Question about Whirlpool GEW9250P Electric Dryer
How do I connect a 4 wire cord to a whirlpool dryer - there is no grounding strap. There is a green grounding wire connected on the bulkhead. Can I connect the green wire from the 4 wire cord to this green ground wire?
  • Whirlpool Master
  • 43,501 Answers
Yes, infact you can connect the green wire anywhere to the body of the dryer. That is a safety ground that will or is supposed to, take away the risk of getting shocked if one of the hot wires would short tothe body of the dryer anywhere.
Posted on Nov 14, 2009
Testimonial: "great - i was puzzled as what i should do with the green grounding wire attached to the body of the dryer - i diden'think i should leave it hanging. "
I have estate dryer by whirlpool that came with a 3 prong cord and I changed it 4 prong because my outlet is ,4 and on my dryer I dont have a bonding strap but a green ground wire connected to the middle...
no,you need to connect the green wire to any metallic part of the dryer,even if the white wire on the neutral terminal has a bonding strap from this terminal to the metallic dryer case as you should never connect more than one wire under any type of terminal unless otherwise specified by the manufacturer
Apr 20, 2012 | Whirlpool Dryers
Tip
Electric Dryer power connections
The supply cord on an electric dryer can be 3 wire or 4 wire,
depending on the existing receptacle. All new construction
must have 4 wire receptacles for dryer hook ups.
At the back of the dryer you will see a set of three
terminals. The outside terminals are for connecting the
outside wires of the cord. In a 4wire hook up, the center
terminal is for the center, insulated, white wire, the
neutral. The bare copper or green wire of the 4wire cord
gets connected above these terminals to a lug or stud on
the body of the dryer. There may be a strap there. For a
4wire cord connection this strap is connected to the stud
only.
The change for a 3wire connection is that the center green
wire of the 3wire cord connects to the center of the three
power terminals along with the grounding strap from the
dryer body above.
on May 05, 2010 | Washing Machines
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 13, 2011 | Kenmore 700 6972 Dryer
Eletric cord installation
The supply cord on a dryer can be 3 wire or 4 wire, depending on the existing receptacle. All new construction must have 4 wire receptacles for dryer hook ups.
At the back of the dryer you will see a set of three terminals. The outside terminals are for connecting the outside wires of the cord. In a 4wire hook up, the center terminal is for the center, insulated, white wire, the neutral. The bare copper or green wire of the 4wire cord gets connected above these terminals to a lug or stud on the body of the dryer. There may be a strap there. For a 4wire cord connection this strap is connected to the stud only.
The change for a 3wire connection is that the center green wire of the 3wire cord connects to the center of the three power terminals along with the grounding strap from the dryer body above.
Dec 05, 2009 | KitchenAid KEHS01P Electric Dryer
I have a new 4 prong plug to replace a old 3 prong on dryer
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
Front loader whirlpool dryer (04') 3-prong cord; 4-prong outlet..
You'll need to get a new 4 prong cable. Connect wires as color coded now and connect the green to the frame.
Jul 16, 2009 | Whirlpool GEW9250P Electric Dryer
How to install a 4 wire cord on a 3 wire dryer
This is a common question we receive and a common mistake most every general contractor makes that we work with. With a 3-wire system your neutral terminal will have a copper clad or aluminum strap or green wire connected between it and the frame. You need to remove this when changing to a 4-wire cord.
Terminate the wires from your new 4-wire cord as black to black terminal, white to white terminal, red to red terminal and green to ground screw on frame. This is the other end of that strap or green wire you need to remove from the white (neutral) terminal.
When changing to a 4-wire cord it is very important to remove the strap or wire that connects between the white terminal and the dryer’s frame. If you do not remove this, your neutral or grounded conductor will allow electricity to flow through your dryer’s frame and shock you each time you touch your dryer.
Jul 15, 2009 | GE DCSR483EA Electric Dryer
Prongs on dryer
Take old cord off. Remove wire or ground strap connecting dyer frame to center (nutral) terminal. White wire goes to center terminal. Green wire to frame (ground) Red and Black wires go to two remaining terminal, order really won't matter.
Sep 28, 2008 | Whirlpool LER5636P Electric Dryer
Whirl pool dryer
L1 Hot= Left terminal (Red Wire) ...... L2 Hot= Right side terminal (Black Wire) .......... Netural = Center terminal (White Wire) .................. Ground is Green connect to the cabniet of the unit and remove the connection strap from the center terminal on thje dryer wiring block..
Feb 22, 2008 | Kitchen Ranges
Whirlpool GEW9250P Electric Dryer Logo
127 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
