Question about Gateway Computers & Internet
I replaced ram in a MX6421.The unit will only power up with one 1GB. When the second GB is installed the unit comes on but the screen remains black. I'm using PNY 1G DDR PC2700 333MHz.
    Master:
  • Gateway Master
  • 956 Answers
My advice is power up with working ram, go to www.offtek.co.uk
There they do scans of your ram, give you a read out and recommendations. Free, chips you buy!
If poss, try with both in, if not good chance not compatible or dud?
Hope this helps.
Posted on Nov 14, 2009
Hp a1340 new ram windows freezes
I would recommend a fresh install of Windows. Back everything up with the 1GB installed, turn off PC, install the second stick of RAM and then go straight to installing Windows.
Feb 27, 2014 | HP Pavilion a1340n PC Desktop
New memory nx6110
Did you remove and replace 1 or 2 RAM modules? There are 2 modules installed. One is internal and one is external. Both MUST BE OF THE SAME DENSITY OR THE LAPTOP WILL NOT WORK. You will need a second 1GB RAM Module, then use the link below to download the service manual for your laptop. Accessing the internal RAM module is fairly easy...follow the directions and you will have not problems. You CAN remove the internal one and operate the device on the single 1GB module, but I would recommend if you do that, you put the 1GB module in the internal slot. Then later, if you wish, you can add more RAM without additional disassembly. By doing this you will at least double your RAM from the 512MB you had to !GB. You can double it again with the second RAM Module to 2GB later.
.GO Here. Find Remove/Replace procedure for Internal Memory Module.
Nov 10, 2013 | HP Compaq nx6110 PC Laptop
My dell mini 1012 is not giving display and i can hear some beep i changed ram but same condition
I feel the problem is with the RAM.
Please use 1GB atleast, DDR 2 SDRAM and check your system.
Apr 12, 2011 | Dell Inspiron Mini 1012 Netbook...
Installed RAM and now monitor has no display. I
The splash screen with the LG Flatron logo is the monitor's splash screen not the PCs.
The machine is NOT booting up the splash screen is the monitor coming on.
Remove the 1Gb stick an see if the machine performs normally.
If it does then power it off, remove the power cord and CAREFULLY reinstall the new stick.
If it fails to boot you may have a defective memory module.
If the machine fails to boot with the new stick removed make sure you have the original memory seated properly and all cables securely attached
Jan 03, 2011 | EliteGroup Computers & Internet
RK549AA-ABA SR2170NX problem: i think my second slot for ram is no good. i'm supposed to be able to install 2 gb max . I bought 1gb ram to install in slot # 2 but it doesn't work. can i install...
Is the 1Gb RAM you purchase the same make and speed as the original? If not, they may not be compatible with each other or the new RAM module may be faulty.
Try removing the RAM from slot 1 and insert the new 1Gb RAM module in slot and boot up your laptop to test the new 1GB RAM module.
Installing a single 2Gb RAM module should work.
Dec 29, 2010 | Computers & Internet
Do this model supporsts win xp service pack 2
Hi.
This unit has a Pentium 4 2GHz single core processor, and does support Windows XP SP2.
The standard memory installed on this unit was 256KB RAM, in order to run XP efficently you will need to upgrade the RAM. I suggest upgrading RAM to the maximum amount allowed of 2 GB RAM.
To upgrade the RAM to 2 GB you will need 2 modules of 1GB PC2100 184 pin DIMM ECC each.
Micron 1GB DDR RAM PC-2100 ECC
May 25, 2010 | IBM eserver xSeries 205 8480
Burned RAM
just remove the 256mb ram it is the main problem only insert equal memmory of rams in 2 slots, if u insert 1gb ram in one slot try to insert also 1gb ram in other slot, donot inser 2 unequal rams in one time
Sep 28, 2009 | Computers & Internet
1gb shows 512mb only
Your mobo is quite old and its chipset can only support a maximum of 512MB PER SIDE (technically called a bank) of a memory module. I would guess that your 1gb memory module has 8 chips that are all located on one side of the module, putting all of the 1 GB on one bank. Thus, only 512MB of your 1 gb RAM is detected and usable by your motherboard (the remaining 32 mb is most likely being used by your onboard video). You'll need to find a double sided 1 gb memory module (usually 8 chips on each side).
Mar 06, 2009 | ASUS P5VDC-MX Motherboard
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
