Question about Refrigerators
I am having trouble with the ice maker. Too much water flows into the maker itself. At the advice of the Sears Service dept. I put a new selenoid in it, which did not help, I turned the white fill adjustment screw clockwise which also has not helped. I did notice a small spark when it began and ended the water filling. Is the motor bad?
    President:
  • 1,462 Answers
If the water is overflown inside the icemaker then it could be issue with the inlet water assembley...
Think it seems to be malfunctioning. i recommend testing for proper functions. This could be a mechanical failure.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush
or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Please leave me comment, if you need further assistance
THanks for using FixYa!
Rnj VINODKUMAR
Posted on Nov 14, 2009
Does not make ice
Either the ice maker is not calling for water or the ice maker water valve is not working, there are many different types of water valves so its very dificult to tell you what to do without a model number or picture of the valve, but generaly speaking if you VERY CAREFULLY put 120V to a water valve it should open and alow water to flow, you can try this for the valve that has a water line going to the ice maker and see if it lets water go to the ice maker, sometimes there are two valves that must open, one main valve and then another for either the water dispensor or the ice maker. a better first test might be to test the water valve for resistance across the coil and compair it to another coil and see if its close-ish. also you can test some ice makers and see if they are putting 120V to the water valve by bypassing the bimetal and causing the ice maker to go into a cycle, but again a model number is required to know what kind of ice maker you have., even a picture would help
Feb 08, 2013 | Kenmore Sears Tempered Glass Shelf Refrig...
Ice maker won't fill with water
There is a soleniod near where the ice line hooks in, Take it off and clean it with hot water and soap, if that does not fix it it may be bad
Jul 31, 2009 | Frigidaire FRS26R4A Side by Side...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
SELENOID WONT RESPOND TO LET WATER FLOW THROUGH TO ICE MAKER IN AMANA REFRIDGERATOR ON ITS OWN BUT IF I RUN POWER TO IT DIRECTLY IT WILL ACTIVATE AND WATER RUNS NO PROBLEM
your module has gone out on ice maker. it is not calling for water on its own. you can replace this for around 80 dollars or the entire ice maker cost around 150
May 01, 2009 | Amana ARS2464B Side by Side Refrigerator
Replaced icemaker with new one but still not working
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
No water comes automatically to the ice maker
What you need is a new ice maker the front gear is not engaging the contacts, you can buy the front module only ( what u put the wire in to on the l & v contact ) but a whole new ice maker assy is the same price.
Jan 10, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice maker does not work
the lighs are normal if you have no ice then is something else ok remove the cover infron of the ice maker there you should see the the ejector it looks like spikes or forks ok they should be facing you if they are facing down into the mold then you have a broken module in ice maker now there isa fill tube on your right that fills the mold with water squeeze it is hard or soft if hard then is frozen keep it from filling the mold de ice it with hair dryer or unplug unit for a day or so . next if spikes are facing you and there is no ice then you have to trouble shoot the water valve at the back of unit there are 2 selenoid 1 for dispencer and 1 for ice maker locate the one for the ice maker and apply 12o volt directly into selenoid if you get no water replace it. if you get water repl optic board that is the red lights ok
Nov 28, 2008 | Refrigerators
No water to the Ice Maker
sorry to hear that i hope i still can help check the fill tube that fills your ice maker see if it is frozen if it defroated with a hair dryer if there is no frost then you might have a bad water valve you see there are 2 selenoids on valve one for dispenser and the other one for the ice maker so if you don't get water it could be the valve look at the ice maker are the forks pointing up or down if they are down then you have a bad module on ice maker that is the front part of it. if they are pointing to 1oclock then check valve and tube
Oct 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Apr 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
