Question about Canon Pixma iP4500 InkJet Printer
Canon printerip4500 shows error USB003. Nothing wrong with output tray
    President:
  • 1,194 Answers
Usually, USB error show when there is some problem with your USB Data cable, follow the instruction to resolve it.
1) Disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
Else...
2) You can try a different data cable on the computer, may be issue with that specific data cable.
Visit this link for more information & Type "Error USB" in enter your question space.
Good luck.....don't forget to rate the solution.
Posted on Feb 23, 2010
Paper outray is showing closed however its open, in Canon mp287 printer
For Paper Output Tray error
Paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
or
look for buttons or such things on the part that has blue rectangle below.. check inside if theres piece of paper or any object.
Jan 30, 2015 | Canon Office Equipment & Supplies
Canon gives error 03e
Hi
This error maybe cause of two reasons:
  1. The paper output tray is closed.Open it.
  2. Paper jam.Turn the machine off and on.Look through the paper output tray for any stuck papers and gently pull them out.
Hope this helps.Thanks!
Ken.
Mar 24, 2012 | Canon MP280 All-In-One InkJet Printer
I am getting a "fax output error - cassette." It
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes successfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Dec 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
My copier keeps showing an error: remove paper from output tray but there isn't any paper there? How do I proceed?
on the output tray you will see sensor flapper... it can get stuck ed... try to manually lift or down it, it usually gets out of his holder.
Keep me posted,
Hope that help's!
Nov 18, 2010 | Canon imageRUNNER 4570 Copier
Error 1250 on PIXMA ip4300 printer. Despite open tray messae will not o away or allow printing to start.
the error message means there is something wrong with the printer and if the problem is not attended to, the error message will not go away.
In this case, the error message showing on your canon ip4300 is related to a door problem. It has something to do with the front door of your printer. I think the front door of your printer is closed of which is supposed to be opened.
So, the solution is to Open the paper output tray of your printer and the problem should be solved.
Good luck.
May 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
MX338 output tray problem,
please help me...how to reset the following ink cartridge cannot be recognized U051 canon mx338
Jan 23, 2010 | Canon Office Equipment & Supplies
Photo Tray Problem
When nothing worked, I reexamined the trays, and there is a small plastic hook about half an inch long under the left side of the D7460 output tray. The tray below had a small hole. So I clicked the two together, and the printer started printing. Probably like many of you I had elevated the output tray as the printer spews onto the floor. Apparently it needs this connection. So much time lost....
Apr 11, 2009 | HP Photosmart D7460 Printer
Canon Pixma iP4500 InkJet Printer Logo
522 people viewed this question
old marine
old marine
