Question about Apple iPod touch
My sisters ipod doesnt work in wifi its greyed out tried setting again no good any ideas
  • 281 Answers
The first thing i would do is reseting the ipod to factory settings. This can be done by going to the settings icon on your itouch. Once you are under setting go to the general tab. Once in the general tab go to the reset tab. Once in the reset tab go to reset all settings. This will reset all the settings on your itouch. If this does not fix your problem try hooking the unit up to itunes and restoring the unit. This will cause your unit to take all data off your unit, so make sure itunes has backed up the unit. If this still does not fix your problem then check with apple to see if your unit is still under warranty with this site: https://selfsolve.apple.com/GetWarranty.do
The serial number can be found on the back of the unit toward the bottom.
If you have any further questions feel free to contact us at www.wiredextreme.com
Posted on Nov 15, 2009
Alright i have an ipod touch and when i go to settings and try to go to wifi my wifi is gray and whont do anything whats the problem?
it would be gray try to slide the button to the right hand side of the wi-fi logo to turn it on..if this still doesn't work try this
settings->general->reset->reset network settings this should work if doesn't try to restore the ipod to the factory settings but it'll be at a cost of loosing all the data in the ipod.
good luck
Oct 02, 2010 | Apple iPod touch
Wifi grey out(no wifi)
how do i disable my ipod touch 8GB
Jul 01, 2010 | Apple iPod touch
My ipod touch says server not responding every time i try to go on the internet why???
1. you might have a virus 2. You might have to check the signal of the itouch
A solution that you should try which will most likely help because this happened to my sisters itouch and it connected to the internet
1. Go to settings 2. Tap on Wifi
3. Go to the option that lets you manually put in the name of the connection, the connection type, and the password to the connection.
So again, type in the exact name of the wireless connection, Pick the connection type (WEP, WPA, ect.) then put in the password.
It should help(I almost know that it will help).
Jun 01, 2010 | Apple iPod touch
Ipod touch will not connect to belkin wireless router.
If your Ipod touch will not 'find' your Belkin N router - or it did and then vanished forever try this- it worked for me.
1.Turn wifi off on your computer, ensure you have the latest firmware on your router,reset the router to factory default.Do this using a wired connection from the admin page.
2. Change the SSID name from what it was previously say from Belkin xyz to my router.
3. Power down the router wait about 30 seconds then power it back up.
4. As you reset to factory setting you will need to put in your internet access info again - do this from the admin page. Also set up your security at the same time.
5. Restart the router from the admin page.
6. Unplug wired connection start wifi and connect to your computer -make sure that you have full internet access from you computer - dont forget you need to connect to the newly renamed router.
7. Take ipod and make sure wifi is off.
8. Clear network settings.
9.Turn wifi on and it should find your newly renaned router - join and enter your pass key.
Why it does it I have no idea neither do Belkin or Apple but it worked for me - a trial and error solution !
Good luck
Mel
Jan 25, 2010 | Belkin (F5D7230-4) Router (587009)
Mine and my sisters ipod touch keep saying invalid argument everytime we try to get on the internet on it. If you know what wrong please anwser.
Hello there!
I might be able to help you on your case.
When you are connected to the wifi on your ipod touch do the followings
Settings>>wifi>>(you will see a blue arrow next to the wifi signal you are connected) tap on the blue button>>you will see couple of lines full with numbers.
If you see anything full less then 4 line then do these procedures.
After you press the arrow button you will see at the top part saying forget this netwok. Tap on that and then try to re-connect with the wifi.And then do the above procedures.
If it still doesnt solves your problem then this is because of your wifi connection.Try to reset your wifi connection or use another connection. Hope this will help you.
Jan 18, 2010 | Apple iPod touch
I just bought the 32 gig itouch and my sister wifi works but mine doesnt and not picking up a signal in the house
i have the same problem but i figure out the solution. sometimes the problem is not the ipod is your router. check if you the firmware is updated. what kind of router/internet service do you have?
Oct 13, 2009 | Apple iPod touch
I cant get internet on my iPod touch 4GB.
Have you tried to forget network and go back in and reset up the network on the ipod touch under wifi?
Jul 21, 2009 | Apple iPod touch
My touch shows that I have a wifi connection, but i cant use it.
All you have to do to the ipod is go to settings, wifi and make sure its turned on in the same place you should see a list of wifi networks you can connect to just tap the one you want and the ipod will do its thing your done, but if you done all that and you ipod doesnt go online says connected but wont access the net, my guess is the wifi router you mite have some prob with that, make sure the internet ethernet cable is pluged into the modem plug not the numbered slots after this you should be good to go unless your wifi modem is new if so some req you to plug it to your computer via ethernet cable to program it first! Hope this helps
Jul 13, 2009 | Apple iPod touch
Wifi grey area
Here is a way that solved the problem for me.
Downgrade the ipod touch to firmware 1.1.4. You have to put your ipod into DFU mode ('not recovery mode) and you have to have an itunes version that supports this old firmware. 7.5 oder 7.7 i think.
to load your own firmware you simply hold the shift-button while you push the restore button.
After you have firmware 1.1.4 on your ipod touch, download the jailbreaker "Ziphone". This programm has the option to fix the "no Wifi" problem. Look in the advanced options.
In my case, this was the only thing that solved the problem. I tried restoring it often but nothing worked.
After Ziphone fixed your Problem, you can update the Touch to the latest firmware. Wifi was still working, at least for me
Jul 11, 2009 | Apple iPod touch
Wifi problems (iPod G1)
i had experienced that problem with my PSP at the same case,just set your internet connection again and delete all of you history,cache and some data in you iPOD.HOPE I HAD HELP
Jun 20, 2009 | Apple iPod touch
Apple iPod touch Logo
209 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
