Question about American Pro Car Audio & Video
A manual and spec sheet 4 american pro ws9210, maybe a box plan how much rms is it
  • Michael Kovalik III
    Michael Kovalik III May 11, 2010
    ported or sealed? mdf or birch?
5 Suggested Answers
Cerfer39
  • 709 Answers
SOURCE: Wires
Hi Gott Mudd,
I can relate to feeling it in the bones. You got the stuff to do it.  You should try the Alpine MP3 head units with bass boost, those are bad to the bone.
Wiring:
Amp to Speaker I like to use the code VC for Voice coil, and AO for Amplifier output.  Also + for positive.  If I say VC1-, I am referring to the first connector starting left to right on the Alpine Sub. Now I have not seen a Kicker KX1200.1 amplifier.  All I see are MRA, MRP, or PDX prefix on the part numbers. So take what I am saying as a guess. You may want to revisit looking at the model of the amp to be sure your giving the right information.
We are going for  2 Ohms. Paralleling the two subs, not the voice coils. The voice coils will be series.  Bridge the amp if necessary to get mono channel. only using AO+ and AO- for output.
AO+ to Sub1VC1+
AO+ to Sub2VC1+
Sub1VC1- to Sub1VC2+
Sub2VC1- to Sub2VC2+
AO- to Sub1VC2-
AO- to Sub2VC2-
Set your Crossover to LPF
Adjust the bass gain down to lowest until you test.
Set the Frequencies to midrange between 40 and 100hz
Your box can be ported or not. It depends on the space your have.  If you do not have much room, go Enclosed and build a box that the inside space is less than 1 cubic foot.  Make sure you give barely  enough clearance for the speaker to fit.  If you have room, Go with a box and vent it with a 3 inch Vent tube 10 inches long.
Posted on Oct 15, 2007
jpenn1192
  • 58 Answers
SOURCE: im trying to find RMS specs for PERFORMANCE TEKNIQUE CBM-5712 SUB
WELL FIRST IF THEY ARE DUAL VOICE COILS, IF SO,TO GET 2 OHMS JUS THOOK THEM UP TO ONE OF THE TWO TERMINALS, IF YOU WANT 4 OHMS HOOK YOUR POWER LEAD TO ONE TERMINAL THEN ABOUT THREE FEET OF WIRE COMING FROM YOUR LEAD TO THE O9THER TERMINAL, IF YOU WANT 8 OHMSHOOK YOUR POWER LEAD TO + ON ONE SIDE THEN THE NEGITIVE LEAD TO THE - ON THE OTHER SIDE, THEN VISE VERSA. BUT IF I WHERE YOU MAKE THEM 4 OHMS
GOOD LUCK
Posted on Dec 12, 2008
Teh_shivers
  • 104 Answers
SOURCE: I need rms spec's for performance teknique CBM-5712,
you will get more power at lower ohms, the lower the ohms the less resistance it will have against the amplifier
heres a small definition if it helps
The ohm is defined as the electric resistance between two points of a conductor when a constant potential difference of 1 volt, applied to these points, produces in the conductor a current of 1 ampere, the conductor not being the seat of any electromotive force.[
Posted on Dec 15, 2008
popsgifts
  • 160 Answers
SOURCE: tring to find WHAT is the rms for my speakers
the XS1010 sub has an RMS value of 150 Watts and a 450 peak.
AP hasn't released the RMS values on the vs2044
Posted on Apr 11, 2010
Need user manual
If the installation instructions is what you need you can get a PDF of that on Menards.com Type the pmfw432r8 in their search and scroll down to below the description info and you'll see links to a product spec sheet and installation sheet.
Feb 19, 2014 | Computers & Internet
Whats the specs
  • Bridged Max Power: 520 Watts
  • RMS Mono: 170
  • Variable Low Pass 40Hz-120Hz
  • Variable Hi Pass 150Hz-1.5Khz
  • THD: 0.02%
  • Die-Cast Aluminum Heat Sinks
Sep 20, 2010 | Power Acoustik XL2-520 SPL Car Audio...
I have a pioneer XL2-520 amplifier. I bought it used. So I didn't get the user manual and the sticker on the bottom of amp is not there.. So I was wondering how many watts (rms) in mono mode at 2ohms....
i think its a power acoustik amp im not sure that was a pioneer model. if it is apower acoustik the specs are
125 rms x 2 @ 4 ohms
150 rms x 2 @ 2 Ohms
300 rms x 1 @ 4 Ohms
You can only bridge the amp at 4 ohms dnt go lower than that
Sep 13, 2010 | Car Audio & Video
I dont have any cosmetic problems with my subs .. but i have 4, 12 inch hifonics olympian subs in one sealed box. and i cant find any specs on them at all.. do you know the watts and rms wattage and how...
look on the bottom of subwoofer should say like olm2412 olm1612 olympus the 1612 is the rms and speaker size 2412 is 2400 rms and the 12 stands for 12 inch subwoofer.i think thair is only 2 modles . also u have 4 u would need a 10,000 rms amp if thay are the olm2412s or 6,000 rms amp to push 4 olm1612. as far as box building info i think you should call maxxsonnics. 847-540-7700 talk to mike
Mar 03, 2010 | Hifonics W-124 Olympian 12" Subwoofer Car...
Straping planet audio vx900d's
Specs
  • VX900D
  • 1 X 375 RMS @ 4 Ohms
  • 1 X 650 RMS @ 2 Ohms
  • 1 X 900 W RMS @ 1Ohms
  • Dimensions 10-1/4" (L) x 2-7/16" (H) x
    Click on the link below. It will take you to the official Planet Audio website. In the search box on the right hand side, type VX900D and it will bring it up. Click on Download and it will download the installation manual for VX900D including a diagram on how to strap (on Page 9).
    Remember that you must only run on a min load of 2 ohm when strapping or you may damage the amplifiers and void you warranty.
    http://www.planetaudiousa.com/support/index.php
  • Nov 04, 2009 | Car Audio & Video
    How much rms dose an american pro vs 1409 put out
    I used to have a similar model, vs1405, and it was advertised to have 600w max. Its rms ratings were 260w bridged @ 4ohm. and 80x2 @ 4 ohm.
    So I really wouldnt expect much.
    I would personally suggest the HiFonics Brutus. Very nice amps for the price, and have TONS of power.
    Oct 26, 2009 | American Pro Car Audio & Video
    I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
    Hi mate very nice amp you got there here is the specs for it
    Model: MA Audio HK401SX
    Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
    1 x 1800W RMS @ 0.5 Ohm Mono
    1 x 1200W RMS @ 1 Ohm Mono
    1 x 650W RMS @ 2 Ohm Mono
    1 x 500W RMS @ 4 Ohm Mono
    Fully Unregulated MOSFET Power Supply
    2 Ohm Stable @ Mono
    1 Ohm Stable @ Mono
    0.5 Ohm Stable @ Mono
    if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
    Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
    Trying to figure out what kind of amp i got amercian pro vs-3507?
    The VS3507 Is a class D monoblock.
    Your optimum wiring for this amplifier is a 2 Ohm load - so it produces its full potential power of 350W RMS.
    To Achieve a 2 ohm load, the most common load is one of the following...
    (1) Dual 4 Ohm Voicecoil Subwoofer Wired in Parallel.
    (2) 4 Ohm Voicecoil Subwoofers wired in Parallel.
    (1) Quad 2 Ohm Voicecoil Subwoofer wired in Parallel/Series.
    (1) Single 2 Ohm voicecoil subwoofer.
    American Pro VS3507 2000W Car Audio Monoblock Amplifier
    American Pro VS3507 Monoblock Amplifier Details
    • Built-In Crossover
    • Variable High/Low Pass Filters
    • Phase Shift Control
    • Subsonic Filter
    • Bass Boost Control
    • Dancing Lights at the Rhythm of Music
    • Protection Circuits
    • Gold Plated Terminals
    • Power & Protection Circuit LED
    • 1 x 250 Watts RMS @ 4 Ohms
    • 1 x 350 Watts RMS @ 2 Ohms Thanks for using FixYa - A FixYa rating is appreciated!!
    Jan 29, 2009 | American Pro Car Audio & Video
    Car audio
    depends on what sort of amp you have iv got american pro 1407
    Jun 01, 2008 | Car Audio & Video
    Car Audio & Video Logo
    91 people viewed this question
    Top American Pro Car Audio & Video Experts
    xxxxxx xxx
    Are you an American Pro Car Audio and Video Expert? Answer questions, earn points and help others
