Question about Freezers
Swan sr5090 2 yrs old. just stopped working light on but not cold in fridge and not freezing in freezer ?
22yooper
  • 828 Answers
SOURCE: fridge freezer
Check your settings for the temperature controls. Freezer may be set to warm (IE #1) set it mid point. Also set the refrigerator at mid point and go from there to adjust each to maintain the temperature balances.
Posted on Jun 01, 2008
SOURCE: Dandy 8.8 fridge not working but freezer does
freezer works but fridge wont cool
Posted on Aug 29, 2008
  • 71 Answers
SOURCE: my fridge freezer defrosted n now wont wrk
what you are hearing is the overload kicking in and out. which means bad start relay /bad capacitor/low voltage/bad overload/bad compressor.you can buy a 3in1 to eliminate all but the compressor. and the voltage check them first.
Posted on Dec 14, 2008
  • 16 Answers
SOURCE: kelvinator F/Freezer not working. Not fuse
Sounds like gas is out.Probably leaking Contact the dealer where you bought it,Should still have guarantee.Jan
Posted on Feb 13, 2009
  • 3 Answers
SOURCE: Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Posted on Feb 27, 2009
Fridge 14 yrs old. Unplugged for 2 yrs - now won't cool.
with the unit being that old , the compressor probably whent out the oils inside probably froze up ,,,,, to replace a compressor you are better off replacing the unit it is a major repair
Jan 31, 2010 | Fisher Freezers
Had a fridge freezer in garage. Just found that
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Dave
Jan 08, 2010 | Zanussi 3.46 cu. ft. / 98 liter Upright...
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Freezer seems to be working fine but fridge is not cold... fridge is on top of freezer, it is a frost free zanussi, not sure which model thou, just coming up to 5 yrs old ? any help would be great thanks
A fan controlled by a thermostat is required to move the cold air from the freezer to the refrigerator for cooling. Use a volt meter testing the voltage on the fan. If you have voltage it is a bad fan. If you do not get a voltage test the thermostat. If it measures zero ohms short the thermal switch or if it is a short open one lead. If the fan works replace the thermal switch.
Sep 01, 2009 | Blueair Freezers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Aug 29, 2008 | Freezers
BEKO TZS490
AS A FRIDGE ENGINEER I HAVE COME ACROSS THIS PROBLEM BEFORE IT COULD BE A LOSS OF REFRIGERANT ALTHOUGH THIS WOULD STEADILY WORSEN IN USE,MORE LIKELY THERE IS A BLOCKAGE IN THE SYSTEM STOPPING THE REFRIGERANT REACHING ALL THE PIPEWORK THE CHEAPER FREEZERS USE THE SHELFS AS PART OF THE FREEZING SYSTEM.
THE ONLY SOLUTION IS A COMPRESSOR CHANGE AND REGAS (COSTLY IF NOT COVERED BY WARRANTY/GUARANTEE ETC)
IF FREEZER IS MORE THAN 5 YRS OLD BEST TO SCRAP IT UNFORTUNATELY..
Dec 19, 2007 | Freezers
Freezers Logo
122 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
