Question about Saeco Magic Comfort Plus Espresso Machine
When I steam milk, the GFCI pops to off each time after 8-10 seconds. We have cleaned the internal components,metal filter, plastic assembly, etc . Do i need to send in for service?
  • 1,089 Answers
Hi
Your seals or hoses on the steam boiler are bad. They are leaking on to electrical components and popping the GFCI. The problem is internal.
Posted on Nov 14, 2009
I cant get my steam wand to froth milk- it heats just fine, just wont froth.
The steam valve can wear plastic on metal, try pushing on the knob while steming , if the steam pressure increases the valve is worn out and not opening all the way.
Dec 24, 2014 | Saeco Incanto Classic Espresso Machine
Steam wand on Vienna plus detached from arm
Lets first make sure you have all the parnello wand parts. The nut, hard plastic gasket, soft rubber gasket, the inner wand then the sleeve and the center in the sleeve. When putting it back together find the notch on the metal steam wand and slide the nut onto the wand, then add the rest in the order above.
Jun 02, 2012 | Saeco Vienna Plus Espresso Machine
The pressure valve on my Mukka Express doesn't pop up. Instead after 10 minutes the valve is forced off. I rinse it really well and have even put it in boiling water. How do I get it to pop up?
I have the same problem. I cleaned all the parts, changed the pressure valve, cleaned the gasket, filters, everything. I hear the steam escaping from the overflow valve and if at that point I manually pull the valve up, then it does (barely) pop and steam the milk, but not as well as it used to.
Jul 25, 2011 | Bialetti Mukka Express
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Steam comes out strong for 25 seconds, then almost completely stops and water dribbles from the steam tube, then strong steam for 25 seconds, then it stops and dribbles for 25 seconds, then strong steam,...
Check the thermostats on the steam boiler, one of them is not working, also check the main board for damage, if the pump is not pulsing when you are steaming.
Feb 26, 2010 | Gaggia Titanium Espresso Machine
Plastic "Turbo Frother steam nozzle" blows off metal steam pipe
Pull off entire plastic wand off by unscrewing the top plastic piece. Inside the piece that connects to the screw top you should see two o-ring type spacers. The top one should be hard pastic and the one beneath should be rubber. Take the entire unit apart and clean, making sure to put all pieces back in the way they came out.
To put back on, take the top piece and put it back on the metal stem first then put the rest of the wand back on and gently push it as far up the metal stem as possible and screw back together. If you don't have the rubber spacer this could be the problem since the wand really has nothing grabbing onto the metal stem except for the rubber spacer. If this doesn't work, order another wand:
http://www.wholelattelove.com/Gaggia/gaggia_pannarello.cfm
Feb 27, 2009 | Gaggia Carezza Espresso Machine
No milk,or steam coming from cappucinno nozzle
If you pull the cappacino component off. The black plastic thing at the end of the metal tube (where the cappacino component's attached to) can be unscrewed by rotating it with your hand. You can clean it with a brush and a thick needle to clean the hole the make sure that it's not blocked. After that just screw it back on and reattach the cappacino component.
Dec 16, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Steamed milk
I just had this same problem and solved it.  It was due to a very small amount of milk residue on the inside of the black frothing unit (the one with the dial which lets you choose foam or no foam).  Grip the dial firmly and pull it out while twisting. It may take a few seconds to twist and pull it out.  I had a very small spec of milk residue in one of the crevices on this piece.  Quick clean with a toothpick and plenty of hot water, reassembled, and it works perfectly.  Hope this helps someone.
Nov 05, 2007 | Jura Capresso Impressa Z5 Espresso/Coffee...
Pavoni, no steam from steam wand
i havent heard of this issue , it could posibly be the bent steam wand , but the nozle is made to be that way, because the pavoni eurpicola doesnt produce enough steam pressure , it enables you to create better froth
Oct 25, 2007 | La Pavoni PC-16 Espresso Machine
Steam wand used to make great foam until just a week ago
The stainless steel cover has a very small hole near the top. The hole allows a venturi action - meaning air molecules are entrained with the steam flow to increase the affect. Milk will clog the hole, but warm water and a guitar string, cheese wire, even a staple - something thin - will work to clean it out.
After frothing either clean the entire stainless steel piece or at least occlude the end at the same time as shooting through some steam. I usually use a kitchen sponge with the abrasive pad attached. The pad helps insulate the heat and provides the necessary resistance to force any milk out the small hole.
Yes, I hate living with this also. In fact I am considering machining a different steam tube assembly.
Red
Oct 05, 2007 | Saeco Incanto Rondo Fully Automatic Coffee...
Saeco Magic Comfort Plus Espresso Machine Logo
113 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
