Question about Xerox Office Equipment & Supplies
I received the ff. fault codes this morning and know what to do. I need your help. 14/11/2009 07:45 AM 071-105 14/11/2009 07:45 AM 005-139 14/11/2009 07:23 AM 005-122 My machine is the ff.: Xerox WorkCentre 5225A5225A
  • 14 Answers
SOURCE: Xerox 6204 error 071-103
The cutter assy has a disk with hole in it to tell the circuit board how fast it is turning and where it is in respect to the home position. It may be that this disk or the sensor that looks through it has a lot of paper dust on it and not able to read correctly. It may me the the cutter itself is sticking and needs a little cleaning and oiling.
Posted on Feb 10, 2008
  • 2072 Answers
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Posted on Apr 03, 2008
  • 2072 Answers
SOURCE: xerox workcentre m20i power off
First off try unplugging it and leaving it unpluged for 30 minutes. Not just turned off, but unplugged, then plug it back in and see if it works. There are filter capicitors in the low voltage power supply that sometimes have to sit with power removed for 30 minutes before they discharge and allow the power supply to turn on.
Sounds weird but I have seen it fix a dead machine probably 50 times or more. If that doesn't restart then you will have to replace the power supply. If that is the case let me know and I can tell you where to get it from and ho\w to replace it.
Try leaving it unpluged for 30 minutes. not less than 30 minutes.
Posted on Oct 16, 2008
  • 8 Answers
SOURCE: Good Morning!, I have a
2nd Btr retract error Call Xerox service or go to Xerox.com
Posted on Dec 30, 2008
  • 24 Answers
SOURCE: Service Manual for Xerox WorkCentre m55. URGENT!
Does this link help?
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC_M55&Xlang=en_US&Xcntry=USA
Posted on Jun 10, 2009
Error code for FF for KingAir air conditioner?
Error code FF means the outdoor DC motor fault.
first check the resistance value of the DC motor port, change the DC motor if short circuit.
Nov 08, 2016 | Refrigerators
Refrigerator
all available online
  • Appliance Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair List of Appliance fault codes and Appliance error codes for all Appliance appliances. Free tech support.
  • Refrigerator Error, Fault or Function Codes - GE Appliances www.geappliances.ca/.../refrigerator-error-fault-or-function-codes Fault code Definition; FF: Check frozen food for thawing because the temperature is rising too high. PF: The power to the refrigerator has been interrupted.
  • Fault Codes - RepairClinic.com www.repairclinic.com/RepairHelp/FaultCodeLinks Fault Codes. Our Repair Help is model number driven. Once you provide the model number for your product type we can provide a list of the most common symptoms for ...
  • Related searches for refrigerator fault codes
  • http://www.bing.com/search?q=refrigerator+fault+codes&qs=n&form=QBRE&pq=refrigerator+fault+c&sc=0-20&sp=-1&sk=&cvid=3FD49316383B43288E0AB1ED81167DF7
    Jul 07, 2016 | Refrigerators
    Code ff on portable electric heater. What does code ff mean
    If its a Sunbeam you need to check the electric cord an make sure it is plugged into heater an wall socket well. Really need brand an model to help more.
    Jan 27, 2015 | Refrigerators
    The receiver always goes into protect and im not sure why, it will work for a short time and will then go "off line" and shut off
    Cool down first the unit for about 5mins.Disconnect all input and the speakers connected to isolate the problem. Power it on then observe while playing it naked. If the symptom still there then I've suspect that you have a fault on the FF: 1. Power supply - might have an unregulated supply caused by leaky capacitor. 2. Pre-amplifier circuit - might be faulty. 3. Output IC - IC is leaky which overheat after a minute which trigger the unit to protect.
    This is not diy and need to send to repair shop. If the symptom gone after you played it naked then I've suspect the ff: 1. Short on speaker wire. 2. Short on speaker voice coil. 3. Short on input.
    Thanks for using fixya.
    Jan 27, 2011 | Harman Kardon AVR 335 Receiver
    Hi, got an AMD computer with an Epox EP-8KTA3 PRO motherboard with Apollo bios.It will boot,but wont load O/S and the fault code LED's show FF. I am trying to find a manual to interpret the fault code and...
    I have an EP-8KTA3PRO, Code FF on the LED means "System Booting" the BIOS has passed all Post checks and control has been passed to the Operating system. It stays at FF as long as machine is on and operating system is running. I would suggest the problem is with the operating system, or possibly hard drive corruption? Do you get any error messages on the screen after the Bios checks? you say it does boot? Never Flash the Bios unless absolutely necessary.
    Just in case you get it working you may be interested to know that the manual insists 1GB is maximum memory but that is a lie, I have just installed 1.5GB (3 x 512MB) which is the true maximum. But it ONLY recognises the full 1.5GB if you populate DIMM 0,1, and 3 - leave DIMM 2 empty.
    Good Luck
    SB
    Jul 15, 2010 | Computers & Internet
    Xerox c2424 fault code 37,008.44:54093
    There are two things. I most likely suspect that the print head wiper blade has stuck to the print head. Very common problem after a power failure.
    Not sure how I didnt see your post before now. But if your still having that problem let me know, I can tell you how to fix it.
    Mar 04, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
    Received error message FF on the Kenmore Elite SS bottom freezer in our rental, with no manual....Can i fix or do I need to call Sears? It is the weekend!
    Called Sears, and they are sending out a tech on Monday but then this morning the error message was gone and the screen was normal.....we shall see!
    Dec 04, 2009 | Kenmore Refrigerators
    Sunbeam 4267-000 not turning on just blinking red
    "FF" or a blinking light will display meaning “Fault Found”. The “fault” is in the amount of power available to the blanket, mattress pad or throw.
    There are several causes to this problem:
    1. Bedding product is plugged into an extension cord, surge protector, power strip, or not plugged into a direct wall outlet.
    2. Bedding product wasn't plugged in properly.
    To FIX this problem, do the following to reset your bedding product:
    1. Unplug the power cord from the electrical connection.
    2. Unplug the cord from the actual bedding product itself.
    3. Re-plug the cord into the bedding product. Make sure the connection is secure and complete.
    4. Re-insert power cord back into a wall outlet.
    If the 4 steps above are not followed in order, the bedding product will not properly reset.
    Dec 08, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
    Error Code ER FF
    FF is your freezer fan. You may need to defrost the unit.
    Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
    1,017 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    CheckitRight
    CheckitRight
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
