Question about Bosch 13.0 cu. ft. / 368 liter Chest Freezer GTA37900
Gtl 3720/01 never switches off - Bosch 13.0 cu. ft. / 368 liter Chest Freezer GTA37900
Green light wont come on
Is unit running? Orange switch - is that the fast freeze switch? If on and running, green light faulty. If nothing happening, start with fuse, test the switch and make sure power is to the thermostat.
Apr 04, 2014 | Freezers
Freezer temp keeps dropping despite putting on superfreeze switch. What might the problem be?
I own an Imperial freezer and it has a superfreeze switch. The schematic electrical diagram on my freezer shows that the superfreeze switch when activated, bypasses the temperature control thermostat and keeps operating the compressor motor non stop. Try switching the superfreeze to off after you reach your desired freezer temperature.
Aug 28, 2011 | Miele 4.2 cu. ft. / 119 liter Upright...
What is the on/off switch at the bottom for.
Sorry to read about your problem, I hope this helps you out.
High-Temp Alarm Switch (on some models)
An alarm will sound if the freezer temperature reaches unsafe levels. The alarm operates on household electricity. If the power fails, the alarm will not perform.
An ON/OFF switch allows the temperature alarm to be deactivated if desired. The freezer is shipped with the switch in the OFF position. After the freezer has run long enough to lower the temperature, you may set the switch to the ON position.
CAUTION: Adding more than 3 pounds (1.5 kg) of warm food per cubic foot of freezer capacity can trigger the alarm.
To activate the alarm, set the switch to the ON position.
To deactivate the alarm, set the switch to the OFF position.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | GE 20.3 cu. ft. / 575 liter Upright...
The "door ajar" alarm keeps going off and the door is sealed shut?
Your door switch may be bad. Is the light on when you open the door when you manually push in on the switch does the light go off? On most fzr the door ajar alarm is set off by the door switch showing the door is open.Turn off the power by unplugging the fzr then you can pop the switch out with a flat blade screw driver if it is only a two wire you can use a paper clip to connect the two wires wrap them with elect tape Then plug the freezer back in and see if the problem clears if it does order a door switch. Some units use a vacume sensor but i believe all kenmores use the door switch. good luck
Aug 17, 2010 | Kenmore Freezers
Refrigerator inside light will not go out when door closes
This can be due to one of two things, either the door is not hitting the light switch when it closes or the light switch is bad.
Locate the switch, it is usually on the top of the cabinet inside the refrigerator, push the switch, if the light does not go out then the switch is bad, if the light goes out the door needs adjusted so it will hit the switch when it closes. Typically this can be done by loosening the hinges and holding the door in place while someone tightens the hinges back up.
May 08, 2010 | Kenmore Freezers
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
unsafe levels. The alarm operates on household electricity.If
the power
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
the OFF position.
After the freezer has run longenough to
position.
to the ON position.
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
Long story but I had someone "attack" my T-72 Freezer and I'm trying to figure out what they did. I think they tried to replace the defrost switch with a non standard switch and stopped half way through...
http://www.truemfg.com/index_en.aspx?language_id=1&event_id=401
Go to this web site. Be sure to have the serial and model numbers. You can request a wiring diagram from the tech line. This is most likely your best place to start. True uses a variety of different devices so I would do this first.
Let me know if I can be of more help after you get diagram.
Dec 07, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Evaporator fans do not come on, why would evaporator is not cool enough?
There are three main reasons the fans would not come on.
1: A bad door switch. There are switches on the top part of door frame. They turn fans off when door is opened to prevent warm air from being drawn into unit when door is open. If a switch goes bad the fans will never turn on.
2: Refrigeration problem. The fans are tied into a temperature switch called a fan delay. The fans will not come on until the coil is well below freezing. This is to prevent water spray after a defrost. If unit is low on gas or has any other cooling issue the fans will not come on.
3: Bad fan delay switch. If the fan delay switch becomes "stuck open" the fans will not be energized.
Feel the back of your evaporator coil, if it is very cold and frosted you probably have a bad fan switch, or a bad door switch. ;)
Oct 10, 2009 | True 49 cu. ft. / 1388 liter Commercial...
What is switch on bottom outside for?
that is a temp alarm switch it will buzz till the temp drop to freezing temp
Dec 30, 2008 | Freezers
Bosch 13.0 cu. ft. / 368 liter Chest Freezer GTA37900 Logo
Top Bosch Freezers Experts
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
