Question about Intel Computers & Internet
While plugging my pendrive in system the system gives me an error that your pen drive is multifunctioned windows is not able to operate it
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
Posted on Nov 17, 2009
    Problem Solver:
  • 13 Answers
If you have tried to insert the drive into multiple USB ports then the issue is probably the flash simm inside the card or the USB controller. In either case the drive is not operable.
My system is not reading any pendrive so please give me solution very soon
first check your pen drive in some other system to make sure that your pen drive is not faulty
then try repairing your usb drivers of your operating system by using the cd
ex- if it is windows xp then use bootable disk & fast repair or override the operating system on the same drive.
Feb 04, 2011 | Computers & Internet
My windows was unable to complete the formate my pendrive. my operating system is windows 7 ultimate
this is a most common problem.it is due to the errors from your pc/pendrive.so at first format the drive in a fresh os and then connect to your pc.please remove the pen drive safely by clicking the green icon near the time and date.
Sep 27, 2010 | Computers & Internet
Windows vista ask for pen drive driver when i plug it
you should download the driver of pendrive from net from the site of which you pendrive is and install it
Jul 04, 2009 | Microsoft Windows Vista Ultimate Edition
My 4GB pen drive is not formating...
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
Jun 26, 2009 | RCA TH1101 MP3 Player
Pen drive not showing in my explorer.
Its a common problem with the pendrive, in windows. some time it doesnot detect or not showing clearly that device. you have to check your pendrive manufacturer and driver details. and also check it out driver signing.
Do you have mapped network drives on your computer? If you have this may cause your problem. When you insert the PEN Drive into USB and the "safely remove hardware" icon appers try to right-click on it and choose "eject" or "remove" (don't remember :), then pull the PEN DRIVE from the USB and connect it again. Go to Windows Explorer and try to open all your mapped drives, then the content of your PEN DRIVE must be loaded into your Windows Explorer. This is happened sometimes, because PEN DRIVE try to assign the first free drive letter after your phisical drive letters, and if you have a mapped drive letter, the PEN DRIVE assign one of them.
Jul 22, 2008 | Microsoft Windows XP Professional With...
Drivers of pendrive for win98
i have moserbear 4.0 pen drive but i haven't the driver for it to run it in my win 98 OS. plz give me the solution.
Apr 16, 2008 | Microsoft Windows 98 for PC
Pendrive is not working
ic, maybe the usb port of your friend's pc is defective which may cause your pen drive to malfunction, probably a shorted usb port. or just maybe your pendrive was dropped by your friend which damage the drive, it happened to me too before.
Sep 18, 2007 | Transcend (589307) Media
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
