Question about Go Ped ESR750Ex Electric Scooter
No response installed new throttle assy. still no response.applied current to motor motor works. batteries showing full charge.
Hi
i am new
how can i install the sabre reservation system
Posted on Nov 14, 2009
My Zip'r 4 is flashing the green light 7 times which means, "A throttle fault has occurred." The Throttle seems to be working fine, How do i fix this issue?
One of the cells of the battery seems to be bad. Though you charge it, and it shows full charge, but at the time of using the throttle the kinetic power is not there. I recommend that you take the battery to battery ware house so they can confirm the problem. If the problem is not with the battery then the issue is with the circuitry, but most likely it is the cranking power of the battery, though it is fully charged, but it get exhausted right away..
Jul 07, 2014 | Zipr Mobility Zipr Xtra 4-Wheel Hybrid...
No charge indication on throttle and motor doesn't work - New charged batteries.
Make certain the Batteries are IDENTICAL to the original. Any change of the Voltage, Current, or Amps will damage the motor or starter. Check all connections to see if they are properly set and Plus is to Plus and Minus to Minus. Check the Ground wires. Make certain all wires are insulated well, no cuts, peeling, cracks, or holes. Technically speaking, if you do not have test equipment like a VOM (Meter) you cannot check continuity (for shorts) and leaks.
If you are satisfied that we are tryting to help you, rate the person accordingly.
Apr 02, 2014 | Electric Currie EZIP 500 Scooter
2009 Ford Mustang has no throttle response at all why?
1.Check wiring. 2checkair fow meter or fow meter also spark plugs
Dec 01, 2013 | Ford Mustang Cars & Trucks
Aquasoothe travelite scooter, the batteries are fully charged, the battery gauge is showing full, but the battery light is flashing. It flashes 7 times then pauses, we can't get the machine to move or...
Response to similar query in 2011.
http://www.fixya.com/support/t5751777-aquasoothe_travel_lite_instruction
not my words. The link to the pdf for this is http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
you want page 22.
Problem Check Point
The driving of the wheelchair is too slow or insufficient, the status
indicator lamp flashes slowly Batteries are exhausted and need to be recharged
1 flash The battery needs charging or there is a bad connection to the battery. Check the connections to the battery or charge batteries.
2 flashes There is a bad connection to the motor.
Check all connections between the motor and the controller.
3 flashes The motor has a short circuit to a battery connection.
4 flashes Freewheel is engaged.
5 flashes Not used.
6 flashes The controller is being inhibited from driving; this may be because the battery charger is connected.
7 flashes A throttle fault is indicated. Make sure that the throttle is in the rest position before switching on the scooter
8 flashes A controller fault is indicated. Make sure the controller connections are secure.
9 flashes The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the controller connections are secure.
The-Active-Light
does not function,
the Battery/
Status indicator
flashes rapidly.
Count the number
of flashes:
10 flashes
An excessive voltage has been applied
to the controller. This is usually caused
by a poor battery connection. Check the
battery packs and controller
connections.
Sorry wasn't sure how much space they give you for answers. :)
Oct 11, 2013 | Health & Beauty
Why is my Razor motorcycle MX350 battery showing green but not charging
yes!your battery needs replacement.....throttle clicking after a full charge is a sign,...but that's after 2years or more,depending on how it's being used..your motor can go bad before then if you been riding in the rain--wet connectors in or out the motor can not get wet for any reason..a full dirt motor bike can not get full dirty with mud..mud catains water/water and electricity don't mix/////.motor/thottle/moisture.
Dec 17, 2012 | Razor MX500 Dirt Rocket
How will i know if its my batt or motor on off switch lites up red but nothing happens
Lift the rear wheel up off the ground and apply the throttle, while watching the throttle lights. If the throttle light goes from green to yellow or red it shows that the battery voltage is dropping under a light load because the batteries are low in capcity - not holding much charge. Most battery places will load test the batteries free of charge to confirm this.
Have a look at the trouble shooting guide here
http://www.razorama.com/razor-installation-guides.html
and the wiring diagram here
http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Jul 30, 2012 | Razor MX350 DIRT ROCKET - BLUE
Fuse blows repeatedly
The auto speed control is failed. Keep it manual and see how it does...It will run at full throttle even when no load is running. Then fix the throttle control when able.
Aug 09, 2009 | Generac Guardian Ultra Source 15,000 Watt...
Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Minn kota turbo35 electric motor only stays on full spped for 10 minutes.
I dont know how old your battery is but they will sometimes show full charge but not last long cause of age. Try a differant battery.
Jul 26, 2008 | Boating
Need new adapter?
Clean the heatsink and fan assy and apply some thermal grease to the cooling pad on the CPU.. Its throttling back on batt. and not running full tilt. Vents are plugged/Obstructed/Clogged..
www.ikenfixit.com
Jan 13, 2008 | Averatec 3200 Notebook
Go Ped ESR750Ex  Electric Scooter Logo
129 people viewed this question
Top Go Ped Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Go Ped Toy Expert? Answer questions, earn points and help others
