Question about Cell Phones
My vu is frozen and i am ony able to push the hard keys like send back and end what can i do
    Sergeant:
  • 297 Answers
Open ur phone and clean it with siprit
Posted on Nov 14, 2009
My lg vu phones bottom keys wernt working so i turned it off and it wont turn back on any suggestions to fix it
I think you were ruff with the keys and you pushed them once too hard, so in other words the buttons have stoppd, i may be wrong but you may want to talk to a local AT&T provider and see what they can do.
Sorry if this had no help to you.
Apr 30, 2010 | LG Vu CU920 Cellular Phone
No water from cold water facuet
Remove lower grill and disconnect the water line going through the freezer door hinge. Usually it is a push lock fitting, which requires you to push the ring2_bing.gif on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater2_bing.gif. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
Dec 08, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Easiest way to thaw out a possible frozen water reservoir in my GE side by side fridge?
Hair dryer is the easiest way to thaw. To find cause: Remove lower grill and disconnect the water line going through the freezer2_bing.gif door hinge. Usually it is a push lock fitting, which requires you to push the ring2_bing.gif on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater2_bing.gif. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter2_bing.gif or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
If water filter or water line/ reservoir is frozen, thaw with a hair dryer. If reservoir is frozen, check to make sure there is no frost on back wall of inside freezer, preventing normal air flow, allowing cold air to enter fresh foods compartment through return air vent at lower back of fresh foods compartment, resulting in freezing of water line / reservoir and possibly food in bottom bin.
Nov 18, 2009 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
Keys have frozen.
=) This may sound weird, but try banging it hard on your hands (just like you bang your TV remote). This is a common problem with RAZR's and the other solution is to send it in for a $15 fee for their problem. But, from what I see, banging it against your own hand has worked for many =P.
If this does not solve your problem, please leave a comment and I'll get back to you as soon as I can.
Jul 26, 2009 | Motorola Mobility RAZR V3c Cellular Phone
How do you cancel sending a text messege on the lg vu
the best way is the second you push send go to outbox and options cancel but you ahve to be extrmely fast hope i helped
Jun 29, 2009 | LG Vu CU920 Cellular Phone
How do you 3 way call on the LG vu. when i call the third party with the other person on hold it wont let me join them.
  1. While on the first call, dial the 10-digit number of the second person.
  2. Press SEND; the first person is automatically put on hold while the call is made.
  3. When the 2nd person answers, press SEND to create a conference call.
  4. If the second person does not answer, press the SEND key twice to end the connection and go back to the first person.
  5. To end both conversations completely, press the END key.
Jun 15, 2009 | LG Vu Cellular Phone
No water but ice maker works
Remove lower grill and disconnect the water line going through the freezer door hinge. Usually it is a push lock fitting, which requires you to push the ring on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X101073 water tube heater. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
Feb 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hard Reset Wing
Hold down both soft keys (both above the send and end key's) and use the stylus to push the reset button in between the volume key and micro sd slot. Then the screen will turn on and tell you something to the extent of press "Send" to perform a factory reset. Hit send, and your good to go.
Apr 24, 2008 | T-Mobile Wing™ Smartphone
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
