Question about AT&T Computers & Internet
I don't have my network key, i want to connect my laptop to the desktop computer in the other room. how do i find that? i use windows XP. my desktop does not have a wireless local area connection option, plus it states i am not the administrator.
  • brandyone Nov 14, 2009
    i have got a linskys-g router the trouble is i can not find it 2 log on also when i go into wireless trying 2 log on the networks it shows and they ask 4 apassphase or network key can u help pls
  • Chris Hingee
    Chris Hingee May 11, 2010
    How do you want to network the laptop and the desktop together? You have several choices :- 1. Connect them (only two computers) with a crossover LAN cable (you don't need a hub). 2. Connect them together using a hub and standard LAN cables (this will allow to to expand your network beyond two computers). 3. Connect your desktop to a wireless router using a LAN cable and your laptop with a wireless connection (if you connect a broadband DSL or cable modem to this wireless router then these computers and others can all connect to the Internet). I assume the desktop has a LAN card and the laptop has a wireless card. When you decide which network method you want to setup, then I can advise you how to set up this network.
    Guru:
  • 1,738 Answers
First you need to create a administrator account on both computers. Make sure that you have ipx and spx protocols and both comptuer installs. Take you laptop back to your router and log into with the gateway address and go to the wireless tab. There you can create a network key, which is known as a password.
Posted on Nov 14, 2009
I got a wrt54gh router just less than a year now. it is connected to our desktop being used by my son & grandson in our living room, while i'm using my laptop in my room. it just happened that i...
If you have Windows XP then try this, for Windows 7 and Vista also the procedure is similar. If you have Vista or 7 then tell me I'll post the tutorial for that also.
  1. In Windows XP, click the Start button and select Control Panel.
  2. Click the Network and Internet Connections category.
  3. Note: If you are using Classic View, you will see the control panel icons instead of categories. Double-click the Network Connections icon.
  4. Click the Network Connections control panel icon.
  5. Double-click Local Area Connection, listed under LAN or High-Speed Internet.
  6. When the Local Area Connection Status window is displayed, click the Properties button.
  7. In the Local Area Connection Properties window, do the following:
    • Verify that the Internet Protocol (TCP/IP) box is checked.
    • Note: If your Ethernet adapter is not listed in the Connect using box, you need to install your adapter.
    • Click Internet Protocol (TCP/IP) once to highlight it and then click the Properties button.
  8. In the Internet Protocol (TCP/IP) Properties window, do the following:
    • Click Obtain an IP address automatically.
    • Click Obtain DNS server address automatically.
Apr 11, 2011 | Linksys Wireless-G WRT54G Router
Tip
Don't have a router and want to connect the two wireless computers with each...
Don't have a router and want to connect the two wireless computers with each other you need to set up both computers to an adhoc mode.If using Windows XP in your desktop computer follow the steps below to configure the wireless adapter to adhoc mode.
Go to control panel> Network Connections> Right click on wireless network then hit properties> Click on Wireless network Tab and removed everything under preferred networks. Click on Add button then type on the Network name SSID "Linksys". Remove the check for "The key is provided for me automatically" then enter the network key. Make sure that you enter 10 or 26 characters on the network key box. You can only set a network in using alphanumeric characters. You can create a network key by using numbers only,letters only or combination of numbers and letters from 0-9 or A-F characters. Put a check mark on the box says "This is a computer-to -computer (adhoc) network." Hit the ok button. Under the preferred networks highlight the SSID that you have set "Linksys"then hit the advance button. Click on computer to computer [adhoc]networks only then hit close and ok all the way out.
You need to do the same thing on the laptop where you have the installed a wireless adapter. SSID and network key should be the same on your network card. It should be set to adhoc as well.
Both computers must have static IP address. For the desktop computer you can set an IP address of 192.168.1.2 and the subnet mask is255.255.255.0. The laptop must have an IP address of 192.168.1.3 and the subnet mask is 255.255.255.0.
From the desktop computer, under network connections right click on wireless network connection then click on view available wireless network. Highlight Linksys then hit connect. Do the same thing on thel aptop. Once they are both connected try to ping each other and see if you will get reply. To ping the laptop from the desktop computer,follow the steps below:
a.On WinXP/2000:
Click Start > Run. On the Open field type cmd then hit OK. On the DOS prompt type ping 192.168.1.3 then hit enter.
b.On Win98/Me
Click Start > Run. On the Open field type command then hit OK. On the DOS prompt type ping 192.168.1.3 then hit enter.
Do the same thing on the laptop but instead of pinging the 192.168.1.3you need to ping the 192.168.1.2.
If you got replies it means that you are already communicating with each other.
If you are getting a low signal you may change the channel on the adapter. Follow the steps below on how to change the settings of the adapter:
For Windows XP and 2000
Right click on my computer properties>click on hardware>device manager>under network adapters right click on wireless-G notebook adapter then select properties>click on the Advance Tab then look channel then change it to 11. You may try to use other channels like1, 6, and 9.
For Windows 98 and ME
Click start>control panel>network>look for wireless-G notebook adapter with a green icon left beside it then double click on it>click on the Advance Tab then look for channel then change itto 11. You may try to use other channels like 1, 6, and 9.
Hope this help everyone.
on Feb 04, 2010 | Computers & Internet
Tip
HOW TO CONFIGURE WIRELESS ADAPTERS TO ADHOC MODE
From the desktop computer, under network connections right click on wireless network connection then click on view available wireless network. Highlight Linksys then hit connect. Do the same thing on the laptop. Once they are both connected try to ping each other and see if you will get reply. To ping the laptop from the desktop computer,follow the steps below:
a.On WinXP/2000:
b.On Win98/Me
Click start>control panel>network>look for wireless-G notebook adapter with a green icon left beside it then double click on it>click on the Advance Tab then look for channel then change it to 11. You may try to use other channels like 1, 6, and 9.
on Jan 26, 2010 | Computers & Internet
How to connect to internet. what are the instructions... because my router have a signal but it cant connect to internet
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop/Desktop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
You will also need to configure your browser for the internet
1. for Windows XP here is the setup :
http://www.microsoft.com/windowsxp/using/networking/default.mspx
2. For Windows 7
here is the setup instructions: getting online and networking
http://windows.microsoft.com/en-US/windows7/help/networking-e-mail-getting-online
http://windows.microsoft.com/en-US/windows7/View-and-connect-to-available-wireless-networks
Apr 07, 2011 | Computers & Internet
I have the Gateway 2wirewireless-G modem and router, how can i connect another desktop in another room to it?
1. Right-click the wireless network icon in the lower right corner of your screen, and then click View Available Wireless Networks. sammiller001_5.gif
2. The Wireless Network Connection window appears and displays available networks. If you don't see your network (should be named something like 2wire), click Refresh network list in the upper left corner. Click your network, and then click Connect in the lower right corner. sammiller001_7.gif
3. Windows XP prompts you to enter a key. The key should be one of the numbers printed on the bottom of your 2wire modem/router. sammiller001_8.gif
4. Windows XP will show its progress as it connects to your network. If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key-click Cancel and return to step 3. After you're connected, you can close the Wireless Network Connection window. Now you're ready to browse the internet!
Mar 05, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I have a connection to the network but no internet activity
check the ISP to verify the connection to your home
2.You will also need to configure your browser for the internet
a. for Windows XP here is the setup :
b. For Windows 7
4.. Check the laptop/desktop do ipconfig /all to see current IP addresses.
7. Move the laptop about 20ft away and try to log on to the internet.
Oct 07, 2010 | Acer Computers & Internet
Home networking Windows XP
Often this is a simple power management issue. On the laptop check the wireless properties and disable allow Windows to turn off this device to save power.
Apr 05, 2009 | Microsoft Windows XP Professional
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Apr 02, 2009 | Dell Vostro 2510 Laptop
Cannot Network printers on FIOS system
If both computers are connected to the router. Try turning off the firewall on both computers first. normally its firewalls blocking file and printer sharing that block the connection.
Mar 07, 2009 | Westell Wirespeed VersaLink...
I have a Compaq PC with Windows XP and the flat I've moved into has wireless broadband - how do I connect to it?
You can use a wireless network to share Internet access, files, printers, and more. Or you can use it to surf the Web while you're sitting on your couch or in your yard. Plus, it's easier to install than you think.
There are 4 steps to creating a wireless network:
1.
Choose your wireless equipment
2.
Connect your wireless router
3.
Configure your wireless router
4.
Connect your computers
For Windows XP users, Windows XP Service Pack 2 is not required for wireless networking, but it does make things much easier. Service Pack 2 also helps protect you against hackers, worms, and other Internet intruders.
If your computer does not have wireless network support built in, plug your network adapter into your USB port, and place the antenna on top of your computer (in the case of a desktop computer), or insert the network adapter into an empty PC card slot (in the case of a laptop). Windows XP will automatically detect the new adapter, and may prompt you to insert the CD that came with your adapter. The on-screen instructions will guide you through the configuration process.
Note: The steps below only apply if you're using Windows XP Service Pack 2. If you're running Windows XP and you don't have Service Pack 2 yet, plug your computer into your wireless router and download and install Windows XP Service Pack 2.
Windows XP should show an icon with a notification that says it has found a wireless network.
wireless_connected.gifFollow these steps to connect your computer to your wireless network:
1.
Right-click the wireless network icon in the lower-right corner of your screen, and then click View Available Wireless Networks. If you run into any problems, consult the documentation that came with your network adapter. Don't be afraid to call their tech support.
2.
The Wireless Network Connection window should appear and you should see your wireless network listed with the network name you chose. If you don't see your network, click Refresh network list in the upper-left corner. Click your network, and then click Connect in the lower-right corner.
wireless_chooseconnection.gif 3.
Windows XP prompts you to enter a key. Type the encryption key that you wrote down earlier in both the Network key and Confirm network key boxes, and then click Connect.
4.
Windows XP will show its progress as it connects to your network. After you're connected, you can now close the Wireless Network Connection window. You're done.
Note: If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key.
Nov 05, 2008 | Compaq Computers & Internet
Computers & Internet Logo
127 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
