Question about KDS Visual Sensations 5 Monitor
No Signal My monitor is connected correctly, but it displays a message stating that it has no signal. I have already tried restarting the computer and reconnecting the plugs. What else can I do to solve this problem? Any assistance will be appreciated!
  • 51 Answers
Your video card is the problem its probably scrap !
try to reinstall the video card software if nothing comes up see a tech to replave the video card the monitor is fine! you could try the wire tthat brings the signal in if you daont have a spare take the pc with the wire o a tech to see wat is wrong!
Posted on Jan 08, 2008
After having unplugged my computer from router for a period of time when I hooked it back up I get no signal msg on monitor how can I fix it
Troubleshooting Network Problems on the Dell V525w and ...
DellMay 13, 2015 - My Account .... Back to Top ... The printer, the computer, and the access point (wireless router) are ... Try unplugging other devices that may cause a conflict with the USB ports. ... with only the VPN and no other network at the sametime. ... message during installation indicating that the printer does not have ...
Connection Keeps Dropping Off - NICs - Components - Tom's Hardware > Forum > Components
Tom's Hardware Guide
Mar 8, 2010 - 30 posts - ‎23 authors
I will sometimes lose my internet connection within windows. ... When I hook up the cable modem directly to the host PC everythinh ... My desktop has a linksys wireless NIC and I have no problems with it ... Comcast says when the cable box loses it'ssignal, the router can't get good communication back with ...
No Signal Message On Monitor And PC Gets Restart?
Nov 18, 2015 - started recently, when I boot my PC, the screen shows message: no signal and screen stays dark. ... then to get the signal back again, i must restart mysystem. then after boot up, i get ... Dell :: Having Trouble With Display On External Monitor .... laptop screen working until I unplug the 2nd monitor and restart my computer. What Is A Signal Cable On The Computer - Logo
Jan 17, 2016
BSOD When Unplugging Ethernet Cable - Logo
Nov 19, 2015
Monitor Doesn't Get Signal From Computer?
Nov 13, 2015
Cable Unplugged Network - Logo
Mar 22, 2013
More results from
Jan 27, 2016 | Dell Computers & Internet
How do I get out of no input signal
The video signal is not getting into your display.
Check the connections on both sides of your cable (display side and display card side). If that didn't help, switch off your PC, make sure youre display card is in its correct place (try taking it out and putting it back again). Switch on your PC and check again. If the problem continues, try replacing your display card.
Aug 11, 2014 | Sony VAIO Computers & Internet
Monitor states No signal. this is a new computer, just today
Make sure you are connecting the monitor signal lead to the correct signal output on the rear of the machine. Some desktops have extra video out connectors when they have a graphics card fitted. If yours has a graphics card the display connector will be away from the back USB ,audio and keyboard ports and near to some silver pop out panels near the bottom of the tower.
Apr 20, 2013 | Acer Aspire m5640 PC Desktop
No input monitor signal
Sounds like the video card inside the computer is bad. If the monitor was bad it would not be able to display the No Input Signal. To make sure, try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays the same No Input Signal message then your video card is bad. If the Borrowed monitor displays and works ok, then your original monitor or lcd screen is bad.
If you have a laptop, The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 31, 2012 | Foxconn (M61PMP-K) Motherboard
It was working fine yesterday. Today is states VGA no signal. What is the problem.
A number of things can cause "No Signal" on a monitor
1) Check the cable between the monitor and PC is properly connected
2) If the PC has more than one display port try changing the display port the monitor is plugged into
3) Try an alternative cable between the monitor and the PC
4) Check that the correct input is selected on the monitor
Dec 17, 2010 | HP w17e Monitor
The screen says no signal
If you have already verified the connection between your computer and the monitor you can try these steps to attempt to get an image on your monitor.
First, check your monitor for a button that says "source" or a button that has a square with an arrow pointing to the center. This will switch where your monitor looks for the signal.
A good rule to follow is if your monitor is connected to the computer by a cable with white ends, you should select "Digital", and if it is connected with a cable with blue ends, you should select "Analog" or "VGA". It is possible, but unlikely that your monitor is connected in any other way.
If these steps still do not work, follow these steps exactly:
  1. Press the windows logo key 220px-ctl_wndws_alt.jpg and "R" (This opens the "Run" window.
  2. Type this command: "shutdown /s /t 0" without the quotes. The shutdown command with the "/r" and "/t 0" switches tell shutdown to restart the computer at "time 0" which is immediately
  3. Wait for the computer to restart and it should automatically detect the correct display to use.
  4. If all else fails and you cannot get the display to connect, restart the computer and press "F8" until the computer comes up into safe mode. From there you can verify whether or not the monitor is actually functional, as driver incompatibility issues are not a problem when running in safe mode.
Nov 25, 2010 | Gateway FPD1975W 19" LCD Monitor
My monitor ( with less that 6 months use) has been going off while someone is using it--- says out of signal and i have to restart the comouter... and this is not stopping even with a restart
julezj, You will need to connect your monitor to a KNOWN GOOD pc that DOES NOT have the screen saver set to do a time out when the keyboard is inactive. Whenever you state a problem with a monitor on fixya, please mention the monitor technology you are dealing with. CRT (TUBE) or LCD flat screen!! IT HELPS IF WE KNOW TOO!!! Did it really display a screen message that read "out of signal" or did it read "OUT of RANGE SIGNAL"??? Is this monitor used to display HIGH resolution gaming and other high refresh rate imaging? Will this happen if you only have the WIN-desktop showing on the screen? Get back to me with more CLUES as to what happens on the screen. 12fixlouie Bye for now.
Nov 25, 2009 | Gateway Computers & Internet
NO SIGNAL What do I do?
These messages are normal when the computer truly goes into suspend mode or loses the video signal (such as when the computer is suddenly turned off).
If the monitor displays any of these messages when the computer should be displaying video , do the following items until an image from the computer appears:
Ensure the computer is really sending a video signal. To bring the computer out of suspend mode: move the mouse, press the spacebar, and press the suspend button on the keyboard twice (the suspend button has an icon that looks like a quarter moon).
Ensure the video cable is connected (and connected to the correct video port).
If you are trying to view video from a set-top box, DVD player or similar device, use its menu system to set the proper video output channel so that it matches the video connection are using. For example, if the monitor is connected to a satellite receiver via a second HDMI connection on the back of the receiver, select HDMI-2 (or similar) using the remote control for the receiver.
Turn off the monitor using the monitor's power button and then restart the monitor.
Cycle the power on the monitor as follows:
Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
Unplug the power cord.
Wait 5 seconds.
Plug in the power cord.
Press the power button on the monitor to turn on the monitor.
One of two things happens:
The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution.
Adjust the Windows display resolution to a setting that is compatible with the monitor:
NOTE: The native resolution setting for your model of monitor can be found in the Monitor User Guide, the monitor's product packaging, and product specifications.
Restart the computer and press F8 repeatedly after the first logo screen.
Select Safe Mode .
Windows should open showing a Windows desktop with lower resolution and fewer colors.
In Windows Vista, click Start , Control Panel , and click Adjust Screen Resolution in Appearance and Personalization.
In Windows XP, click Start , Settings , Control Panel and then double-click the Display icon and select the Settings tab.
Move the slider bar until the native resolution for the monitor is set, click OK and restart the computer.
If the native resolution is not available from the slider bar, click Advanced Settings , click List All Modes (from the Adapter tab), select the resolution, and click OK .
If the native resolution setting is not available as a selection in Windows, you can temporarily use 1024 x 768 to complete these steps. However, you should update the graphics driver on the computer. Updating the graphics driver can provide more display resolutions to Windows; possibly including the native display resolution for the monitor.
Check for nVidia video driver updates at nVidia Home Page (in English).
Check for ATI video driver updates at ATI Home Page (in English).
Check for S3 video driver updates at S3 Graphics Home Page (in English).
Check for Intel video support and downloads, Intel Downloads (in English).
If you own an HP or Compaq computer, HP hosts video drivers and some video driver updates at the HP Software and Drivers site (in English)
Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
NOTE: One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside of the HP Web site.
Jun 15, 2008 | HP PAVILION A6230N DESKTOP PC
No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Jan 11, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
KDS Visual Sensations 5 Monitor Logo
81 people viewed this question
Top KDS Computers & Internet Experts
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
