Question about The North Face Tritronix II Triclimate Jacket - Men's
Ziper teeth broken
The zip became jammed on my north face triclimate jacket. I eventually freed the zipper but about 4 of the plasticc teeth came off.
    Problem Solver:
  • 17 Answers
You will have to replace the zip unfortunately
Posted on Nov 14, 2009
Call the north face customer service at 1-866-715-3223. Tell them what happened and hopefully they'll repair or replace the jacket for you. I believe the jacket is supposed to have a lifetime guarantee. If you bought it from REI, the store will replace it for you if you have receipt of some sort.
Posted on Mar 13, 2010
How do I fix the zipper in my jacket?
I found a answer on google that helped me never heard before but it worked on a pair of knee high winter boots. I would have bet against it working only wore the leather boots one year. it said to get pair of pliers and gently squeeze the part the moves up and down along the teeth, the zipper had split and was a plasticky one. teeth would not join. hope this helps. it saved my boots.
Oct 07, 2015 | Clothing
Are all male elvis jackets from leathercult.com have left handed zippers
I can't answer specifically for that maker, but the split on zips put into garments made for the UK and for the US is on the opposite side. I saw this on a jacket my son bought in the US when on holiday there.
Oct 31, 2014 | Motorcycles
My zipper on my jacket wont zip up.
Make sure it is properly hooked at the bottom. Get a cake of soap and rub it on all the zipper teeth. Carefully and slowly try to ease the zipper up. Also,make sure there is no material caught in it.
Oct 13, 2013 | Eureka Tundraline Tent
Zipper won't zip up its almost shut closed
If all the teeth of the length of the zipper are snapped together, it is closed and the pull piece is all the way at the ends of the two matching sections. It appears jammed at that point, right? If so you may need to use a little muscle to pull the end links one way and the zipper tab the other. A pair of plyers sure could help.
Jan 23, 2013 | Crafts & Hobbies
How do I fix a zipper that won't zip?
I take it that your slider won't connect the two sides of the zipper but just slides along.
This is a common problem and is caused by the slider having opened up a bit.
Get a pair of pliers and gently squeeze the slider front to back so it'stighter on the zipper, this should do the trick.
(Check the zipper for a cracks first, if it's cracked this will be a very temporary fix.) There is acompany that makes a replacement slider that can be fitted to an existing zipper called ZlideOn www.zlideon.se
I carry a pair of these in my backpack, one latrge size for the tent and one that fits my jacket/sleeping bag/inner tent.
Ingenious product!
Aug 09, 2010 | Eureka Tundraline Tent
I need a replacement zipper for a last years Burton System Jacket. Where would I find one?
Call your local large camping store and ask them who does all their tent and pack repairs. Then call those people and talk to them about Zips
Nov 09, 2009 | Burton System snowboard Jacket
Broken zipper pull on snowboarding jacket
Put the zipper back on its tracks....use some staples (appr.3) and push them into where the old stopper was making as many tight circles as you can .use small needle-nose pliers. after this simply sew over top of the staples with strong thread or fishing line. It's a bit red necked ...but it works.
Aug 29, 2009 | Winter Sports
How do I remove a small part of ziper
You go buy a magnetic or three hook flexible retriever from your hardware store and go fishing down the side.
Or if the zipper is floating about loose you take the back off the machine after dumping the outlet hose into a bucket to drain off the water.
Tip the machine forward or backward so that the outlet hose from the drum to the pump is as near to the ground as possible then remove the clip retaining it to the outer drum and your zipper should be within grabbing distance.
Make sure you have an old towel underneath the hose before you crack the joint
Jul 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
The North Face Tritronix II Triclimate Jacket - Men's Logo
268 people viewed this question
Top The North Face Sport & Outdoor - Others Experts
Are you a The North Face Sport and Outdoor - Other Expert? Answer questions, earn points and help others
