Question about Intel Motherboard
No video on start up
No video on startup from new motherboard
  • DYRON REDDICK Jan 11, 2008
    Motherboard will not show video from the built in VGA or an add on video card. I get no beeps from the system this is why I'm so lost on what the problem may be.
  • 1,226 Answers
Do you use add on VGA card or main board built it.
If you use add on card u need to set it in the bios using the built in VGA b4 u can use add on card.
However if you use built in VGA; try to fixed well the processor and then the memory. If the system beeps during start the memory is not fixed well or it is damage.
Posted on Jan 08, 2008
  • Emelio Navaja
    Emelio Navaja Jan 24, 2008
    Do connect all the power cord on the board. the four pin power near the processor please connect that power cord that is 2 yellow and 2 black color.
    maybe this is only thing that mess.
Brand new, has never worked, fans run, first time installed ran the I Will cd that went fine then nothing
Hi ;) Sound like you got a bad driver file loaded can you go in in safe mode or when the computer first starts up in WindowsXP hold down the F8 key to go to the startup list and pick VGA mode and that will load with default video drivers.
Updated Bios file
Mar 13, 2011 | Iwill KK400 Motherboard
I attach my monitor and turn the machine on and I get a black screen. When I pull the monitor cable out of from the monitor connection on the motherboard I get a color display on the monitor. What is...
When you disconnect the monitor cable, the display you see is from the monitor itself. It's telling you that the monitor has power and is working, but that you don't have the cable connected to your computer. So the trouble is in your computer, which isn't sending anything to the monitor.
Your computer may not be starting up when you turn on the power. This is pretty common, and may be due to a bad power supply or system board. Or something may be wrong on one of the devices connected to the motherboard (one of the drives or a card plugged in to an expansion slot). You'll need to figure out what is keeping the computer from starting. The easiest way is to unplug all devices from the motherboard except for the power supply and try starting the computer. If the computer starts up you'll know that one of those parts you disconnected is at fault.
Another possibility is that the video card (integrated video on the motherboard in most computers, or a separate card) isn't working. The computer may be starting up and getting in to Windows, but you just never get any video to the monitor. If you are hearing all the sounds of a normal startup (disk drive activity and then finally whatever startup sound your Windows makes), then you need a new video card. If the board has integrated video you just need to install a new plug-in video card of whatever type fits the available slot on the board.
Good luck and thanks for using Fixya!
Dec 14, 2010 | FIC VL35G Motherboard
The motherboard starts up with fans spinning but monitor gets no signal and cant turn off motherboard
If your fans power up but you see no image, then your computer has failed its startup test.
Now you have to find out what the problem is.
Start by opening the case and disconnecting everything but the keyboard, CPU, memory, and video. Now try to start it. If you still have no signal, it might be your video card if the monitor shows a message telling you there is no signal. Memory could also be a problem.
If you get a message telling you there is no boot device, then turn the computer off (push in the switch for about 7 seconds) and connect the hard drive. Now try to boot. If it works, then suspect the CD drive.
If after doing all this you still get no signal no matter what you do, and if the video is part of the motherboard, you're probably looking at a new motherboard.
var fctb_tool=null; function FCTB_Init_b6f227197c554533aa0da572889177d1(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_641fd7d97ec64dd1b4f68e2bce8bfd6f(t) { fctb_tool=t; start(fctb_tool); }
Nov 29, 2010 | Gigabyte GA-8S661FXM-775 MATX MBD SIS661FX...
No GUI on startup.
Try a repair installation.
Is this an illegal copy? If it is, it may have virus or malware problems.
Jul 22, 2010 | Dell Inspiron B120 B130 1300 / Latitude...
At the startup "video out fo range"? what to do
can u start it,if you can,remove drivers,and instal new one,and set refresh rate that is recomended for your monitor.....
Apr 08, 2010 | Mercury KVM400M-U Motherboard
My pc boots but no video is displayed so my only guess it the onboard video on the motherboard is faulty. can i buy another video card and remedy the problem?
You can indeed install another video card, but this may not be your trouble. Are you absolutely sure your computer is running normally except for the video? That is, do you hear all the other sounds that usually go along with normal startup (hard drive activity, Windows startup sounds through the speakers, etc.)? It's very unusual for a motherboard to fail so that everything works except for video out to the monitor. You might be facing a computer with some other issues, like memory or a deeper motherboard problem, causing it not to start.
If you do decide to install a new video card, be sure you get one that's compatible with the motherboard (proper type connector) and power supply (not a super whiz-bang card that may need more power than your current supply can provide).
Mar 27, 2010 | Computers & Internet
NF7-S2 No POST on startup. Can Not get into Bios
In that case the motherboard itself is faulty replace it..
Jun 08, 2009 | Abit nForce2 NF7-S2 Motherboard
No video at startup
The beep code you mentioned is either a video problem or RAM problem, that is what the beeps mean. Check your RAM one by one in case you got a bad stick, making sure they are properly seated in the slots. Since a new video card did not slove the problem then it also could be a motherboard issue, video slot dead. If your motherboard is still under warranty contact the manufacturer to see if they'll send you a new board. These are the common problems for the symptoms you describe. Hope this helps.
Apr 24, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
I put my 3 0 ghz cpu in my Gateway Intel 850 Socket 478 ATX Motherboard no video from agp is new board with 2x 256 rimm pc 800 pc seems to start all the fans as well new power supply 512 ati vid card but...
Remove the BIOS recovery jumper near the battery on the motherboard and attempt to boot. If the system displays a startup screen, replace the jumper on pins 1 and 2 (pin 1 will have an arrow by it) and configure your bios appropriately.
Mar 16, 2009 | Computers & Internet
Cannot get the option to enable VGA through using F8 at windows S
Sometimes after changing BIOS settings the computer will not start or will possibly give error messages similar to yours. I have at times had to remove the power source, remove the motherboard battery, and set the motherboard back to factory default settings. You also stated that you installed a new motherboard. That could also be a potential problem. If the computer has never started with the new motherboard, the new board may be defective.
Dec 18, 2008 | Dell Latitude C640 Notebook
Intel Motherboard Logo
50 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
