Question about Canon PIXMA MP760 All-In-One InkJet Printer
When I turn on printer I get a sound like a machine gun. Error message says "Error, Turn the machine off and on.
  • 1 more comment
  • kleinandcomp Nov 14, 2009
    Tried that several times. Print head will not engage. Tried removing print head and replacing and still no luck.
    Tried moving head from side to side. Removed and replaced print head. Still same problem.
    I discovered where the sound was coming from two gears on the right side of the printer were not engaging when the printer was turned on. There is a spring loaded lever that engages these gears when the printer is turned on. Apparently ink had leaked from a faulty cartridge and had deposited on the lever and somehow fouled its engageing the gears. I cleaned up as much of the ink as I could with a tissue and alcohol dipped Q-tips. When I turned the machine back on the head engaged. Thanks for steering me in the right direction. Your explanation led me to view the mechanism to identify the problem.
  • Canon Master
  • 1,113 Answers
Hi I think the noise you are hearing is the head or carriage that moves up and down a silver bar trying to unsuccessfully move, turn the power off and see if you can manually move the carriage to the center, don't force it or pull it via cables. If you can move it check either side for paper smashed up against printer wall. Check for any obstruction in the carriage area, ensure all cartridges are secure.
Sometimes even after all this is checked and cleared the problem still exists, this is due to what is called an encoder strip getting stained or dirty. A encoder strip tells the printer where it is along the carriage and if this thin plastic strip that runs parr-ell to the shiny silver carriage bar, gets ink on it the printer cant read the spaces between the tiny lines that are printed on it, make sure this encoder strip (can be a wheel on some models) is spotless, I use metho and rag very gently on it, sometimes the ink stains the plastic beyond cleaning and needs to be replaced, mind you the cost of repairing any ink jet thes days is uneconomical.
hope this helps with your issue.
Cheers
Posted on Nov 14, 2009
    President:
  • 3,278 Answers
Hello.
Sounds like something is stuck, like the print head.
Give this a try: Power off the printer. Open the top of the printer and move the print head from the left to the right. Power the printer on, again.
Hope this helps.
ERROR SC682-223 ? Also, Error for CPU cyan at starting.
Memory chip at TD sensor: Communication error
Retry of memory chip communication fails three times after the
machine has detected the memory chip communication error.
?? Damaged memory chip data
?? Disconnected inter face
?? No memory chip on the development unit
?? Noise
Replace the PCU.
Jan 06, 2016 | Ricoh Aficio SP C820DN Laser Printer
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
PAPER JAM MESSAGE APPEARS WHEN THERE IS NO PAPER JAM
Please follow the directions below to clear the paper jam error orincase there is one somewhere.
Turn off the Printer. Remove the drum and toner from the front cover. Remove the toner from the drum. Look inside machine incase of possible paper jam. Open back cover and paper tray incase of jam. Close all doors and put toner and drum back in machine. Turn on the printer, and see if the error message is gone.
Apr 04, 2010 | Brother MFC 7420 All-In-One Laser Printer
Printer made machine gun noise. will not print.
The print head is stuck - something has jammed it and the noise you are hearing is the carriage for the print head. Open the top and try moving the head by head sideways to see what has jammed it.
Aug 31, 2009 | Canon PIXMA MP760 All-In-One InkJet...
CHECK PRINTER ##330 flashing message
From the message board archives:
Error codes:
## 322 Fuser not heating (Usually Bad Fuser Module)
## 323 Laser Beam detect error
## 324 Laser scanner motor rotation incorrect
## 325 Fan motor inop
## 330 Power Supply (Replace/Repair)
You must turn on error management to have the machine display error codes, otherwise it will just say "CHECK PRINTER".
To turn error management on, enter the following: Press Data registration, #, Set, 00000011, set, stop. Now after the "check printer" message there should be one of the error codes above.
Supposedly, Nation-Wide Repair Service fixes the bad power supplies for $45.00. They can be reached at 800-798-1814. You can also buy one for $148.00 from www.loyal.net I hear. The proper replacement power supply part number for both the LC7000 and LC7500 is HH3-5278 so I am told.
Aug 04, 2009 | Canon LaserCLASS 7500 Plain Paper Fax
Error message on c.itoh ci3500 printer reads a11. What does it mean?
What is the error message?, not clear on the make and model either, be specific please.
Apr 21, 2009 | Citoh Office Equipment & Supplies
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Error Message: "Contact Your Dealer Printer Error E04-01" - What does that mean?
you can try a LBP fuser reset and LBP error log clear . this might fix the problem your having.
Mar 14, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
79 people viewed this question
old marine
old marine
