Question about i-mate Jama 101 Smartphone
When i will put battery blue screen and red light only shown it will not connected to window
    Sergeant:
  • 297 Answers
Reinstall sa software older version is damaged
Posted on Nov 14, 2009
The image color on projection is not the same as shown in laptop. There's is no red color.
It could be a broken connection in the computer lead for the red signal, or a fault on the projector that the red panel doesn't work any more.
To diagnose, bring up the projector's on screen display. If there's white in the menus then the problem is the cable. Replace it with a new one. If the menus are affected too then it's a projector problem. This requires the attention of a service engionner.
Aug 20, 2014 | Toshiba Tdp-s25 1080i 720p Hd Dlp...
Strech it is a dash mounted I have five gallon fat bobs key switch in middle
The BLACK wire (that you say you know goes to the battery), would be the HOT lead, shown as a TAN wire in the diagram.
Per the diagram, it actually connects to lug #1 on the STARTER RELAY.
As far as the RED and BLUE wires, you need to figure which is for the lights, and which is for the ignition.
My GUESS is RED's the ignition, and BLUE is the lights.
If your switch is a THREE position (ACC, OFF, IGN), it might not matter, as these switches are set up to run the lights whenever the ignition is on.
The older FOUR position switches (ACC, OFF, IGN, LIGHTS) are so you can manually select if you want to run the headlight or not, and would also have a fourth wire coming off the switch.
Feb 10, 2014 | Cars & Trucks
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
The Wii turns on but the remote won't connect to the screen...all lights working also, bought a new sensor bar and still nothing...???
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
Hope this helped!
May 16, 2011 | Nintendo Wii Console
Flickering bulbs
You posted under EJ500 Intermatic battery-operated timer.
If you have different timer, add a comment.
I have tested EJ500 timer.
A) If this is new single-pole installation and lights click on-off when timer turned on, then you connected red wire where blue wire should be connected.
Manual says for single pole switch:
Timer-black-wire to Hot; Timer-blue-wire to Load (lights)
Here's how to wire timer correctly:
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-blue-wire. Choose either one for now.
3) Put wire nut on red wire.
4) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-blue and timer-black wires.
B) If you are replacing 3-way switch, view wiring diagrams shown on link below, and then add a comment saying exact color of wires. To wire this timer for 3-way can require additional wire between switches. This is because EJ500 blue wire must always go to Load (light, fan, motor)
http://waterheatertimer.org/ST01C-program.html#EJ500-wire
C) If this is older timer that stopped working, check your bulbs. Then check timer battery. Manual says if timer stops working and bulbs are good, and battery good, then reset timer and reprogram. How to reset timer. Press reset button while holding down Next/ON-OFF button.
EJ500 manual has long list of programming instructions: Add a comment if you forgot parts of programming.
EJ500 manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej500c%20-%20english.ashx
Nov 28, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
My Samsung R530 Laptop`s screen does not come on. There is a red indicator light on 2nd from right (next to the blue light that indicates the power is on) What does the red light mean?
first cut the power of ur laptop and ,disconnect the battery ,
again connect battery and connect adptor and power on u laptop
if problem is not solve,
connect crt/tft monitor through vga port,
if laptop give display , then chk ur function of laptop with fn button.
Sep 16, 2010 | Samsung R530 Notebook
My Sansa e250 has hanged and only wheel light gets light is I restart the player....Plz help !!
Battery and Black screen Blue ring: Remove the back and check and see if the battery isn't fully connected
push softly but firmly on the Rubber rectangle above the battery (This is the Chip-set For the screen, and memory "Black screen Blue ring" ) and put the back on.
Jul 25, 2010 | SanDisk Sansa e250 MP3 Player
Why wont the screen turn on but the wheel lights up, how can i fix it?
I put a folded peace of paper and put it on top of the battery also push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screen, Black screen Blue ring ) and put the back on.
Jun 28, 2010 | SanDisk Sansa e250 MP3 Player
I RECENTLY PURCHASED A 1994 bIG SCREEN TV ( mODEL # TP55C81 ) THE PICTURE IS PURFECT BUT IM SEEING THE RED GREEN AND BLUE LIGHTS . THE CLOSER I AM TO THE TV THE SMALLER THE LIGHTS ARE AS I BACK UP THE...
You have a projection TV - basically a red, green, and blue spotlight is shown onto the back of an opaque screen that creates the color picture you see. The spotlights you are seeing is common for a TV of this vintage and type.
According to the user's manual, you should ideally be sitting no closer than 10 feet to the screen.
Sitting closer to the screen may enhance the phenomenon you are experiencing.
Nov 19, 2009 | Toshiba Televison & Video
i-mate Jama 101 Smartphone Logo
87 people viewed this question
Top i-mate Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you an i-mate Cell Phone Expert? Answer questions, earn points and help others
