Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
The kenmore won't keep the fridge or the freezer cold and now its outer left panel gets hot when it runs and the heat extends all the way around to the doors. It has been running almost all the time, hardly ever shut off.
  • Kenmore Master
  • 1,606 Answers
Check the fan in the back of the refrig , which cools the compressor , for operation or blade obstruction . If not turning to keep the compressor cool , replace the fan motor .
Posted on Nov 14, 2009
The beam in middle of refridgerator where both doors rest against while closed is too hot to touch
Is the cooling fan for the compressor working? There is a coil of the condenser line that runs around the freezer side. This will get hot but the cold freezer side keeps it form not getting too hot. It could get very warm if the freezer is not cold yet.
Sep 10, 2014 | Kenmore Refrigerators
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
My freezer frosted over everything because the door was not shut tight and now it will not clear.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
Jun 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
I have a kenmore upright freezer and it runs continuosly, no freezing issues. It is located in my garage and the temperature is extremely hot. Should my freezer still cycle or could it be my thermostat or...
You may have the cold control set lower than necessary. Make sure the condenser panel is not coated with dust/dirt. If the outer walls of the freezer are the heat-release surfaces, make sure that nothing is on top of, or stacked next to, the outer case that could block heat release. Hope this helps!
Aug 11, 2010 | Microwave Ovens
Kenmore 253 9280413 freezer keeps running
The coils are embedded in the outer walls and will make the cabinet feel warm outside when the compressor is running. It needs about 4 inches of clear air space around all the outer case walls to properly get rid of its heat. If you have items stored too close to the outer walls they will act as insulation to keep heat from being dissipated. This can cause long run times.
A unit that has lost freon gas due to leakage, while unlikely, can also extend run times. Normal temperature should be about Zero when the dial is set to halfway.
Good Luck
Sep 15, 2009 | Freezers
Vertical surface on the sides towards the front hot
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath
Aug 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore fridge not getting cold
first thing to heck would be the condenser fan motor which is located int the compressor compartment pull the refrig away form the wall remove cardboard cover and inspect the fan motor that you will see. check for obstruction or if the fan motor is seized. if this motor fails it will cause the compressor to run extremely hot then shut off on internal motor protector. if you determine the motor is bad you can place a house fan behind unit blowing on compressor area to keep unit working until you get it repaired.
Thanks Peyton
Feb 17, 2009 | Kenmore 64522 Top Freezer Refrigerator
Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Jun 01, 2008 | Refrigerators
External Surfaces of Fridge/Freezer are hot
That is normal, refrigerators work by removing the heat from the storage area, thus making it cold. This heat has to go somewhere. Most of it is blown out the back but some escapes through the sides of the fridge.
Dec 28, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
119 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
