My heat pump runs about 5 minutes, shuts down for 6 seconds then restarts
  • 43,501 Answers
Did you check yourair filter at the indoor unit. If you are not getting enough air through the unit it will do that. The othere thing that it could be is not so easy for you to fix. Your unit may be just a bit low on refrigerant. After running for a while the pressure drops too low and the low pressure switch cuts out. after a few seconds the pressure rises againa and it restarts. If the filter does not solve this then you need to get the unit serviced by a professional that is certified to handle refrigerants and can charge it for you.
Posted on Nov 14, 2009
Ac compressor runs 5 min shuts off then restarts 10 minutes later for another 5 min fan runs ok
Shutting down on safety. It's likely a pressure switch, possibly low pressure if fan is running.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 24, 2017 | Heating & Cooling
Tip
Backwashing A Sand Filter with A Push/Pull Slide Valve or Multiport Valve
Lots of people are first time pool owners and pool professionals forget to teach these "newbies" about the simplest aspects of pool ownership.
One of the biggest questions we receive from new homeowners is "How do I go about backwashing my sand filter exactly?"
It doesn't matter if you have a Hayward, Pentair, Jandy, Sta-Rite or any other number of Sand Filters on the market they all utilize the same basic valves for backwashing; a push/pull slide valve or a multiport valve.
To backwash with a multiport valve:
1) Shut off pump motor.
2) Press down on valve handle, rotate valve from FILTER to BACKWASH position.
3) Roll out any backwash hose or open any waste line valves.
4) Open air bleeder assembly on filter, and turn pump on.
5) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
6) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
7) Shut off pump motor and move multiport valve handle to RINSE position. Run on rinse for 15 - 25 seconds.
8) Shut off pump motor and move multiport valve handle to FILTER position.
9) Turn pump back on and note lower pressure.
10) Roll up backwash hose so the dogs use it as a chew toy.
To Backwash a sand filter with a slide valve:
1) Shut off pump motor, roll out backwash hose.
2) Twist to unlock plunger T-handle, push or pull(depending on manufaturer) the plunger 2" - 3".
3) Open air bleeder assembly on filter, and turn pump on.
4) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
5) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
6) Shut off pump motor and push T-handle back down into locked position.
7) Turn pump back on and note lower pressure.
8) Roll up backwash hose.
Now you are a backwash Guru!
More tips and tricks are available form The Ugly Pool Guy, www.WeFixUglyPools.com
on Dec 14, 2010 | Pool & Spa
Car starts then after about a minute it shuts down, restarts w/o problem then stalls again
I would think it is the fuel pump or relay . Turn key on an have someone by the gas tank to see if they can hear it running..It should run for about 5 seconds then shut off, if not heard I would guess the relay or pump is bad.Also a bad fuel filter can cause this.
Feb 29, 2016 | Cars & Trucks
Jaguar XJ 6 97 engine shuts down acts like its not getting gas engine will restart and 22 to 35 minutes will run for about 5 minutes then shut down again could this be a gas filter problem
Could very well be the fuel filter, try replacing it, aslo check for a cramped fuel line, if the problem persists, check the fuel pump
Sep 14, 2015 | Jaguar Cars & Trucks
Electric furnace/air handler short cycles
check that the replaced thermostat is the same temp degree setting of the last one
Dec 16, 2013 | Goodman Heating & Cooling
Shuts down after 5 minutes blinks green
Once the set shuts down, wait for the unit to stop blinking. Once it stops hold in the input and menu buttons for 5 seconds. The TV will then give you an error code. A 6-1 or a 1-8 error code would indicate a bad Color wheel. Which I think is the problem you have.
Jun 19, 2012 | Mitsubishi WD-65735 Television
My Flotec pump runs 5 seconds shuts off for 30
fully submerse pump in bucket of water, tilt to get all air bubles out,(keep hose off) plug in and it should work fine
Dec 02, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
3 year old Beckett AFG with Clean-Cut system. New inline filter new strainer, new nozzle, flame looks correct in pattern always. Flame does not sputter prior to shut-off. I did notice that when it shut off...
Called Beckett at 1-800-OIL-BURN and explained the problem. They told me that the solenoid on the oil pump (Clean Cut) was the cause. I purchased a new pump for $50 at the local plumbing supply and installed it. Problem solved.
Nov 20, 2008 | Heating & Cooling
Heating & Cooling Logo
270 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
