Question about Mitsubishi WS-55511 55" Rear Projection Television
Mitsubishi rear projection tv won't turn on
Press button and tv comes on for 3 seconds than turns off. model ws-55711 (pretty sure)
    President:
  • 4,402 Answers
Know problem of bad caps.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Posted on Jan 08, 2008
SOURCE:
Tip
Bypass Mitsubishi WS-65711 Front Lock
Bypass Mitsubishi WS-65711 Front Button Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65711 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65711 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
________________________________________
Mitsubishi WS-65711 Manual Download
Reset Mitsubishi WS-65711 VChip Password
on May 04, 2010 | Mitsubishi WS-65711 65" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
I cannot power up my mitsubishi 55711
This sounds like the flyback unit on the main board has went out(this contro;s the power to the differnt areas of the TV (a flyback costs around 70.00 and you can order one at www.sears,com yhe parts dept...Have make and model ready!
Dec 13, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Tip
Bypass Mitsubishi WS-65611 Front Lock
Bypass Mitsubishi WS-65611 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65611 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65611 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Mitsubishi WS-65611 Manual Download
Reset Mitsubishi WS-65611 VChip Password
on May 04, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Bypass Mitsubishi WS-65511 Front Lock
Bypass Mitsubishi WS-65511 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65511 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65511 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Mitsubishi WS-65511 Manual Download
Reset Mitsubishi WS-65511 VChip Password
on May 03, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tip
Reset Mitsubishi WS-55711 VChip Password
Bypass or Reset Mitsubishi WS-55711 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 55711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
Bypass Mitsubishi WS-55711 Front Lock
Mitsubishi WS-55711 Manual Download
on May 03, 2010 | Televison & Video
Tip
I hope that helps.
on May 03, 2010 | Mitsubishi WS-55711 55" Rear Projection...
Tip
Bypass Mitsubishi WS-48511 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-55711 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-55711 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Tip
Bypass Mitsubishi WS-48511 Front Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Reset Mitsubishi WS-48511 VChip Password
Mitsubishi WS-B55 Manual Download
on May 03, 2010 | Mitsubishi WS48511 48" Rear Projection...
Tip
Bypass Mitsubishi HDTV Lock
Bypass Mitsubishi HDTV Front Button Lock
I hope that helps.
Reset Mitsubishi HDTV VChip Password
Mitsubishi Projection HDTV Manual Download
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
874 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
