Question about CyberLink SW- DVD Software Power DVD (SWPOWERDVD) DVD Drive
Need to Re-install Cyberlink Power DVD 6
I have uninstalled a program from my computer but copied the Program Folder for it to my computer first. I can't find any file within this folder which say ''setup'' or ''install'' as i want to try to re-install it. Is there a specific file type i need to look for within this folder to re-install?? The program is Cyberlink Power DVD 6.
Thanks,
R
  • 535 Answers
Here is the downloading link for power dvd download and install in your PC because Ur power DVD CD has been damged its cant read the file from the socrce u have to download new version of the power dvd and install in your pc
Posted on Nov 14, 2009
Where i can download usb drivers for gz-hm30bu ?
You dont need drivers for this camera to connect to a PC. The Everio HDD cameras use their own file format called .MOD which, in the first instance can only be used by the supplied software. The way the cameras connect to computer is via a USB2 connection.
When the camera is connected to a computer the computer will only see an extra hard disk drive or "Removable Disk" just in the same way as it would if you connect a USB memorystick etc. This is the cameras built in hard disk drive and you can copy and paste from that drive to your computer. For the video files you need to look in the folders on your new "Removable Disk" (or "Everio HDD...." if you have the 21/26/36 etc 2006 range) called SD Video. Inside the SD Video folder you are looking for folders starting with "PRG" and depending on how much video you have taken you may have a few (PRG001, PRG002 and so on).
To save time i would highlight the whole PRG folders, right and click on the folders and copy them to a new folder on your PC. Make sure to give the new folder a memorable name and remember where it is.
Then, with the supplied software, if you want to do some video editing you start the hopfully installed Cyberlink PowerDirector. This program will open in the edit mode. You then click on "FILE" at the top of the screen, drag you mouse down to "IMPORT" and drag your mouse slightly to the right to "Media Folder".
You then need to find the new folder you made with the copied "PRG" folders from your camera, select "OPEN" once you have found your folder and it will import the videos from that folder into the PowerDirector program. You can then drag the images to the timeline in that program to playback or edit.
The other program supplied with the Everio cameras is Cyberlink PowerProducer. This program is for burning DVDs of the video files. The principles are the same where once you have set up the type of movie you want to produce (DVD, VideoCD etc) you can then import the .MOD files directly into the program and burn DVD that will play on normal DVD players.
Jun 17, 2011 | JVC Everio GZ-MG20 Camcorder
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
Jan 24, 2008 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Tip
Removing Cyberlink Power DVD Registration Pop Up
Are you using Cyberlink Power DVD version 6 or later.
these version keep popping the registration menu quite often which makes it somewhat annoying if you don't want to register it.
here is how to stop the pop up.
Close the Cyberlink Registration pop-up and shut down the program.In Windows XP, Go to "Start" > "My Computer" > "C drive".
In Windows Vista and 7, Go to "Start" > " Computer" > "C drive".Click on"Program Files" > "Cyberlink" > "Power DVD"> OLRSubmission".
Right-click on the "OLRSubmission" folder and choose "Rename".
Type"Submission" in the box and press "Enter" to set the name.
This will disable the pop-up.
on Mar 03, 2011 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
How do i use cyberlink
Am not so sure if Cyberlink power dvd is capable of copying disc. I believe this software is just for video playback.
To copy pictures from a disc just navigate to My Computer then select the DVD Drive. Right click on the DVD Drive/optical drive then select open.
From there right click on the file or folder that you want to copy then select copy. Paste it to a folder on your computer.
hope this helps . . .
Apr 06, 2010 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
I recently downloaded power 2 go 6 but now want to uninstall it but wont let me keeps being used by another program or person
restart and try again.
if that doesn't work, hit Ctrl+alt+delete and find the program in the list, and end it.
Oct 12, 2009 | CyberLink SW- DVD Software Power DVD...
Need activation key
Contact Cyberlink. Power DVD 9 is a paid for program, and they will help you through any support issues you have.
Aug 31, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Whenever I try to burn a DVD it says invalid folder
Go to control panel and then go to install and uninstall programs. look for the program and reinstall the program of your choice and try to durn dvds if that does not work you may to get another program.
Aug 26, 2009 | CyberLink PowerProducer 2 for PC
Dvd doesn't work, audio cd not recognized by the system
Your DVD drive lens needs to be cleaned by a lens cleaner...
Jun 12, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Computer/DVD
first try to update your windows an try if not use 3rd party software to uninstall. i.e.TuneUp Utilities 2007
Mar 15, 2008 | Computers & Internet
Unable to install a new powerdvd version
I imagine that it's trying to uninstall the older version to install the newer one, which it can't. NOTE: This is a desperate step. Delete the Cyberlink folder in C:\Program Files\; Go to Add/Remove Programs and attempt uninstall - it will say it can't uninstall, and ask you if oyu want to remove it from the program list. Click yes. Go to start->Search (or Find) and search for Cyberlink (make sure that Hidden and System files are being searched). Delete all Cyberlink files. Do the same, but with PowerDVD. Download and run CCleaner. Attempt to reinstall PowerDVD.
Nov 09, 2007 | CyberLink SW- DVD Software Power DVD...
Computers & Internet Logo
428 people viewed this question
Top CyberLink Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
