Question about Targa ProEdit T3K 6221A PC Desktop
Unhealthy noiser when starting - disappears aftr
Unhealthy noise when starting - disappears after several minutes - cooling fan?
  • 3,153 Answers
Please DO NOT spray any type of silicon or grease on your fan !
These types of spray ATTRACT dust and will acrually make the issue worse.
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
While you are in there just check that the CPU cooler itself is not loose
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem they have to be cleaned and new thermal grease put on ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off with anything metalic (fingernails are OK). Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are
some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
Posted on Nov 14, 2009
  • Project NOMAD
    Project NOMAD Nov 14, 2009
    If its not the CPU cooler then it would be the power supply fan.
    If you understand how to remove the fan and replace it then they are quite cheap to do yourself.
    BEWARE of possible high voltage in the PSU even after being switched off !
    If you don't then the next best option is a replacement power supply as these are quite cheap too and very easy to replace the whole unit.
    If you replace the whole PSU select one that has a higher capacity than the one you are using.
    EG if your PSU is a 350 Watt then a 400 Watt or higher will be better in the long run.
Your cooling fan has dust on it. clean and spray some silicone or even spray and cook should solve it, check to see if fan guard has not been banged and fan catches on this guaqrd>
Knocking sound in Engine of Kia Sephia when driven longer.
It sounds like valve train noise. The best thing to do is have the dealer listen to it and see what the preliminary diagnosis is of the nosie. Is the engine full of oil and it has been changed on a regular basis or at least every 5,000 miles.
Sep 13, 2012 | 2001 Kia Sephia
Ticking clacking noise gets a lot louder when air conditioning fan is turned to high, is this normal?
look at your idler pulley since the ac clutch runs on the serpintine belt its moving alot faster the berings are prob bad in it takes 10 minutes to take off and 17 dollars to replace n another ten but if you take it off spin it in your hand if its rubbing n stopping fast(should spen fast like a skateboard wheel) then its bad that could be all it good luck hope this helps
Aug 26, 2012 | Chevrolet Cars & Trucks
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
There is a whining sound upon powering up my HL-P6163W which softens after about 5 minutes, but doesn't disappear completely. I think the source is either the color wheel or the cooling fan. How can I...
It the Colors wheel,cooling fan will shut down,if it start making noise to the fan,because the whole projection egine and the bulb link to it.The fan have to run a certain RPM to keep the tv running without problems.These colors wheels run 1000 RPM to start to give the tv colors and it make out Flexy glass and plastics.What ur opinion,who will give u the problems,first as parts wise.Ok any noises like whinning in the tv alway the colors wheel starting to buckle and warp.Getting worse make motor noises and briddles enough will brake and shatter it into ten of hundred of pieces.Who know,than inside what else will cause the rythum of the RMPS running of the tv,when u replaced it.
Jul 31, 2010 | Samsung HL-P6163W 61" TV
Cooling Fan Spinning Fast On A Cold Start
most fans are clutch fans and they work or are engaged by temp.most all will spin under really cold conditions.this is normal.but to be sure, with the motor off and key in your pocket grab the fan and see if it wiggles or has any slop. if not alls good
Dec 20, 2009 | 2007 Chevrolet Colorado (Extended Cab) New...
How to reduce noise of Compaq Presario C700
More than likely, it's just the fan making noise. They get noiser with age due to dirt and dust. Fans are cheap, you probably have one in the computer and one in the power supply. Bet bet is to pick one up at frys electronics or on ebay. They are just a couple of bucks and new ones are very quiet.
Sep 16, 2009 | Compaq Presario C700T Notebook
I know my santa fe, and i started listening a horrible humming
what kind of noise? if rattling noise and noiser when you accelerate, either in idle position or while moving, then you need to overhaul. if high pitch sound and noiser when you accelerate, then check you bearing in timing belt mechanism
Aug 02, 2009 | 2004 Hyundai Santa Fe
CPU cooling fan
Hi...you can press the F2 key to enter setup...and scroll down until the fan is highlited...hit enter and then F10 to save and exit.This tells the computer its OK.
you should have plugged the fan in the same pin port the old fan was in. Usually only 1,.
If the new fan is not from dell..it may be faster and noiser..or it may be faulty..if you bought it locally you may try to return it.
The purpose of the fan of course is to remove the hot air from the CPU to keep it from overheating. If this fan does it it is most likely ok.
Hope this helps..
Squipps
Feb 07, 2008 | Dell Dimension 8200 PC Desktop
Targa ProEdit T3K 6221A PC Desktop Logo
55 people viewed this question
Top Targa Computers & Internet Experts
David Payne
David Payne
Are you a Targa Computer and Internet Expert? Answer questions, earn points and help others
