Users manaul for indesit wm12x washing machine
When i put the washer on programe 8 washer starts ok then then programe selector knob just carries on going round only way to stop isto turn of power
Posted on Jan 30, 2010
Morning ive got a indesit wm12x washing machine iam looking to replace it because its broken do you still do them thanks
fixya site never had any washing machines as we never have nor do we have anything to sell
contact a retailer or previous supplier direct on the phone
Nov 28, 2016 | Indesit Washing Machines
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
My dial keeps clicking round on my indesit wm12x, have ordered a new part, do you think this is the problem.
I doubt it will solve the problem, as the part you are referring to is a selector switch and not the timer, the problem is more likely to be a faulty control unit.
Nov 19, 2010 | Indesit W 83
I have a indesit wm12x washing machine and i was told it is a dryer but i can not get it to work please help
I have been looking at your machine on internet and found out that the indesit model you have is not the washer dryer version it is a washing machine so has no dryer function. hope this helped.
Sep 19, 2010 | Indesit W 123 Front Load Washer
Manual for intergrated indesit wm12x washing machine
To obtain the instructions for washer, go to,
WWW.INDESITSERVICE.CO.UK
In the menu on the left click on Indesit user manuals, then enter the model number in the search box, and down load the instructions to your printer or hard drive.
Please rate my solution.
Thankyou.
Jan 13, 2010 | Indesit W 123 Front Load Washer
I need to replace a washing machine door seal (indesit wm12x). Do i need to remove the top or can i do it from the front ? Any other tips on the procedure would be great. Thanks
It would be adviseable to rempve the top, and also tilt the washer to the rear, as it makes it easier to change the seal, and gives you more room to get your hands in.
Please rate my comments.
Thanks.
Oct 30, 2009 | Indesit W 123 Front Load Washer
Indesit Washing Machine WM12X... Were Should The Water Level Come 2 On A Wash Cycle..
The water level will never go above the lower part of the door bowl. Can you be a little more specific on your question?
Regards
Sussex Engineer
Oct 22, 2009 | Maytag MAH6500 Neptune Front Loading...
TEAR IN SEAL ON AN INDESIT INTERGRATED WASHING MACHINE...MODEL NUMBER WM12X. IS THIS EASY TO FIX,THERE IS ALSO MOULD ON IT...MAKING IT SMELL, ARE THE PROBLEMS LINKED ?
the fitting of the seal depends on the age and wether the tank assembly has been changed as there were two different fixings one was a spring fitting and the older version was a clamp which requires a tool to fit.
the mold is rotting washing powder which can be reduced by putting a cleaner through once a month.
Aug 05, 2009 | Indesit W 123 Front Load Washer
Help!! Indesit WM12X - cold wash only
Yes, they are easy enough to replace, but you need to test them with a multimeter to see if they are faulty..
There could be other things wrong.
Nov 22, 2008 | Indesit W 123 Front Load Washer
Filter on indesit washing machine
Push panel right or left side. Unscrew or turn anti-clock wise, according to your model. Be prepared for some water. Pull this out and clean, refit carefully. Of course it is meant to be removed and cleaned periodically, according to usage. Rate me pl.
Nov 30, 2007 | Washing Machines
Washing Machines Logo
299 people viewed this question
Top Washing Machines Experts
