & fuel ryobi rbc30sbt
its probabley your throttle cable , try pulling the throttle full on when you starting up the trimmer word of warning though only do this on a very flat surface..
Nov 23, 2010 | Ryobi Garden
I have a Ryobi RLT 30CESA with the strimmer attachment. What do I need to fit a Brushcutter blade to it
Oct 02, 2009 | Garden
I have just bought an RBC30SET. I am trying to
To remove the strimmer and procut fitment first you need to lock the shaft by placing item 35 into the slot in the flange next to the fitment and through into the hole in the outer housing of the drive shaft, item 3. Then using the box spanner turn the fitment CLOCKWISE. Once this has started to move it can be turned by hand until it released. Place the brush cutter onto the shaft followed by the dished washer, cupped face towards the cutter and fix in place with the nut, turning it anticlockwise to tighted. DO NOT overtighted as the direction the cutter turns will tighten the nut further.
Sep 18, 2009 | Ryobi Garden
Garden Logo
307 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
