Question about AT&T Siemens S46 GSM Cellular Phone
I have a new Siemens RDH10RF heater thermostat but seem to have misplaced the instructions.How can I conected them too power?
  • Anonymous Mar 12, 2014
    Reached temperature 1or2 above turns boiler off after time temperature still above set point buy 1or2 but heating comes on but not always
    Heating comes on when way above set point
Siemens, RDH10RF, thermostat, not turning my heating on
You likely lost the settings when the batteries died. Sound like you have to reprogram the tstat as to your application. Like switch heat type FROM GAS to ELECTRIC.
Dec 18, 2016 | Heating & Cooling
Siemens thermostat rdh10rf
If this is battery operated it could be the batteries at fault.
Apr 17, 2014 | Heating & Cooling
Siemens se25m275gb
Dishwashers tend to get stuck on wash cycle if the water temperature is not reaching the level the wash program expects it to reach. This could be due to faulty heater or thermostat or both.
One test is to run the dishwasher on a rinse cycle (normal water temperature) and see if it completes it.
Refer this site for location and cost of heater and thermostat
https://www.buyspares.co.uk/siemens/se25m275gb80/catalogue.pl?path=463858:496324,183865:463966&model_ref=185092
Apr 12, 2014 | Siemens Dishwashers
When you turn on the heater it does not light. piolet light is on. if I conect the two post connected to thermostat the burner will light, I disconnect the two and it stays lighted. If I turn off the heat...
Hello my name is Heath it will be my pleasure to assist you. The problem then seems to be with the thermostat. If you have an ohm meter you can verify by attaching the ohm meter to the thermostat and turning it up if there is resistance when the thermostat is turned up then the thermostat is okay if the resistance is infinite then the thermostat is not working.
Oct 08, 2010 | Williams 3003622 Ceramic Wall Mounted...
I have 240 volts at thermostat and conection on the tank but nothing at the bottom element. no hot water either
Thermostat may be bad and not suppling power to lower thermostat and element.
Sounds like Thermostat not working properly if no power there..
Do you have power to top element and power going into top of bottom thermostat if it has one.
May 12, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I'm new handyman
from the thermostat you have R and W, R goes to the Transformer and W goes to the Gas Valve if you have a 24 volt system
Jan 22, 2009 | Empire DV-215 Direct Vent Natural Gas...
WHERE TO CONECT THE 2 WIRES TO THE NEW THERMOSTAT
Connect one to Red, R or Rh.
Connect the other to White or W.
Jan 09, 2009 | Honeywell Programmable Thermostat Heater
Baseboard electric heater installed properly, yet won't work.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
Nov 22, 2008 | Fahrenheat Electric Convector Baseboard...
AT&T Siemens S46 GSM Cellular Phone Logo
492 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
