Question about Sharp Aquos LC-15S1U-S 15 in. EDTV-Ready LCD Television
A large black box appears in the center of my Sharp Aquos LCD tv. Picture around it is fine, sound, etc. all fine. Is it time for a new TV?
  • 405 Answers
Keep pressing CC button on your remote control until you see CC/TEXT OFF.
Posted on Nov 14, 2009
Testimonial: "The CC was definitely the problem!! Appreciate your help....wow...this site is great! Thanks agai!"
  • Matt h Oct 25, 2014
    Thank you, thought i was dealing with a parental control issue.
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Sharp Aquos LC-C4654U The TV blacks out frequently. The blackouts last aprox. 1-2 sec and when the picture reappears, the blue box appears in the top right corner (just like when the tv is initially...
Good day!!! That problem is cause of faulty capacitors on the power supply... just look at the actual image of it through visual check if the capacitors look like leak/bulged on top you need to replace it to end that problem... hope it helps... \thanks for using fixya..
Sep 13, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
I have a Sharp AQUOS LC-32D47UA 32", black box
Press the cc button on your remote control. You want cc to be off. Play around with the cc button to become comfortable. Press it over and over again. Observed that a different closed captioning option appears on your screen each time you press the cc button. Now press cc and when it says cc off do not press the button anymore.
Jan 23, 2011 | Sharp LC-32SB21U 32 in. LCD TV
We have a new 46" Sharp Aquos with a "snowy"
sounds like you have a cable connection problem make sure your tv is set to dtv signal in the menu screen. when you scan the channels should be displayed as 12.1 or 8.2 not just a single number if the digital channels are programmed correctly then change the cable coming into the tv from antenna making sure that it isnot crossing any power wires good luck and hope that i helped
Nov 07, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Black square on screen that covers half the picture appeared on my 42" sharp aquos tv.
sounds like you might have PIP turned one (picture in picture) .. if there is no input hooked up for the PIP . you will just get a black screen ... you should be able to move that PIP around and change its size .. indeed turn it off .. look for a menu item called PIP .. select PIP off ..
Nov 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture but no sound
main pcb needs to be cleaned were audio ic is. there is black gunk
Jun 01, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
Can't retune sharp aquos lcd tv
This is the best place that's near the manual you need.
They have the LC32D44E manuals, but not the "BK" at the end. I think the "BK" just means BLACK.
But, I think it will work for your TV.
Here's the link:
http://www.sharp.co.uk/page/downloaddrivermanuals#
Click on the "Sharp Europe - Manuals and Download "
Then, Operation Manuals
Then, LCD-TV
Then, put your TV model# for the search.
Apr 21, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
LCDTV - Picture problem
Do the lines only appear on the Cable box input? It maybe be a problem with your cable. Try to isolate the problem.
Do you see the lines on all sources such as your DVD player as well? If you press the MENU button on the Sharp remote, do the lines go through the menu as well? If yes, it is most likely a TV problem.
A bunch of lines sounds like it is most likely a problem with the connection with the LVDS cable, if not that, then a defective main board.
There isn't really much you can do about it now.
Since the TV is less than a year old, I suggest calling Sharp to locate a local authorized service center.
Mar 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos
Shine a bright light on the screen, do you see the image (but very very very dark)? If so, its either a bad inverter or lamps, which are only sold with the LCD panel as an assembly, which is very expensive (more than the TV is worth).
Mar 09, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC-15S1U-S 15 in. EDTV-Ready LCD Television Logo
119 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
