Question about Samsung MU3250W Microwave Oven
Samsung microwave -the electrical panel runs, the
My Samsung microwave is less than a year old. The electrical panel runs, the turn table turns, light lights up - just isn't heating up. I put a cup of coffee on four times for one minute - still ice cold.
    Scholar:
  • 91 Answers
It sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Posted on Feb 01, 2010
My smh8165 microwave stopped working and the display says "SE" and is less then a year old
Unplug microwave. Remove (2) flat head machine screws on the top of the microwave holding in the top front trim. My trim slid left and gently pulling was removed. The control panel has (1) screw holding it in. Remove screw, slide up and gently pulling detach from microwave. There are (5) electrical disconnects which need to be disconnected. Do not force they should come easily. Lay control panel on and old towel. Squirt both the male and female connections(in microwave control panel opening) with electrical cleaner. Carefully clean up excess. Connect the (5) quick disconnects and carfully fit back in the control panel opening. Attach screw. Place top trim in and slide right to lock. Once it is in secure the top two screws. Clean area and plug back in. Hopefully your up and running. These pieces break real easy so don't force anything.
May 26, 2011 | Samsung Microwave Ovens
Less than 5 years old - Microwave Panel lights up, turntable turns, fan works - everything works except it doesn't heat food. Heard a pop, and now it runs louder than before but doesn't heat. Any ideas?
That pop was the magnetron frying. This is a repairable problem, but feirly expensive, around $300 if you have it done by a professional.
Please rate my response if it was helpful to you.
Thanks, Repairman45.
Dec 02, 2010 | Frigidaire PLMV169DC Microwave Oven
Oven not heating. runs but no heat. GE Spacemaker (11 years old) Light works, table turns. Seems a little louder when turned on
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Sep 26, 2010 | GE JVM1440 Microwave Oven
Samsung mw87L microwave does`nt emit heat, light works, turn table works, controls work, but no heat. Had it just over a year.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhj
Apr 21, 2010 | Samsung MS1040BB Microwave Oven
Intense squeaking noise
When microwave is running, turntable squeaking when rotating. Can problem be fixed? Microwave is about twelve years old.
Mar 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No heating or power to microwave oven
You have a fuse in the back that's problem is blown
Mar 13, 2009 | Microwave Ovens
Defective microwave
I would definitely contact the manufacturer since most of them have a one year parts & labor warranty and they'll fix it free.
If you have your owner's manual, you can find their number. If not, please reply back with your brand and model number (or brand at least) so we can help you.
Sounds like a bad door switch or relay, and also possibly a bad magnetron or high voltage diode.
May 29, 2008 | Magic Chef MCB780W Microwave Oven
Samsung MU3250W Microwave Oven Logo
209 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
