Question about Cell Phones
The phone has apparently been dropped and now will not ring.
    Scholar:
  • 173 Answers
A hard reset involves physically removing the battery from the smartphone and
then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone. 2) Remove the battery, and then reinsert it after a few seconds. 3) Replace the battery cover.
Still if it is not working kindly walk into the nokia service center this might be a Hardware issue.
I hope I was able to help you.
Thank you for using Fixya.
Posted on Nov 14, 2009
The oil level drops after driving the and and it has no oil leakages,what might be the problem
if the oil level drops with no apparent leaks ,then it is being burnt in the engine either by going past the rings, being burnt in the sump by having worn rings , pushed out past the PCV valve . have a compression test to gauge the condition of the engine.
Jan 28, 2015 | Cars & Trucks
Why does my cell phone keep ringing and vibrating every couple of minutes ?
Try removing battery - leave it disconnected a min - then reassemble... sorta like rebooting a computer...
Sep 03, 2014 | Samsung Galaxy S 4G Cell Phone
Drop in oil pressure
The most likely cause is that the O-rings on the feed pipe from the oil pump to the block have degraded. This can cause a severe drop in pressure, but may only be apparent when the oil is hot and therefore thin
Nov 09, 2011 | 2000 Volvo S80
I have a SAGEM D30V cordless phone which was working beautifully when I was connected to Telsta (here in Australia) but I changed my service provider over to TPG and now the phone only rings once and then...
I had the same problem when I switched to a ST780WL router. I solved it by changing the voice country configuration to uk as the ring cadence for australia in this device is wrong.
Feb 17, 2011 | Cell Phones
I have a LG 220 C phone and I am trying to figure out how to deactivate the announcement feature on the phone. My phone is not ringing; it is just announcing the incoming caller's phone number.
Go into the menu. Then hit '8' (calendar, alrms, etc I think?). Press '1' (voice commands). You will then get a drop list to check or uncheck regarding 'deactivate', 'announce', 'announce +ring'. Select deactivate-- now your phone will ring normal! Son had same prob on his phone-- apparently he'd hit 'announce' at some point....
Jan 27, 2011 | LG C 2200 Cellular Phone
Phone doesn't ring long enough
Apparently the problem was at the networks end. I had to ring them to set the ring to a longer time and had them deactivate voiemail.
Feb 07, 2009 | LG KU990 Viewty
Intercom rings and there is no one there, the sound of dialing pr
You might have a door phone that was installed and programmed as a door phone extension. Now a physical phone that is connected to a previous door phone port is causing this.
Check your #604 and #605 command
Jan 13, 2009 | Lucent PARTNER18 Corded Phone
Panasonic kx tg5571 phone drops all calls after first ring
I have the Panasonic phone system Mod. # KX-TG5371. My calls, in and out drop out after 1st ring often. Whats going on.
Don
Dec 29, 2008 | Panasonic Phones KX-TG5571
Recieving / answering phone
i had the exact same problem. basically (sounds a bit weird) but it happens if you drop your fone and the only way to let people hear you again is by dropping it again! so whenever you drop your phone you have to drop it again to fix it.
Jun 14, 2006 | Sony Ericsson T610
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
