Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
The press here lock light is on but I can not get the other buttons to work. There is nothing in the way so it does not close properly
Press and hold for 3 seconds
Posted on Nov 14, 2009
My handle is broke, but closes just fine. I can't select a type of wash. It's stuck where its at. It says hold button for 3 seconds to unlock but still nothing. Whats the issue?
Hello. From what you describe, you have multiple issues at work here. I need the model number of the washer to help you most accurately for exploded diagrams, diagnostic routines, and part numbers. If the door lock mechanism is still working, then the only part that needs replacing is the plastic handle--there is an internal switch that MUST close when the door is shut thereby telling the main control board it's okay to start the cycle. If that switch isn't closed, you can choose options as much as you want but the washer will NEVER start. It's an important safety feature. Next, the control lock light is lit--that tells you that nothing will work on the panel until the lock is disabled. You must press and hold the button until the light goes out--USUALLY 3-4 seconds more or less. If the light remains lit no matter what you do, then there is an issue with the main control board. Have you had a power outage recently?(3-4 weeks prior or anytime in-between) They are NOTORIOUS for damaging the digital boards in modern appliances. And, it could have been a "brown out" where the power just blinks that does it. Also, the button control panel might be defective--the soft-touch buttons can become shorted internally--the computer won't let anything happen because it thinks you're pressing a button and haven't let it go yet.
Oct 04, 2015 | Washing Machines
I have a Liftmaster HBW077. The opener operates from the wall mounted button. There are two remotes and neither will open the door. The green light on the WALL button is blinking. There is nothing that...
Check to see if the wall control has 3 buttons. If it does one of them is the lock button and you need to press and hold this for 3 seconds. The lock button has an icon of a padlock. If you do not have a 3 button wall control programming the remotes should cure it.
Dec 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Frigidaire dishwasher will not start.
WOW! This same thing is happening to me tonight too! The Lock button is lit for me but not the "heat dry". Looking forward to reading what this problem is.
Nov 18, 2009 | Frigidaire FDB1502RG Built-in Dishwasher
Would not wash
It sounds like the child lock is on. Is the light on when the door is closed and nothing is pressed? If so hold the lock button until the light turns off. If you do not have a lock button, try the heated dry button or consult the manual to find out which button toggles the child lock.
Good luck.
Feb 21, 2009 | Kenmore Dishwashers
Kenmore Dishwasher 665 15777990
Good luck.
GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Oct 22, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Hardbody 2002
get into the truck and close and lock the door. place the key in and out of the ignition cylinder about six times(not too fast or slow) until you see the hazzard lights flash twice. then turn the key to the acc. position and then press the lock button on the remote(if lock doesn't work you can push another button on the remote). if the hazzard lights flash it is now programmed. then turn the key to off and pull it out and then unlock the door and open and close it. now test the remote.
Jul 21, 2008 | 1990 Nissan Hardbody King Cab
Washer won't start/lights on
ok try first to make sure the detergent drawer is closed tight if its not will stop washer is the door locked some times you have to close them firmly make sure the lock light is on hit pause cancel twice then try washer
Dec 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
