Question about Toys
Samsung mobile keeps bringing up 'select USB mode' on the screen and will not go away. Not sure if i have to chose one of the 3 options?? but want it to stop doing it - any ideas?? Samsung soul SGH - U900
    Sergeant:
  • 297 Answers
Reset ur phone setting
Posted on Nov 14, 2009
Do not remember pattern passcode for locked screen of galaxy Samsung s j. How can I reset or bypass locked screen to reset
Here i provide how to unlock galaxy with hard reset. this will erase all your data from galaxy mobile.
1. Press volume up , home and power button.
2 This will provide you 6 option including hard reset wipe data. this is fourth option.
use volume down button to select wipe data factory reset and confirm it by power button.
3. this will hard reset your galaxy mobile this can unlock only screen lock.
4. when hard reset completed select reboot system now.
5. After system rebooted it will not ask for screen lock password.
if you want to sim unlock your galaxy mobile here is the guide.
Howto network unlock samsung galaxy s7 edge
May 04, 2017 | Samsung Cell Phones
How do I text with Samsung Gusto 3 flip phone.
Create and Send a Text Message - Samsung Gusto™
  1. From the main screen, press the left soft key to choose Message.
  2. Select New Message then press OK.
  3. Select TXT Message then press OK.
  4. Enter the desired 10-digit mobile number(s) or email address(s) then press OK.
  5. Enter the message.
  6. To add a graphic, animation or sound:
    • Press the right soft key to choose Options.
    • Select Add then press OK.
    • Select a category (Graphic/Animation/Sound) then press OK.
    • Select an item then press OK.
  7. Press OK to choose SEND....
  8. try this.
Nov 22, 2016 | Samsung Cell Phones
The display does not show, so i can't program the unit.
  1. Go to Settings on your mobile device Menu.
    Select Developer Options.
    To the right at the top of the screen is an On/Off virtual switch. Move the slider to On. There will be a check-mark pop up if it is turned on.
To turn on the USB Debugging on a Samsung 4.2.2 or higher
  1. 1
  2. 2
    Click More Menu.
    It is located in the upper right area of your screen.
  3. 3
    Click on About Phone
  4. 4
    Now, at the Android Build Number on your Samsung mobile device tap seven times.
    This will activate the Developer Mode.
  5. 5
    At Developer Mode select Developer Options.
  6. 6
    Tap the USB Debugging.
    It will turn on, and a check-mark should pop up to the right of USB Debugging.
Mar 25, 2016 | Breadman Kitchen Appliances - Others
My laptop after beeing in ibernation can't wake up. The hard drive starts for 2 seconds and stucks. On the screen there is only a dash that disappear afte a bit of time. Some suggestion, please! Is it...
when you start it up hit the f8 key a few times right away and it should bring up your boot options page and chose your method for start up start in safe mode to keep options down to a min. and it will only load mandatory winsys drivers and soft weare. good luck
Sep 26, 2013 | Acer ASPIRE 8935G-904G100BN LAPTOP LCD...
Prostart 6 button in sleep mode
Sleep mode is a convenient power-saving feature used on both laptops and desktop computers. This feature powers down hard disks, monitors, wireless devices and any other power-consuming peripherals without turning the unit completely off and necessitating a reboot. Sleep mode can prevent battery drain if using a laptop or mobile device while away from the power supply. This mode is useful when quick access to a computer is needed, but can be irritating if the sleep mode takes a long time to come back from. It is simple to turn sleep mode off, based on the operating system being used.
Go to the "Start" button, then click on "Control Panel." In the control panel screen, click "System and Maintenance," then click on "Power Options." This brings you to the "Select a power plan" page. From the "Select a power plan" page, select the option that says "Change plan settings." This changes the settings on the currently selected plan. Select the "Change advanced power settings" option. Click "Sleep" and then click on "Sleep After" to expand it. If using a laptop or mobile PC, click "On battery" and "Plugged in," then select the "Never" option. This turns off sleep mode for both battery and AC use. If you are using a desktop computer, click "Setting," click the arrow and then click "Never" to turn off sleep mode. Click "OK," then click "Save changes" to save the modification. b> Turning Off Sleep Mode - Mac OS b> Click on the Apple logo at the upper left corner of the screen to open the menu and select the "System Preferences" option. From the "System Preferences" screen, click on "Energy Saver." If you are using a desktop, select "Power Adapter" in the top drop-down menu. In the second drop-down menu, select "Custom." Highlight the "Sleep" tab, then adjust the top slider to the far right, marked "Never." I f you wish the display to stay on, adjust the bottom slider to "Never." Click the red button on the upper left side of the "Energy Saver" screen. If you are using a mobile product or laptop, follow step 2 and select "Battery" from the top drop-down menu. Repeat step 3 to change the settings for battery use. Hope this helps.
Jan 09, 2013 | Computers & Internet
How can I connect samsung gt-i5801 with my Laptop for Internet usage
What you need is USB tethering.
USB tethering
You can set your device as a wireless modem for PCs and share your device's mobile network connection via USB.
1 Using an optional PC data cable, connect the multifunction jack on your device to a PC.
2 In Idle mode, open the application list and select
Settings ? Wireless and network ? Tethering.
3 Select USB tethering to activate the USB tethering feature.
Your device will share the mobile network connection on your PC.
To stop sharing the network connection, clear the check box next to USB tethering.
The sharing method for the network connection.
The manual is here
http://downloadcenter.samsung.com/content/UM/201106/20110614142414209/GT-I5801_UM_SEA_Froyo_Eng_Rev.1.1_110601_Screen.pdf
Nov 13, 2010 | Samsung Computers & Internet
Pc is not detecting my cellphone .
When you connect your mobile to pc, you willl get options for selecting phone mode and pc mode/usb mode. Select pc mode/usb mode and it will detect your handset. Do you have pc suite installed for samsung star on your system. If not then please install it with cd you got with handset or download it from internet.
Jul 16, 2010 | Samsung Star GT-S5233 Cell Phone
Turning flight mode off
This guide shows you how to turn off this irritating Flight Prompt:---------------------------
  1. In the Menu screen click on Settings
  2. In the Settings screen make sure the General tab is selected at the top then scroll down and click on Flight mode
  3. In the Flight mode screen the Show at start-up option is selected. Click on Don't show to change this
The next time you restart your phone you won't be prompted to choose between Phone or Flight mode. To bring back the prompt return to Settings - General - Flight mode and change the option back to Show at start-up.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Sony Ericsson K850i Mobile Phone
Menory card
How to connect your memory card with PC. Here's what u do:
1.In your mobile, go to Menu, then Settings, then Phone settings.
2.Scroll down to Pc connections.
3.Select "Mass storage" option.
Next time you connect your mobile to the PC via the USB, open Samsung Studio. Samsung Studio will automatically detect your memory card and then you can start transferring files.
Another simpler method is when you connect the mobile via the USB, go to My Computer. Click on Removable Disk. Then it's just a matter of dragging and dropping files from there on.
Note: When connecting your mobile, make sure it is in Idle Mode (i mean in the main screen mode)
Hope this helps.
Thanks for using Fixya...
Aug 28, 2009 | Samsung Modem Configuration Software...
Samsung mp3 player YP U3
take your mp3 off the usb and go into the settings, you should find settings for the usb connection , ,, one of the options should be highlighted , chose the other one and try again,,,, your mp3 was set to charge only just pick the other setting and it should work. that happened to me once
Aug 17, 2009 | Samsung YP-U3 MP3 Player
Toys Logo
622 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
