Question about Acer Computers & Internet
Cd stuck in my acer aspire L3600 which doesnt have a drawer
  • puvi83 Nov 14, 2009
    hi 1m karan my pc is aspire l3600 it is motherboard not working how to solve i thing not work isl ic in mother bord
The L3600 doesn't have an emergency hole so you need to disassemble the cover. MAKE SURE IT'S UNPLUGGED FROM THE AC POWER BEFORE GOING FURTHER! I would only suggest this if your warranty has run out. Remove the screw at the back under the warranty label then slide the top cover backwards and remove it. You will see 3 strap type black plastic catches towards the front of the computer, lift each one to unclip the front then lay it forward (it will still be attached by a cable, leave it connected). You should then see a metal catch under the CD/DVD Drive, lift it then slide the CD/DVD player out of it's housing, remove the Ribbon Cable at the back but make sure you know how to reconnect it. Remove the 3 small screws from the top and the two on the side holding the metal cover on top of the Drive then take the cover off, you should now be able to lift out the CD. Do the reverse of the above to reassemble your computer and there you go.
Posted on Jun 27, 2010
    New Friend:
  • 26 Answers
Every dvd/cd drive has a small hole in it, (besides the open or close button)
just put a small needle in it to open it and get the cd !
Posted on Nov 14, 2009
2 Suggested Answers
SOURCE: cd stuck in Acer Aspire L3600
Cd player won't open with the push of the button
Mechanical or electronical drawer?
Is the button stuck?
Oct 25, 2012 | Acer Aspire T135 PC Desktop
Stuck CD/DVD drive. Won't open
There is a hole on the front of the drive. Push an unbent paper clip into ththe hole and it should release the drawer.
Jul 04, 2012 | Acer Aspire X1300 (PV.SCC0X.002) PC...
I am wanting to change my broadband connection to a wireless connection to use with multiple connections. Does the Aspire L3600 have what is needed for a wireless connection? I can't find any details.
The Acer Aspire L3600 only comes with a wired network option in the original basic configuration. Some models had an added WLAN card filling the mini-card slot. The best way to check if the WLAN card is in your computer is to check the Device Manager. In Windows Vista, Click Start > Control Panel > System and Maintenance > Device Manager (except in the Classic view of the Control Panel). For the Classic View there is a direct link to the Device Manager on the Control Panel. For XP, it's Start > Control Panel > Performance and Maintenance > Administrative Tools > Computer Management > Device Manager (in Classic View, just skip the Performance and Maintenance step). If you upgraded to Win7, Start > Control Panel > Hardware and Sound > Devices and Printers > Device Manager. Scroll down the list to find any Wireless drivers that are installed.
(If you have one of the machines with Unix, check the specific documents. My Unix experience has always been wired.)
The Aspire L3600 specs are available here: http://support.acer.com/acerpanam/desktop/0000/Acer/AspireL3600/AspireL3600sp2.shtml .
I hope this helps.
Aug 10, 2011 | Acer Computers & Internet
I want to get driver tv tuner for acer aspire l3600
It's a problem for us to assume since you didn't mention the Operating System installed on the Acer Aspire... moreover there are two types of tv tuner card that comes with this model. I hope you'll not mind letting us know all these next time so that we can help you better.
If the operating system install on your system is Windows 7 the click the below links to download
Acer Aspire L3600 Connexant Tv Tuner driver for windows 7
Acer Aspire L3600 Yuan Tv Tuner driver for windows 7
Once you click the link, download will automatically begin. You'll need winrar or winzip to extract the files. Extract the files and run the setup or as per your convenience.
Acer Aspire L3600 Yuan Tv Tuner driver for windows vista
Currently, there's no drivers available for windows xp but you can still run it by using the "Device Manager" > "Update Drivers" wizard after extracting the windows vista drivers.
Good luck.
Thanks for using FixYa.
Jul 08, 2010 | Computers & Internet
My Acer l3600 Power Lead is faulty - is it
No. It's about 90-100 volts different.
Oct 29, 2009 | Acer Computers & Internet
Do i need the cables for the router?
To go Wireless on your desktop Acer Aspire L3600, you should consider buying an USB Wireless Adapter. It could be any brand as long have same frequency with your Netgear (i.e 2.4 Ghz/5.8 Ghz)
P.S.: If this information was helpful, please rate this solution.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Apr 01, 2009 | NetGear DG834G Router
Cd stuck in Acer Aspire L3600
If you look on the door of your cd drive next to the button you push to eject the cd there is a small hole.  This is essentially the ememrgency release.  Unfold a paper clip and push it straight into the hole.  Once it releases you will feel the paperclip pushing down on a button.  you will feel and hear the drawer release.
Jan 06, 2009 | Computers & Internet
Acer aspire 3610 lan driver
Go to control panel. Select Add hardware. Select that you connected the hardware. Find the device you need to update and tell Windows that your drivers are located on the desktop using the browse option.
Aug 21, 2008 | Acer Aspire 3610 Notebook
I have an acer aspire L3600 pc, and the dvd rom isnt working, it isnt even showing up on the Computer page, and under device manager it just says device not working (code 10) and when i press find...
Try to remove it under device manager and restart the laptop. If the same problem occurs, the driver for the CD rom isn't installed yet. Better call the Acer tech support for possible part replacement.
Jul 24, 2008 | Acer Computers & Internet
Keyboard touchpad not working
y-ran 77 cordless keyboard...doesnt work with the l3600 multimedia desktop..it cannot recognize the said hardware...you need to use standard keyboard and manually install the driver for your y-ran77 cordless keyboard
Jan 13, 2008 | Computers & Internet
Computers & Internet Logo
660 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
