Question about Euro-Pro Shark GI490 Iron
Shark Euro-Pro G1490
The iron was working then shut off like it sat idle for a while but I was still using it. The button to increase temp back to "max" won't move past the On light now so I'm not sure what's wrong with it.
  • 5 more comments
  • Willieslc1 Feb 19, 2008
    G-1490, power indicater ligh on, no heat on any setting. I removed the four screws on the back plate but it won't come off. Are there screws under the two rubber bumpers?
    slcwillie1@ameritech.net
  • Anonymous May 11, 2008
    cannot get my shark g1490 to go past the on button
  • kmilicia Jun 25, 2008
    In the middle of ironing the iron shuts off and will not turn back on.
  • Anonymous Aug 02, 2008
    lost power
  • Anonymous Jan 27, 2009
    Does the same thing. I pulled out the plug and then pushed it back in and it started again. Then unexpectedly shut off. Who repairs these????
  • lemoninMI Feb 09, 2009
    I have the same problem, it shuts off like it's sitting idle, and I have to unplug it and start over. I hate this iron, it's a lemon, would never buy another one !!!!!!!!!!
  • Anonymous Feb 09, 2009
    WHile ironing on high heat, the iron turns itself off for no reason.
    I have to unplug it and then replug after 30 seconds to get it to high
    heat again. Then it will AGAIN turn itself off in the midst of ironing.
    Most annoying.
Our G1490 quit after one year. Just won't come on. Period. I can't get it to open after removing the back screws either.
Posted on Apr 26, 2008
I took my euro steam iron model 4488 apart as it doesn't stay on. I have to mess with the revolving button on the back for it to get a connection with the little contacts that this switch seems to control. I took the one center screw off and at both ends at the bottom of the plastic backing I had to pry it gently away from where it clips in. I used a slender flat screwdriver or you can use a butter knife. Hope yours opens the same way.
jimbo
Posted on May 23, 2008
I have the same iron.When my iron shuts off automatically,I have to unplug it for about one minute, plug it back in and then I can change the heat settings to get it going again.
Posted on May 19, 2008
Hi the auto shut of light came on and I cannot get the iron to work, keep switching off and on over the past week to no avail.
It's a safety feature that we can do without. But keeping the Iron moving will keep it hot.
May 19, 2016 | Irons
Iron shuts off automatically when using
There is a fuse link and an over temp disc in these ,if the disc is not working correctly it tells the iron to open the disc until it cools to a lower safer temp then resets.
Apr 19, 2014 | Irons
Black and decker all temp steam iron stopped working while ironing and now it won't turn on.
please see the cause and fix it:
a) tank or ports clogged. Dissasembly and inspect replace tank and seal if badly clogged. Emptying iron after each use allow heats to evaporate remaining water and helps prevent clooging. Inspect valve and linkage: clean or replace as necessary
GOD BLESS YOU
Jul 22, 2012 | Applica Black And Decker All Temp Steam...
Iron keep shutting off while ironing
The cord is broken...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 21, 2010 | Black & Decker Steam Xpress AS250 Iron...
Auto shut off how to turn back on?
The automatic shut off is a protective device to let the iron cool down when not in use. Normally, if you pick the iron up and sit it down on the board or fabric, the iron will "sense" the motion and click back on to the heating cycle. To turn the iron off, just move the dial to the lowest position, or OFF and or unplug it from the outlet. If left unattended for a while, and when picking it back up to iron, if it does not come back on then you may need to increase the heat setting, move the dial a little, till you see the power light come back on. This is a safety item, and a good one, given the hectic lifestyles we have now, and having busy lives. If we forget to shut the iron off, it does it for itself after a period of non-use. No more trips to the store or wherever and remembering "I forgot to unplug/turn-off the iron I was using". Still, it's best to unplug and or turn it off when not in use. I prefer unplugging, so that it does not be a "vampire device" drawing even little amounts of current when not in use. And it's safest when unplugged and cool.
Sep 26, 2009 | Irons
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Aug 14, 2009 | Euro-Pro Shark GI490 Iron
How to use the calc-clean button
Calc-Clean function
The Calc-Clean function removes scale and impurities.
To do so, set the steam control to position '0', set the temperature dial to 'MAX', and fill water tank up to the 'MAX' level. Then heat up the iron until the pilot light on the handgrip goes out.
Remove the mains plug from the wall socket and hold the iron horizontally over the sink. Then press and hold down the 'CALC CLEAN' button.
Move the iron forwards and backwards while boiling water/steam squirt from the holes in the soleplate to wash away impurities/scales.
When the water tank is empty, heat up the iron to dry it.
Finally move the iron to and fro on a piece of cloth to dry the soleplate. Repeat the process if necessary
May 05, 2009 | Philips HI-296 Iron
Tefal 400 iron auto shut-off light stays on
TEFAL B.800
AUTO LIGHT ON,BUT NOT TEMP LIGHT.NOT HEATING UP.HAD BEEN USING BUT UNPLUGED WHILE I GOT MOE IRIONING.
Jan 31, 2008 | Irons
Cleaning a self cleaning iron
Fill the Iron with water but keep the water level below the max line. Plug in the iron and set the temp to 6 and stand iron on it's heel and allow to heat for 3 mins. Now unplug the iron and take it to a sink move and Hold the variable steam dial in the CLEAN position. There may be some hissing and spitting while cleaning so be careful. Continue to hold the dial in the clean position until all the water has emptied. If necessary rock side to side and back to front to get all the water out.When finished release the steam dial plug in the iron and heat for about 2 mins to dry out the remaining water and unplug.
May 22, 2007 | Black & Decker D2030 Iron
Dial stops at "silk."
if the iron is under warranty send it back to the company.if not take down the iron it has a broken part that is stopping it from moving properly.good luck.
Apr 02, 2007 | Rowenta Perfect Iron
Euro-Pro Shark GI490 Iron Logo
815 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
