My Maytag gas dryer Model # MDG308DAWW doesn't work - I dried a load OK and when I went to do the next load - I push the dial to start the cycle I just get a buzz and the cycle does not strat. Is there anything I can do short of calling the Maytag man. Does it maybe have a reset button somewhere - if that could be it. Tom Rowinski 810-625-6259 tar8412@chartermi.net
  • tar8412 Nov 14, 2009
    Thanks a bunch = good info - at least there are a few things I can check before calling the Maytag man
  • Washing Mach... Master
  • 19,396 Answers
Hi Tom.
If there is an humming noise, then it is almost for sure a fault. There is no much you can do apart calling a technician.
Check the lint filter (PS1814710) if there is too much lint in there you may overheated and blown the fan motor.
Try disconnecting power from appliance for about ten minutes, then connect back, this may clear a problem caused by a jammed timer board circuit.
If that does not work there is a fault.
Common faults that can cause humming or buzzing noise in this model are:
Broken belt: PS2041323 (part 21- diag.2) - the multi rib belt is broken or lose. The motor running alone will make a soft humming noise.
Faulty motor: PS2021298 (p.23-D1.)- The motor will not start and keeps humming.
Faulty fimer board: My Maytag gas dryer Model - _.gifPS2039578 (P.16-D3)- If the humming noise is coming from timer board, then the control board is faulty. This problem is quite common. Timer wiring must be tested before replacing timer board.
Here diagrams for your appliance, click on pictures to enlarge:
Motor
Belt and Tumbler.
Timer
Cabinet
If you need to contact a technician, please call the support number listed on the owners manual, it should be in the last pages of the manual.
Please do not forget to leave feedback.
Best regards.
G.
Posted on Nov 14, 2009
Maytag model mdg308daww
What is the problem you are having?
May 22, 2012 | Maytag MDG308DAWW Gas Dryer
My mdg308daww spins, the heat igniter, glows for about 5-10 seconds and then stops after about a minute it glows again. The igniter was tested ok, and the coils were replaced still the same problem....
Assuming the gas supply valve is turned on, I would make sure the gas valve orifice in your dryer isn't plugged up. If its not that leaves your gas valve not letting the gas in. Very rare though.
Sep 25, 2011 | Maytag MDG308DAWW Gas Dryer
MAYTAG DRYER MODEL MDG308DAWW IS NOT HEATING
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 17, 2010 | Maytag MDG308DAWW Gas Dryer
Maytag 2007 model mdg308daww quit working
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 30, 2010 | Maytag MDG308DAWW Gas Dryer
When I push to turn on my dryer its sound like it comes on but doesnt spin. The belt is ok
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 14, 2010 | Maytag MDG308DAWW Gas Dryer
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Won't turn on
First check voltage and breaker,(this is a big one)
next, if you have power to the appliance (120 gas dryer or 240 electric) then the door switch is probaly broken.
lastly, perhaps a thermal fuse located on blower vent. goodluck
Dec 17, 2007 | Amana DLE330RAW Electric Dryer
Washing Machines Logo
233 people viewed this question
Top Washing Machines Experts
