sounds like your laser is failing. You can find tutorials on how to adjust, clean or replace your laser. Do a google search for " ps2 disc read error " it will give you a choice of plenty of tutorials to follow. Good luck
What you need to do is take you ps2 apart and clean it out and clean the laser lens that reads the cd's...you should be able to google ps2 disc read errors and get videos to help you through it.
Disc read errors are mainly due to worn out lens or dirty PS2 lens.Clean your PS2 lens to get rid of this problem if your lens is dirty.Watch this video it will help you to know how to clean your PS2 lens.Watch it carefully.
Remember to keep your PS2 in Dust free environment if you don't want your PS2 lens to get dirty. Thank you!
Disc Read Error is mainly due to worn-out,dirty lens and it can also appear because of the disc that you have inserted in your PS2...... Try following to get rid of DISC READ ERROR:
Clean your PS2 lens:
Watch this video first
This will help you in cleaning the lens.You can also clean your PS2 lens by some lens cleaning DISC.Make sure not to touch lens with your hand.
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
Now this is strange PS2 hangs up..............!!!wHich pS2 u have.........???slim or the old fat one.........???As far as disc read errors are there, u should clean ur lens by using some lens cleaner CD or do it manually[for fat one] urself it not a big deal........becarefull while opening the cover....clean the dust on lens with the tissue or any other light material......the problem can also b with ur disc change that also...........
