Question about Mitsubishi WS-55813 55" Rear Projection HDTV
Green blinking light on Mitsubishi WS-55813 HDTV
The green power ligght keeps blinking, but TV won't turn on. I have tried unplugging, changing power source, reset button.
  • 5 more comments
  • chummles Feb 15, 2008
    Light continues to blink. Have tried to hold down menu button as described in post but nothing happens. Have hit reset several times, have unplugged TV for long period, and when plug back in, green light blinks.
  • Anonymous Jul 01, 2008
    Have the same problem. Technician seems to think its the EP2 module on the DM board.
  • jbarnes2 Jul 23, 2008
    I have the same problem. Light keeps blinking and won't turn on. None of the recommended actions in the manual work!
  • bilmarc Aug 21, 2008
    i have called my direct tv and they tried to help but couldnt, they said to call Mitsubishi so thats why im her can anyone help
  • swest7865 Sep 28, 2008
    The green light on the front of my TV WS-55813 Rear project HDTV keeps blinking. I've tried unplugging it overnight and have tried pressing the menu button for 10 seconds. Still keep blinking.
    Please help
  • gdgilb19 Nov 19, 2008
    I am having the same problem with the timer light blinking. I tried turning on the set last night and it would not come on. I thought the batteries were dead in my remote so I changed them and when I came back to turn the set on I noticed the green light was blinking and continued to blink all night. I have hit reset and menu and have unplugged the set but nothing is working.
  • Anonymous Mar 16, 2014
    green power light comes on for 2 seconds & goes off, tv won't come on
    Genius:
  • 1,030 Answers
Generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Posted on Jan 08, 2008
This link has the detailed procedure for the fix.
http://www.techlore.com/forum/thread/18565/Mitsubishi-WS-65711-HDTV-Green-Blinking-Light/
Posted on Dec 01, 2009
Mine was blinking every time I turned it on and would have to push reset at times to get it to come on and it was in energy mode. went to menu then setup change energy mode from low to standard problem fixed
Posted on Jan 20, 2008
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Willie@fordtv.com
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Can't turn on the TV. Green light keeps blinking.
You need to change the four capacitors C9B01,C9B02,C9B10,C9B11 all 1000 MFD 16 VOLT (on the DM board which is inside the metal shield standing upright on the left looking from the back of the set)The tops of the capacitors will look puffed out making them easy to find. This is your HD tuner digital board which is trying to reboot but can't - when the green light stops blinking after a minute,than you can power on your TV.
Aug 26, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-65613 tv green power light keeps blinking tv will not turn on
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Sep 11, 2009 | Mitsubishi WS-65613 65" Rear Projection...
Ws-55813 mod. green ld light wont stop blink tv wont turn on
The DM modul is bad. Replace all 1000mF/16V capacitors( be careful with the polarity). After replacing capacitors conect to AC power. Waith about 1min. Green flashing will stop. Turn ON tv. The modul is on the raight hand side next to the main board.
Jan 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Cannot turn tv on
mine required a bulb replacement it wasn't that old at the time
don't like being turned on and off a lot
Dec 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-65513
if you changed the energy mode from standard to low that is normal, anytime you turn the set on it will do the same,
plug set green light will blink one minute.
turn it on it will blink onother minute and then turn on(make sure that you dont keep pressing power key) once on you can change your settings again.
hdtvman.
Apr 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Timer Light Blinking
Replace four caps in DM module 1000mf/25v 105 degree...
common repair for qualified Mits tech............T.
Oct 13, 2007 | Mitsubishi WS-55813 55" Rear Projection...
Mitsubishi WS-55813 55" Rear Projection HDTV Logo
730 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
