Question about Sharp AR-M205 Copier
My copier is indicating H4 code and not workiking
  • Sharp Master
  • 1,294 Answers
Please verify the continuty of the heater lamp,and the thernistors circuit.The problem in the fuser circuit,clean the components and let it go,
Posted on Nov 14, 2009
H4 CODE IN THOSHIBA
H4 indicates Heat roller low temperature detection. U need to check the themistor, heater lamp, themostat.
Jul 06, 2012 | Toshiba e-Studio 161 Copier Copier
Please call service h4-00
H4-00 indicates that the fuser unit (right hand side where the hot rollers are) is not heating up. It could be a blown heater lamp or a blown thermal limiter. You can try resetting the code by pressing: #,*,C,*, 1,4, then choose yes or 1. this will reboot the machine. The h4-00 code may return but this is worth a try. Good luck.
Mar 15, 2011 | Sharp AR-M207 All-In-One Laser Printer
Greetings: i have A sharp 1641CS and it indicates
A H4 error code could be the fuser lamp or the thirmister or the thermal fuse. The lamp may cost $20.00 the others may be $10 to 15 dollars each
Jun 16, 2010 | Sharp AL-1641CS Laser Digital Copier
What does 4 H indicate?
When your copier voltage is abnormal then heater lamp is not on properly.So indicate H4.When H4 signal is blinking you must reset this code or error.
press c button press Photo/Exposure button again C Photo.(C>Photo>C>Photo) display blank press copy quantity button 14 press print key /Start key machine will be ready.
All are hopes fix
Dec 27, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Digital Copier AR 5316E error code H4 indicating
An H4 code denotes a low temperature or temperature sensor failure problem with the fuser (the device that provides heat and pressure to bond the toner to paper). There may be a peice of paper or part of a peice jammed up inside the fuser that's blocking the sensor, or the fuser is defective and needs to be replaced.
Sep 18, 2009 | Office Equipment & Supplies
Toshiba e-studio120, H4 error code. what it`s meen??
seems like heat roller problem.
enter code C, exposer light buttom, C and exposer light buttom , then all the indicator in the machine goes off. then enter 14 and press print buttom. Now your machine must work. If not Pls refer to technician.
Jul 08, 2009 | Toshiba e-Studio120 Copier
Dispays h4 error
An H4 error code indicates trouble in the fusing section - a certain temperature has not been reached within a specified time. It could mean a dirty/bad thermistor or dirty/bad thermostat (both inside the fuser unit. Make sure both of these are clean and there is not debris/paper stuck inside the unit.
You can try resetting the code by : Get into SIM mode by pressing the following keys one after the other "#" "interupt" "C" "interupt" then enter 14 and the start key - confirm if requested then make sure the copier restarts.
Hope this helps.
Apr 18, 2009 | Sharp AR-5320 Black and White Copier
H4 for Sharp Copier AL1551 CS
The H4 code indicates the system did not or is not warming up. It could be a thermostat or thermistor or a board problem or a heating lamp issue.
It requires service.
Check the fuser unit for any debris or excessive build up especially around the thermistors - if you can remove and open up the fuser unit !
Feb 18, 2009 | Sharp AL-1551CS Printer
I want a solution for a Sharp AR - 287 Digital Image problem
H4 for an error code on all Sharps indicates that the fusing temperature isn't correct. It needs to have a new thermistor installed or the heating lamps need to be replaced.
Oct 21, 2008 | Sharp AR-235 Copier
Please Help
H4 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-M205 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
