Question about Zanussi ZWF1430W Front Load Washer
The machine overflows water - Zanussi ZWF1430W Front Load Washer
  • 555 Answers
This is caused by a faulty pressure switch or the hose from the drum to the pressure switch is not fixed property.
Posted on Nov 15, 2009
My Bosch classixx washing machine is overflowing
Bad water pressure switch or bad water inlet valve? does it have or leak water in the tub when not in use? ( inlet valve) sometimes the pressure switch tube has a hole or blockage in it and will not have the pressure needed to open diaphram and go into wash cycle and it may overflow
Mar 09, 2015 | Bosch Washing Machines
How do i stop machine from filling up with water till it overflows
Sounds like you need to replace the water setting switch.
Oct 13, 2014 | GE WJSR2070B Top Load Washer
Amana washer
The level sensor may have failed.
Mar 08, 2018 | Washing Machines
Washing machine overflow on stackable washing machine
Thanks for choosing FixYa and welcome. If you have water overflowing, you need to check your water level switch. It may be bad or it may not be getting power. It controls the water level.
May 01, 2011 | Washing Machines
The water drains too fast and overflows
Here is a tip that will help you with that problem...
Changing or Upgrading your Old Washing Machine
http://www.fixya.com/support/r4696582-changing_or_upgrading_old_washing_machin
heatman101
May 14, 2010 | Kenmore 23822 Top Load Washer
The belt broke, it was replaced, but afterwards its overflows,
If water is overflowing check the small plastic line going from the bottom of the tank to the water level switch. It could be disconected. To check the water vales, set machine to fill, while the water is running into the tub unplug the power cord from the wall, the water should stop, if not the water valve is faulty.
Oct 11, 2009 | Speed Queen Washing Machines
Admiral top loading washing machine overflow water
Most likely the water level sensor - check www.repairclinic.com
Jul 31, 2009 | Washing Machines
Overflow problem
Unplug machine and remove the water probe it is probably not reading the water level.
If it is leaking without the machine being plug in to power then the inlet solenoid is damaged.
Jun 01, 2009 | Bunn U3 / SS 20500-0000 Coffee Maker
Zanussi ZWF1430W Front Load Washer Logo
57 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
