Question about Bosch WFL 2063 Front Load Washer
How do I know if the problem with my Bosch is faulty motor or carbon brushes fixing if the drum is not moving and the other parts are functioning? Also if it is carbon brushes, how do I fix that? If it is motor, is it worth replacing it?
  • barjthomps00 Nov 14, 2009
    Thanks Guru for your helpful contribution. I'm based in London UK and a starter with respect to appliance repairs. I will need contacts here and pictorial guidance on how to fix a motor. Will you advise me to sort out this 3 and the half old Bosch Washing machine or get another one?
    Thanks again Ed
  • barjthomps00 Nov 15, 2009
    thanks Guru,
    Not able to explore your contact as I'm in London UK. I'm a novice at appliance repairs and not able to completely disassembled the washing machine. Is the motor easy to remove and get a working replacement that I can fix myself?
    Thanks again
  • 770 Answers
I can offer an inexpensive solution to your problem. Whether your motor is faulty or you have a brush issue...it is still motor related. The brushes are an easy repair, but the proper brush replacement needs to be properly fit to make the necessary contact. When I run into a problem such as yours, I replace with a good used motor from a local appliance salvage that has proven to be very reliable. The parts that I have gotten from this establishment have held up well and he has even offered a limited warranty on the parts that I have purchased. As a matter of fact, I have a replacement motor from him in my dryer right now. I bought it a year ago for $30. If you choose to go with new parts he can assist with that as well. The name of the place is "Belks Used Appliances" He will ship the parts to you. (704)864-4496. Speak to Harry Belk. Good Luck, I hope this is helpful!
Posted on Nov 14, 2009
  • 1 more comment
  • Hal Hallman Nov 14, 2009
    Brushes cost about $36 dollars per set, and I have heard of repair men charging as much as $350 parts and labor to do the repair. If you choose to repair the brushes, here is the proceedure. This is the way I do it. It saves scrabbling about on the floor!
    Switch off power, disconnect hoses, open pump housing to completely empty machine of water.
    Turn the machine upside down onto a soft surface - eg a blanket on the floor, and carefully cut the cable tie holding the motor cable and splashguard to the motor body; disconnect the motor connector and earth spade to facilitate easy access to the more visible brush block. The brush spades disconnect easily, then the brushes are extracted by sliding each spade terminal inwards toward the motor spindle until the connector end is released from the block, then pull the other way to release the inward end - withdraw the spring/brush assemblies gently from the carriers. The brushes are clearly on either side of the motor spindle but see how they do not fit on a diameter of the motor axle but are inserted tangentially - the curve on the brush is polarised to take this into account - you want to have the wider carbon contact surface of the two fitting options possible. Reassembly is simple but make sure you do not reconnect the mains supply if any water has been spilled into the top of the machine...
    You can test the motor using the spin cycle before re-installing the machine properly. Good luck! Hope this is helpful!
  • Hal Hallman Nov 15, 2009
    Really not very difficult if you have a mechanical aptitude...If not do you have a friend closeby that could weigh in and assist? If neither of these apply, you may want to call and get an estimate on the motor repair, then you could weigh the decision, to fix or replace. Your machine is not very old...suprising that you are having motor problems on such a new machine. I wish you luck...if I can aasist further, please do not hesitate to let me know..Good Luck!
    Hi Ed,
    I looked for something in UK to help you out close to home...found a company called UK Whitegoods, I have attached a page with Bosch Carbon Brushes. Also, I noticed they had repair manuals available and Tech support, I could not find a diagram for your machine, but if you'd like, or if this doesn't help, I'll surely continue to look, or maybe see if my friend Harry can give me something to scan and send to you....I've never went quite this far with a fixya client, hhowever, you being out of the country and not sure if you should tackle this, thought I would assist all I could. I try to give good solutions and maintain a good reputation on this site, so I do want you satisfied. Hope this works for you! Continued Good Luck!
    http://shop.ukwhitegoods.co.uk/Washing+M...
I have just replaced the carbon brushes on my Bosch classic 6 washing machine and wasn't convinced that I put one of them the right way round. The motor is now working ok but it is making a highish pitched...
I would not think putting the brush in the wrong way round would make a high pitched noise. I would look for something rubbing against the drum or check the bearings of the drum or armature of the motor.
Jan 14, 2015 | Bosch Washing Machines
I have a Bosch Exxcel 7 1400 express, had F21 error which I cleared but now when set to wash, water comes in but the drum doesn't move.
F21 refers to the carbon brushes in the motor so price new brushes - if you are handy they are easy to fit and not expensive - but if you can't do it yourself i personally wouldn't spend too much on repairing a 5 year old machine
May 04, 2014 | Bosch Washing Machines
My machine taking in water but drum not moving
Hello when you start the machine do you hear clicking from control board if do all you need to do is replace the carbon brushes on the motor. They are cheap to get does require removing back pannel I found better to remove motor easy access hope that helped :)
Apr 18, 2014 | Bosch Classixx WFL 2066 Front Load Washer
Bosch 2604320913 Carbon-Brush Set
No If the saw is running the brushes must be working. Maybe the front end grease has dried causing too great of load on the motor. if not the motor must be defective (lost a winding in the feild) don't know how much you paid but unless its worth is greater than $150 I sugest buying another
Sep 18, 2012 | Bosch 2604320913 Carbon-Brush Set
Hi i just want to check to see if belt is ok, but dont know where to look, i have a drum wont turn
Its probably your motor carbon brushes. If the machine electricals work OK and it pumps water in and out then the carbon brushes have just worn out on the motor. I had the same problem with my Bosch front loader. Easy fix and you can get help visually on youtube. If you are looking for the belt to see if it has come off, undo the screws that hold the plate on the back of the washing machine to access and sight the belt. Also this will give you access to the motor if you need to change the motor carbon brushes. Hope this helps Sue
Aug 09, 2011 | Bosch Washing Machines
Installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Drum will not rotate or spin
oooops - the motor was stuck under the carriage. Once
moved it came off easily.
Jun 17, 2008 | Bosch WFK 2401
Bosch Maxx WFL 2260
My drum stop, then I put in new carbon brushes. It works very good in 2mouth, now it stop again. Wht can be problem?
Jan 17, 2008 | Washing Machines
Wont spin, and arcs.
2 bruhes in motor
replace motor brushes
use correct brushes from bosch
Oct 09, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL 2063 Front Load Washer Logo
64 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
