Question about Panasonic Televison & Video
U88 displayed on dmr es15 panasonic dvd recorder. cant play ,wipes discs ,makes grinding noises
Took off casing ,removed dvd unit. The laser runs along 2 metal spindles which i lightly oiled with wd 40. next to it runs another brass spindle which i also oiled. Re-assembled , and the machine is good as new.
Posted on Nov 16, 2009
Can't play recorded DVD-R on DMR-ES15. Keeps saying disc incompatible. Why?
the recorded program might not compatible video format of your dvd player, tried to convert in other video format.
Nov 12, 2012 | Televison & Video
DVD optical drive does not play all dvds all the time .one time it will play(same DVD)next time it won't.Also sometime finalize failure.Finally tray will not close w/dvd in the tray(sometimes).Is there a...
It sounds like the DVD-RAM drive is about dead. Panasonic did not make them to be very durable.
Panasonic sells replacements at a high cost.
Replacement drives may work from used models including:
DMR-ES15
DMR-ES25
DMR-ES45
DMR-ES46
Oct 01, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
Panasonic DMR EH56 permanent U88 Error on DVD- and HDD-Drive
displays when ther was somthing unusal detected with the disc while recoding playback or copy this is diplayed when the unit is in the recovery process to return to normal operation the unit is not broken once the display clears you can use the unit again
Jul 14, 2009 | Panasonic DMR-E55 DVD Recorder
DMR-ES15 Stops after 45 Min.
U88 means the unit has detected an error while recording or playing and has entered its recovery process to restore the unit to normal operation. You could try using a DVD-RAM disk or a different make of DVD-R but, as you say the unit is new, you should probably return it to the retailer for exchamge, repair or refund according to unit age and retailer's return policy.
Nov 03, 2008 | Panasonic DMR-ES10 DVD Recorder
Dmr-es15
My DMR-ES15, dvd recorder is showing a U-61 code, I'd done all the instructions on my user manual. I think the problem is lost of memory. How can I get it back working. If I have to change chip of memory what is the part No., and how much will cost me in US dollars. Thanking you in advance.
Sep 06, 2008 | Panasonic DMR-E80H DVD Recorder
Panasonic dmr es15 dvd recorder
My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
Aug 30, 2008 | Panasonic DMR-ES10 DVD Recorder
U88
the dvd disc you are using is copyright you cant copy the disc.. "the disc is encrypted'
Feb 07, 2008 | Panasonic DMRES15 DVD Recorder
Panasonic DVD Recorder Model DMR-ES15
For the unit to be confirmed if its o.k or not You have to take disc which is not very knew and slight scratches ,offcourse which is playing in your other dvd player.Play it on dmr-es 10 see if it plays normally,if it does than its lens is o.k.Other thing you can try is insert blanck disc and try formatting it,if it does than it s o.k.Try R+,R- AND RW+,RW-.iF This disc can be formatted on dmr es10 than the unit you can decide to purchase
Dec 18, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmr-es15
Pan. DMR-ES15 I WILL NOT RECOGNIZE ANY DISC I PUT IN. WILL NOT PLAY A COMMERCIAL DVD MOVIE. SEEMS TO HAVE STARTED WHEN IT COULDN'T FINALIZE A RECORDED DISC. HOW TO RESET?
Oct 28, 2007 | Panasonic DMR-ES10 DVD Recorder
Model No'DMR-ES15 - U61problem
I get this message occasionally on my Panasonic DMR-ES15. It's actually a really simple fix. It occurs when there is a corruption in the disc which causes the recording mechanism to malfunction. There is a separate error message for this, however it is usually not detected until it's too late. When the recorder asks you to carry out the recovery process, do it. When the disc ejects, make sure you take the disc out that was in there when it occured and throw it away...it will keep happening because the disc is permanently corrupted. However, do not close the tray without a disc or the self-check will fail. Instead pop in a disc of the same format that the error occured in (if it was DVD+RW then put in a DVD+RW). It resolves the problem every time on the first try. (It only happened two times in a year and a half for me). As the manual says the unit is "NOT BROKEN".
May 23, 2007 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
640 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
