Question about Lands Phones
When I pick up the handset it goes dead the others seem to be o.k.
    Sergeant:
  • 297 Answers
There is a hardware problem in ur phone
Posted on Nov 14, 2009
My uniden phone is not working. All hand sets say Check Tel Line. Will not make or receive calls. Will a dead battery in one handset make all handsets malfunction? Are batteries available?
batteries are available from e-bay
one dead battery will not affect any others
all hand sets make calls and receive calls through the base unit that is connected to the landline
base unit is connected to the landline and operates any hand set that is picked up
make sure all handsets have the end call button pressed as one not pressed after use may keep a line open
call your provider to check the land line to your premises
borrow a neighbours phone and plug it into the socket and see it you get a line on their phone
Oct 30, 2016 | Uniden Lands Phones
My panasonic cordless phone goes blank when picked up
Sounds like the batteries in the handset have failed, they will display in the charger from mains power
Jul 13, 2012 | Lands Phones
Phillips CD445 cordless phone - cuts out when pick up to answer
if you have had it a while chances r the batterys have had it even though they show full, try a new set, or even try standard batterys briefly while fone is not in charging mode to see if they work during a call.
Jul 30, 2017 | Philips CD4450 1-Line Cordless Expansion...
I have a Uniden Integri sound Power Mac 5.8 ghz. One of the three phones does not register the caller ID. How can this feature be restored?
We have a similar problem with one of our handsets- except that in addition to the caller id, none of the other functions work. We've also noticed that we can get only about 10 mins of talk time on that particular handset before the battery goes dead. The manual says that if the battery is weak, none of the other functions on the phone will work (in order to conserve battery life). This seems to be our problem.
Oct 26, 2009 | Uniden 5.8GHz Dual Cordless Phone
My fax goes off periodicall when a call comes in.
It means that your fax machine is "answering" the incoming call before you pick up the handset. Usually, the factory setting on the fax machine picks up after two incoming rings. There are three ways you can address this issue: 1.) You can either change the number of rings to, say, five incoming rings to give you enough time to answer the phone before the fax machine picks up, or 2,) you can find out if your fax machine has a feature that allows for the voice hook "click over" that will allow you to override the fax when you pick up your handset, or 3.) turn your fax machine off until you need to send a fax.
If you want to investigate number 2.), then you'll need your operator's manual.
Good luck.
Aug 28, 2009 | Office Equipment & Supplies
Replaced battery in handset. Got a dial tone and all was well. Picked up handset later in the day and it was dead. Unplugged and reattached everything - no luck.
Try taking batteries out, but also unplug base station. The aim is to disperse all power in the phone so that it resets itself. I would leave everything unplugged for 24 hours and then reassemble and see if the problem has gone. Its worked for me loads of times with different electrical appliances. Hope that helps.
Apr 23, 2009 | Sony SPP A1050 Cordless Phone
I have a cs5111-2 and a cs51113 and when one phone rings, i answer it and if it is for someone else in the house, i tell them to pick up the one upstairs and when they do their not coming through at all,...
In order to have the other person pick up, you must hit the select button to transfer teh call to the other handset... it is impossible to use both handsets at the same time, if that is what you were trying... hope this helps
Aug 23, 2008 | Lands Phones
Uniden phone
That sounds like the battery is not charging properly. When in the charger there is enough voltage passing to power the handset, but when pulled off the charger it must rely on just the battery. I suspect you replaced your battery because you were having a problem, right? Your problem may be dirty charging contacts. Try taking a pencil eraser to your charging contacts on your handset and base. Try charging your handset again, and ensure your charge light comes on when doing so. Let it charge overnight. Hope that helps. CG
May 26, 2008 | Uniden Cordless Phone
Hand set goes dead
Next time it goes dead, try wiggling the cord where it plugs in the handset and where it plugs into the phone. If the problem goes away, you will need a new cord.
Hope this helps, and if so, please rate my advice.
Feb 05, 2008 | RCA 25202RE3 Corded Phone
All handsets cannot be used at the same time
Some of the cordless phones do not allow more than one handset to be used at the same time. Is there a transfer button on the handsets? Can you call from one handset to the other? If not the phones probably have to be used one at a time.
To get off speaker phone just push the speaker phone button again.
Jan 28, 2008 | GE 25931 Trio Cordless Phone
Lands Phones Logo
42 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
