Question about Sony Ericsson W550i Cellular Phone
Srcrew loose Hello, 2 screws in my w550i flipping mechanism is loose. how can I tighten it. thank you, gurus
    President:
  • 1,017 Answers
The answer is very carefully.
For this sort of problem you would have to buy special tools witch you might never use again. So you are better off going to a mobile shop to have it done. Or maybe an electronics shop. TV repairs, CB radio shop that sort of place.
Posted on Jan 08, 2008
How do you remove the handle to get to the screws to tighten the handle its very loose
Hello Martin;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on the upper inside wall of your fresh food section. So, I can not be accurate in regards to your unit.
1.) Inspect your handles. Are there 3/32" allen wrench screws at the top and bottom? If so back off the screws until the handle comes off. Then tighten the screw on the refrigerator door. Put handle back on the and tighten the 3/32" screws.
2.) No external screws - Then the handles are held on in a slip in slot fashion. Pull up on the door handle. This is going to take a little mussel. Remove the door handle. Tighten the screws on the door and the back of the handle. Slide handle back into place.
Mar 25, 2015 | Refrigerators
The middle, plastic rotator piece in the middle of my whirlpool washing machine seems to be loose, so when the rotator is agitating the laundry, it is making a slight shaking noise. Is there a quick way...
Hello Ajlikt.
There maybe a center screw.
The screw is most likely covered by a plastic lid.
Flip lid up and turn screw clockwise until tight.
Replace lid.
Dec 01, 2017 | Washing Machines
I purchesed a BS18G Cordless Drill. How & when can I use the indication dial from 1 to 24 thank you
This dial is a torque setting. The higher the number, the higher the torque. Torque is a measure of how hard something is turned. For example, suppose you were using a regular screwdriver to tighten a screw. If you were to hold the screw driver loosely in your hand, your hand would slip before you tightened the screw very much. If you squeeze the screwdriver handle tightly, you could tighten the screw a lot more. The low numbers are like holding a screw driver loosely. The mechanism will slip before it tightens very much. This is only useful when you are trying not to overtighten small screws. When you are using it to drilll holes, you will want to set it at the maximum. Good luck, Al K
Apr 26, 2011 | Garden
Door handle came loose .how do i tighten it up`
hello kyler.... Empty out the contents of the door of the fridge. Then pull up the gasket and under that you will see screws. Remove those screws and the entire inside of the door is released exposing the screws to tighten the handle. Joe
Thanks for choosing Fixya!
Feb 24, 2011 | Whirlpool Refrigerators
Loose paddle
Pop the top ... remove the front ... carefully remove the belt ... take the drumout - you are correct, the paddles are held onwith screws - tighten them.
reassemble
Oct 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The rubber in front of the machine has come out so has the metal spring that goes around it
take lid off put rubber back in place and put the metal holder around the rubber with screw loose try have the clip connection to the top as this helps with tightening. tighten screw and jobs a good un
Jun 23, 2009 | GE WSXH208A Front Load Washer
Loose Kwikset Chelsea Deadbolt
I just had the same problem as samrpetrich with a loose kwikset deadbolt. Here's how I fixed it - on the inside of the door, take off the latch that flips the deadbolt in and out using a very small allen key. There is a round plate cover that is snapped on top of the inside deadbolt mechanism. If you look on the bottom aspect of this round plate you'll see where it snaps on; once I saw where to apply pressure it came off easily - taking off this plate exposed the two screws beneath that were loose. Once I tightened these, I snapped the plate cover back on, but the dead bolt latch back and everything is tight again. Hope this helps.
Jan 23, 2009 | Kwikset Professional Door Lock...
Loose "flip" (display) on a Razr v3. How can I tighten it..??
You may need a new Flip assembly.
The version might depend on your model of V3 (RAZR)
May 22, 2008 | Motorola Mobility RAZR V3
Sony ericsson w550i swivel
try this web site http://www.howardforums.com/archive/topic/898275-1.html
Jul 27, 2007 | Sony Ericsson W550i Cellular Phone
Electrolux Oven EOG9330
Hope this helps (technique used on EOG9330XN):
1) With the door open, on each hinge, there is a top cover which lies flush with the hinge. Simply swing this cover up and back towards you. This unlocks the hinge. Undo both and carefully close the door, holding it at the bottom. The door should be able to be pulled away from the frame now. Lay the door on a flat surface.
2) The oven will normally be attached to the surrounding built-in cupbpard. If so, unscrew all attachment screws (mine had at least three per side) and pull the whole oven out about seven inches, supporting if neccessary. Each side panel has a locating screw in bottom front corner, so remove the screw. Peel back the side panel (only thin alloy, but watch for sharp edges) sufficiently to see.....
3) The two side securing screws for the door hinge receiver should be visible. After pulling receiver forward, if loose, tighten securing screws (use lock washers if available, as Electrolux don't provide them).
4) Reverse the procedure to finish job, fitting the door in the near vertical position to engage hinges in the receivers. Support the door, lower to open position and flip the locking hinge covers back.
[This technique works if the hinges aren't worn and if the door doesn't close properly, it usually means that the receivers are loose and have been pushed back into the oven frame].
Apr 11, 2006 | Electrolux EOG9330 Gas Double Oven
Sony Ericsson W550i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
