Question about Gaggia Syncrony Espresso Machine
THE TEMPERATURE ON THE EXPRESSO AND STEAMED MILK IS warm but not hot. Any thoughts?
  • 1,089 Answers
Hi
There are a couple of things.
Your building up scale inside the boiler. DESCALE
Your steam boiler is dying. REPLACE
You can do this your self if your handy.
Posted on Nov 14, 2009
Delonghi EC702
Even semi skimmed milk with froth if hot enough. Check the steam temperature, you may need to blow steam through the milk for longer.
Mar 06, 2014 | Coffee Makers & Espresso Machines
Water shoots out of steam valve and can't make espresso
Samantha,
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
Nov 21, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
What does it mean by 1/3 expresso, 1/3 steam milk and 1/3 frothed milk? 1/3 cup...1/3 teaspoon??????? New to this. what are measurements
i'm sure it is referring to total volume, that being 1/3 of your total is expresso, 1/3 of total volume is steamed milk, etc etc. it is not really a measurement but a ratio of the different components of the drink you are making, example,,, chocolate milk might be 1/4 chocolate and 3/4 milk. if you were making it it would take 1/4 of the "mug" you ar using filled with chocolate, the rest or 3/4 filled with milk. make sense?
Jan 17, 2011 | Microwave Ovens
Milk is not dispensing hot enough from saeco Primea Cappuccino Touch Plus coffee maker?? any ideas
I have the same problem, my wife complain me everyday, now we use our coiffe machine 90$ from sears it`s still better then this 3200$....
Apr 25, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Change milk temperature (milk not warm enough)
It all depends in the Cappuccinotore(milk frotting part) Change a new one or
Think of a way to reduce the suction tube diameter smaller... to get milk and steam mixture correct.
Jul 08, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Primea ring hot milk
if you go in the menu there a temperature setting for that machine pierre
Jan 11, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Steamed milk
I've just taken delivery of an S9 and my lattes were lukewarm too. What you have to do is move the dial on the steamer to the 3 o clock position. See http://cdn2.libsyn.com/coffeegeek/jura_frothxpress.mov?nvb=20081110133816&nva=20081111133816&t=018ee7ad85c33f422c6a5 . Latte I just made was piping hot. If that doesn't fix it, try the Products settings. If still lukewarm I think you should contact your dealer, maybe you have a duff machine.
Oct 18, 2008 | Jura Capresso Impressa X90 Espresso...
Steamer on gaggia titanium
a. Possible air in the system. Switch to hot water iso steam, let warm water pas for a minute by turning the knob fully open. Stop tapping warm water (close the knob) and switch the machine to steam iso water. Try to get the steam by fully opening the knob (pump should start running).
b. Solidified milk in the system blocking internal tubes. To avoid this always purge the system (shortly open the steam to an empty cup or a towel) after you steamed milk to avoid milk being sucked back into the system due to condensation of steam (this creates a vacuum and reverse flow). To resolve the blocked tubing: clean the nozzle and try flushing the system (tapping warm water).
Aug 24, 2008 | Gaggia Titanium Espresso Machine
Primea ring - milk not hot
Hello!!
Okay! Looks like many of you out there has the same problem, whit the milk temerature (not me i never had).
But there is a service menu on primea touch plus series.
Im from Sweden but i will try my best to explain how to enter the menu. First of all !!MUST!! write down off parameters before changing any thing!!!! It is possible to set the grinder to grin more coffie for each cup. I think the factory setting is 85 Aroma impulse. It is possible to change that for you type of coffie beans that you use, i will diff from bean to bean.
Okay, to enter the menus you have to turn you machines off.
Now turn it on !!!!!EXACTLY!!!!! when the display lights up press your display in the following order ALWAYS IN THE CORNERS (you will not see any icons were you have to touch on you display) RIGHT LOWER CORNER, LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER.
To enter the second service menu, do as i explained before but use this "CODE" instead. LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER, RIGHT LOWER CORNER. This is it! Hope i could help you! Remeber to write down before doing any changes! DO NOT ERASE ANY FAULT CODES YOU SERVICE CENTER WILL FIND THAT INFORMATION VERY IMPORTANT!!!!!
Dont say that it didnt work, it will it´s a huge matter of timing!!!! IT WILL WORK!!!!
Let me know some results please!!
Mar 04, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Gaggia Syncrony Espresso Machine Logo
82 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
