Question about Danby Portable Air Conditioner
Water light on where do you drain the water out of con.
    Scholar:
  • 111 Answers
Most Portables have a small drain tube at the back lower portion of the unit, sometimes there tucked away, so just inspect the area towards the bottom and back of the unit and look for a little tube, sometimes there is a cap on the end that you simply pull off and drain the excess water out of the unit.
Good Luck!
Posted on Nov 14, 2009
I have a moretti elite portable air con and it's not blowing cold air it's second hand and a red light is on saying water full
Air conditioners remove humidity or water first, look for the bucket inside and drain it. or it is plugged and not draining.
Nov 16, 2014 | Heating & Cooling
Water in the footwell on a s type jag
has it got a sunroof if so get the seals checked also windscreen seals checked nothing else it could be as far as im aware no pipes running along roof
Sep 26, 2012 | 2000 Jaguar S-Type
Water in the footwell????
air con evaporator drain pipe blocked or missing. condensation forms on evaporator and and must be ablr to drain out under vehicle. if drain blocked water will build up and leak into foot well. if missing water will drain directly into foot well.
May 20, 2010 | 1999 Volkswagen Passat
Water is backing up in the trunk of my 95 celica converable
there are ussually rubber plugs in the bottom,if not use shop vac to remove water and fix leak check antenna if its metal and at the rear panel,other areas to check are the rear tail light gaskets.also look at tail mounting holes.
May 18, 2010 | 1998 Toyota Celica
Fujitsu split system air con leaking inside the house from the unit
The drain pipe must be plugged up or bent. Lift cover of unit and look for water in the tray, find drain hole and remove obstruccion inserting a piece of wire. Be gentle and careful. After the water in the tray drains out, pour a glass of water in the tray to rinse it out and make sure the drain pipe is completely clear.
While you are at it, clean the air filter of the unit.
Good Luck
Mar 07, 2010 | Electronics - Others
Why is there water dripping from the air con?
The most probable cause is a clogged drain line.
Also ensure your air filter and the evaporator coils are clean.
Let us know if this helps and good luck.
Feb 24, 2010 | Heating & Cooling
Where is the drain pipe on Suzuki air con
Hi are you sure its to do with your air con, normally when your carpet gets wet it means your heater matrix has burst, thats always been my experience. hope this helps thanks John.
Nov 24, 2009 | 2006 Suzuki Vitara
Whirlpool Air Con Drainage issue
Yes, there should be a place for the condensate to drain outside. It's apparently clogged and the drip pan is overfilling. Look for a tube or an opening outside where the condensate should be exiting. This needs to be unclogged.
May 31, 2009 | Whirlpool Electronic Window Air...
Danby Portable Air Conditioner Logo
536 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
