Question about Sony Playstation 3 (PS3) Console
Audio but no video using hdmi on ps3
First i hooked up the ps3 using the component cables that came with the system and it worked fine. later, i purchased a hdmi cable and hooked it up to my toshiba hdtv but only get audio and no video through it.
  • howards206 Dec 21, 2008
    hooked up hd cord no video but audio
    Problem Solver:
  • 5 Answers
The cables might be faulty so borrow some one elses cables and try them if you have that option or just go back to the cables that came with it for now.
Posted on Jan 09, 2008
Mitsubishi rear projection tv, model WS-48311 - Lost audio after moving tv and re-hooking up cables. How do I get it back?
It sounds like this TV is being used only for the PS3. We'll need to troubleshoot this through a process of elimination.
If you're using Component Input 1 and audio, try using Component Input 2 and audio instead. If this set of inputs provides working audio and video - you can stop. Or, try going back to Input 1 once more. If Input 1 now works - you may have simply made a better connection. If it doesn't - then there's probably an issue with input 1 on the TV.
If moving to Input 2 above still didn't solve the problem, you should try using a different set of audio cables between the HDFury and the TV. If it now works, the original audio cables are faulty.
You can check the HDfury setup on another HDTV with component inputs with it connected to an HDMI cable. if the HDFury wors, you know the device and all the cables work. If you do this test and it works with your PS3, then you know that the PS3 is providing good video and audio signals via HDMI. If the problem follows the PS3 - then it's the PS3 at fault. If everything works perfectly on the second TV, then there is some issue with the audio amplifier / inputs / speakers of the Mitsu TV. You could get a cheapo stereo amp and speakers - or a set of computer speakers for audio - it all depends on how much you want to spend for sound.
Good lcuk!
May 07, 2015 | Mitsubishi Televison & Video
When I hook up my LG plasma to PS3 and Cable box, I don't get any sound or colour on the PS3. The TV /cable box works fine. Any ideas on the wiring?
What type of connections are you using? HDMI? Component? Composite? What audio? HDMI? Optical Digital? Analog audio?
Are you saying you get video from the PS3, but it is in Black&White only? Is there an NTSC/PAL selector on the PS3? If so, it may be set wrong. Set to NTSC if you're in the United States.
Feb 01, 2013 | LG 50PC3D 50 in. Plasma Television
How do I hook my PS3 gaming system into my Yamaha Rxv2600 receiver. I can get sound but do not get video. I had to use component video from the receiver to the TV because that was the fire code for...
Use HDMI - I don't understand what you mean by "fire code". HDMI uses less cable involvement, where as component uses five cable to produce video - no audio. HDMI accommodates the audio signal as well. However, if you want 1080i, this will only work for component - you need 1080p for HDMI.
Jan 20, 2011 | Yamaha RX-V2600 Receiver
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
I just bought a PS3 slim and hooked it up to my 65'' Toshiba DLP TV using a HDMI cable. The problem is i have picture but no sound. I have tried the settings and all seems to be fine, also tried different...
not 100% sure but check the manual for your tv it may be that you need a faster hdmi cable, as with having a larger tv it will work at a faster rate so the basic hdmi cables wont work.
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
Audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those isn't worth it and regret i bought it.
Jun 14, 2009 | Bose Lifestyle 48 Series III System
Playstation 3 hook up problem
I ended up using the component in cable hookup and fiber optic digital audio instead of HDMI - works fine.
Dec 28, 2008 | Sony Playstation 3 (PS3) Console
Check the couplings at either end of the cable. Sometimes these will loosen and can cause a lack of signal strength.
but its probably not the cable, its probably the ps3. HDMI cables don't really break because they are just wires, they don't have moving parts. Try connecting your PS3 to your TV with the regular cable red, white, and yellow connectors that you got when you bough the PS3. If the PS3 doesn't work with the original red, white, and yellow connectors then you know its the PS3. If the PS3 does work fine, you know its either the HDMI cable (still unlikely) or the HDMI connection on your TV or PS3 (more likely
Oct 12, 2008 | Sony Playstation 3 (PS3) Console
Cant go from a/v cables on my ps3 to hdmi cables! AAAAHHHHHHH
I had the same problem. If you go into the system settings portion of the menu and reset to default settings, then connect your HDMI cable while the system is re-loading, the PS3 should "see" the HDMI cable and ask you if you want to connect your audio and video using that. Hope this helps.
Dec 31, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
85 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
