Question about Furuno 1942 Mk2 Radar
Furuno 1942Mk2 Problem
My radar got damage, I changed the transceiver for a new one and it'sworks, but now I get the following message ''hdg sig missin'' and theorientation of the objects on the screen are wrong.
  • Anonymous Mar 13, 2014
    auto tune and PM test are not work, but in man tune all ok. additional sound is present in transceiver unit and tone changed during changing of pulse
    New Friend:
There is an internal Heading magnetic or optic switch which terminated with a think cable and wellow plug on the T/R PCB.
Check that conduct by a multimeter,fitted in place and try again
on display unit for targets stabilizing.Maybe also using that RDR
a resolver motor counder,you also check tha cabling of this.
For more info mast be read the Radar's manual. I am JRC spcialist, no Furuno but I have RDR experience.
Posted on Oct 12, 2013
  • 232 Answers
It cannot determine a heading, have you also damaged an internal antenna or positioning / gps device inside it? It is unsure which direction it is pointing in but uses triangulation to determine this.
That requires either an electronic compass unit, or gps to achieve correct heading and hence correct orientation of the radar image
Posted on Nov 15, 2009
How to fix "BRG SIG MISSING" error on an old FE-1505 MARK-2. ?
Make sure the antenna/scanner is turning in tx mode. The bearing signal is generated inside the scanner drive motor. This problem usually requires replacing the motor.
Jun 26, 2014 | Furuno 1832 Radar 36nm
Furuno radar
Your antenna seems to be mis alighned. Its ZERO point must be readjusted.
Aug 30, 2008 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
How to install FURUNO magnetron MG5436 for Radar
Assuming you have the right magnetron for the right model radar, you desolder the two leads, remove the 4 or 6 mounting screws and reverse the process for the new maggie. Let radar run in standby for 30 minutes before going to transmit. Most Furuno radars have auto-tune and will tune itself to new magnetron.
Feb 23, 2014 | Maytag Kitchen Ranges
Furuno radar 1715
Cek wiring to scanner, change reedswice sensor /heading sensor. If the problem not solve, change the display with the new one.
Oct 01, 2013 | Furuno 1715 LCD Radar System GPS Receiver
Brg sig missing
That usually means the antenna is not rotating. Verify that first then check for physical obstructions. More than likely it's a defective motor assembly.
Jun 24, 2013 | Furuno 1832 Radar 36nm
Furuno MK 1942. The antenna does not spin. There is a message on the screen "HDG SIG MISSING". Though the magnetron is fairly new one. I can´t access the Instalation Setup at MENU > OTHER...
Either you have a bad cable, or the motor has given up. Sometimes it can be the mod. board but the bearing pulse generator is located on the motor itself. Also check to see if theres a switch on the back.
Oct 14, 2010 | Furuno 1942 Mk2 Radar
A furuno 1715 lcd radar was wired to battery backwords
internal damage to the display, fixable by Furuno, and probably economically feasible (guess $250 with round trip to Furuno)
Nov 17, 2009 | Furuno 1715 LCD Radar System GPS Receiver
The top half of the dome blew off while towing boat. Any way to replace the top half with a used or new piece? Don't need to replace the whole dome.
As long as no damage was done to the enclosure from the lid blowing off, there is no reason that you can't simply put a dome on it. Try contacting furuno direct to see if the part is available. Make sure you know exactly what model radar you have before you call.
Furuno Tech Support : 360 834 9300
Jul 29, 2009 | Furuno 1623 Radar 16nm Range
Error SB SIG MISS on FURUNO CRT radar?
Either your reed switch is bad or your antenna is not rotating. You may hear the motor spinning but that does not mean the array is. If the array is not spinning make sure the belt did not come off the motor. Start there.
Jul 05, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Furuno 1942 Mk2 Radar Logo
211 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
David Burbee
David Burbee
Colin Stickland
Colin Stickland
Are you a Furuno Boating Expert? Answer questions, earn points and help others
